10w 100 ohm resistor
  • sam67
    • 256
    Hi i have a few 100 ohm 10w wire wound resistors .. how much voltage can these take ,say for discharging a cap ..or would i need summat in the 1.8k range.. Just wondered that's all as i thought i might be able to use em rather than chucking em..I measured the spec with my dvm and they are in spec.
    cheers
    • 31131
    Re: 10w 100 ohm resistor
    depends on the make & series.
    pretty sure it will be 300+ though.
    you want to put a number in series for discharging big caps btw.
    • sam67
      • 256
      Hi the caps are in an lcd monitor ,i was thinking of getting a couple of 10w 2k wire wound resistors and use one of em to touch both ends of the cap leads on the underside of board...i know some discharge after you shut them down but i wanna make sure using a volt meter also..it's an lcd what i am just practicing on with some soldering and what not ..So this method should be ok right for the bigger caps ?..I have not opened it up yet but will be going to just to get a few good parts off.
      cheers
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The voltage rating will depend on:
        Ohm and Watts [do the math]
        -and-
        How thick the insulating materials are [arcing through the insulation].
        There is no way to find the second one out if you don't have a PN & Datasheet or markings on it that tell you.
        Mann-Made Global Warming.
        - Dr Seuss
        • larrymoencurly
          • Oct 2004
          • 960
          I've been told that the maximum across a resistor shouldn't be more than about 500V, and I have a Panasonic CRT monitor with several identical resistors in series that seem to confirm that.
          • kikkoman
            • Jul 2007
            • 691
            for wirewound resistors, vishay says max voltage is (P x R)^0.5.
            since this is for continuous operation, the limiting factor is the power dissipation.
            for a 10W resistor that gives you 31.6V.
            if you put 4 in series, that gives you 126V; 5s give 158V etc.
            i'm sure though you can go well beyond the ratings if it's just a pulse like from discharging a cap.
            "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
              • 31131
              worth adding that a big cap could dump 3-6amps into that resistor when it's fully charged.
              i'd rather make a discharge lead with a few 1meg high-voltage resistors in series in it.
              that would act slowly enough to even discharge a 30kv crt safely if you use well insulated wires.
              • sam67
                • 256
                Hi guys, i have this guys lcd monitor repairs and other stuff ,he reckons doing this will be ok.. http://www.electronicrepairguide.com...discharge.html
                Seems theres lots of people have different methods.. p.s he recommends a 1.8 to 2k resistor either 5w or 10 also for SMPS he says either a 2.2 or a 4.7k will work ..
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
                • badcap111
                  Xiaomi mi 9T missing resistor
                  by badcap111
                  Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                  I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                  Is...
                  08-07-2023, 10:42 AM
