MOSFET equivalent
  • Askic
    • Sep 2018
    • 187
    • BIH
    MOSFET equivalent
    Hello guys,
    I have a shorted MOSFET with the following characteristics:
    Type Designator: MDF4N65BTH
    Type of Transistor: MOSFET
    Type of Control Channel: N -Channel
    Maximum Power Dissipation (Pd): 35 W
    Maximum Drain-Source Voltage |Vds|: 650 V
    Maximum Gate-Source Voltage |Vgs|: 30 V
    Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
    Maximum Drain Current |Id|: 4 A
    Maximum Junction Temperature (Tj): 150 °C
    Rise Time (tr): 22 nS
    Drain-Source Capacitance (Cd): 61 pF
    Maximum Drain-Source On-State Resistance (Rds): 2.2 Ohm
    Package: TO-220F
    Can I use the following as a replacement (in TV supply board)?
    Type Designator: STP10NK70ZFP
    Maximum Drain-Source Voltage |Vds|: 700 V
    Maximum Gate-Threshold Voltage |Vgs(th)|: 4.5 V
    Maximum Drain Current |Id|: 8.6 A
    Total Gate Charge (Qg): 64 nC
    Maximum Drain-Source On-State Resistance (Rds): 0.85 Ohm
    Thank you
    • 31281
    Re: MOSFET equivalent
    probably.
    if you had the gate capacitance i could give a better answer, the gate capacitance limits switching speed - lower is better
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Originally posted by stj
      probably.
      The Ciss for the MDF4N65BTH is 518 pF typical.
      The Ciss for the STP10NK70ZFP is 2000 pF typical. https://cdn.badcaps-static.com/pdfs/...f9e2115c39.pdf
      PeteS in CA
        • 31281
        ouch.
        i hope the driver has a strong push/pull output!
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Drain Current |Id|: 7.5 A
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • dj8452000
          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
          by dj8452000
          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
          02-18-2025, 08:28 AM
        • tmaster21
          Ideapad 100 NM-A841, P channel mosfet on laptop in.
          by tmaster21
          Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
          Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
          07-17-2023, 09:48 AM
        • dreico33
          AON7403 Mosfet Equivalent
          by dreico33
          Hellow guys,
          I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
          Thank you very much.
          11-16-2024, 09:28 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
