resoldering a broken off fan wire
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    im trying to repair some fans with broken off wires from the fan pcb. please refer to the attached pictures. however, the fan pcb seems to be glued to the stator and i cant access the solder side of the fan pcb. anyway to pry the pcb off the stator without damaging it or anything? thanks.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: resoldering a broken off fan wire
    The ones I've run across the stator magnets come off with the pcb unglued. If it is actually glued then I think you're SOL and best you can do is carefully cut plastic on the other side and solder very carefully...
    • eagleeyez
      • Sep 2011
      • 29
      it is not glued but the axis is riveted and it is not easy to remove it without breaking something, your best options are to try to tin the wires and then use small soldering tip to slide it under or maybe heatgun, but the best option as eccerr0r said is to try to cut the plastic underneath with a dremel or a sharp tool, maybe cutting pliers can do the job too... otherwise just throw it and buy another one most of the time you spend more time that what this kind of repair are worth.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        On many cheapo fans, PCB and stator are held together and glued onto a plastic "collar" that is used for holding the bearings (be it BBs or sleeve bearings.)
        If you have a heat gun, give the stator a little bit of hot air (or a little more than "a little", but not so much as to melt the plastic - i.e. don't heat the thing much more than around 100C.) Then, using some cloth or wool glove (something that will allow you to grab the stator with enough finesse, yet not burn your hands), twist and pull away the stator from the plastic fan casing. It may or may not come out easily, depending on how much and what kind of glue they used.
        Note: you can do several heat-cool cycles to weaken the glue too. That way, you may not need to heat the stator as much sometimes.
        Also a useful hint: before trying to pull away the stator with the PCB assembly, make sure your wires on the other side are free and ready to go (i.e. not meshed between the usual plastic tabs that hold the wires in place when the fan is normally assembled.)
        Otherwise, the alternative is as eccerr0r suggested: just drill/break/cut away plastic from the back of the fan and solder the wire that way. I've done this too, and this method works too. So you can do whichever one you're more comfortable with.
          • 31087
          cutting away some un-needed plastic is best, you can break shit real easy trying to get the board out.
          as for cheap, most dont use glue.
          they put the board and coil assemby over the plastic sleeve,
          then drive the bearings in with a press so the plastic expands slightly and locks it all in place.
          if you punch the bearings out the plastic does NOT shrink back down!
          • emeskay
            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
            by emeskay
            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
            08-06-2024, 07:13 AM
          • mar1in
            Fix broken tinsel wire on Speaker
            by mar1in
            I've saved a pair of Philips AH 495 speakers from landfill and diagnosed the woofers are not working due to a loose or broken tinsel wire just on the joint of the cone (left wire on the picture)
            What's the best and easiest way to fix this without damaging the cone ?
            Can this be simple soldered on?...
            10-12-2023, 05:07 PM
          • wnlewis
            New wire for my RDE3340 Whirlpool electric range
            by wnlewis
            OK. I got the rocker switch figured out thanks to the good advice on this forum.
            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
            This is a Whirlpool RDE3340 electric range.
            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
            Where may I find parts...
            01-08-2025, 11:21 PM
          • technicalspecialist
            Vintage fan repair, copper wire question
            by technicalspecialist
            I currently have a customer's vintage fan on the work bench to repair.
            It uses an induction motor with 4 poles. One of the poles is open.
            I couldn't find the break so i cut off the original wire.
            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
            The enamelled copper...
            03-16-2023, 12:54 PM
            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
            by sam_sam_sam
            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
            12-16-2023, 08:39 PM
