Help identify a Zener?
  • alwalker
    • Jun 2023
    • 17
    • US
    #81
    Re: Help identify a Zener?
    I have two Liftmaster garage door openers and they both now have the 990LM surge protectors wired into them. I was a little curious about the protection going to the safety sensor and opener switch so just to see the answer I would get I sent an email to Chamberlain/Liftmaster asking (1) why the 990LM was discontinued, (2) if they had a schematic of the 990LM itself available and (3) if it protected the logic board or if it actually protects the safety sensors. Here is the response I got:
    Thank you for contacting Chamberlain Group Technical Support. We sincerely apologize for the delay in our reply. Please see below for a response to the inquiry you recently submitted on our website.
    Hello, I will be happy to assist you. Unfortunately, we no longer have schematics for the 990LM surge protector. Details as far as why it was discontinued have not been given. The wiring to the safety sensors and to the motor was protected while using the surge protector.
    After dismantling the 990LM we now have a very nice schematic courtesy of Redwire. I don't believe that Chamberlain does not have a schematic of the unit even though that is what I was told. I also do not believe that the 990LM protects the sensors--at all. Hopefully it will protect the logic board if a strike comes through the rails and wiring. I already knew that the surge protector does not protect the sensors since I experienced lightning damage to the sensor when the 990LM had already been installed. Sometimes it's just fun to ask questions of manufacturers when you already know the answers will be either irrelevant or incorrect.
      • Jul 2011
      • 6039
      This is unacceptable and unfortunate that this company has this attitude about there product and surge protector device which must have been discontinued because then that way they can make more money on replacement parts or the hole unit
        • Jul 2011
        • 6039
        Originally posted by redwire
        Not sure where the part number is not working? The 990LM schematic is just a picture. I could post a bill-of-materials if you are making one.
        If I lived in Florida or Texas I would definitely have lightning protector on the garage door opener.
        Could you please do that for me because I want to add this to my garage door openers because I have had lightning strike one of the opener more than once
        One time it fried the door sensors another time the same thing and the controller board as well and the door switch controller as well I also think it damaged the motor as well in some way because it would run very warm also the up/down force adjustment we're screwed up as well
        That time I just replaced the garage door opener because the replacement parts were almost as much as a new one
        • redwire
          • 3907
          I think Liftmaster/Chamberlain made a design mistake so the sensors are susceptible to lightning damage. The sensor mounting bolt arcs to the PC board and kills them. I think this is because the mounting bolt/bracket is grounded to the garage door rails yet the opener electronics is grounded to mains ground.
          It seems suspect the sensor PC board has traces around the mounting bolt- when you actually want lots of clearance instead.
          This might be why the 990LM did not work- lightning zap happens at the sensor mounting bolt and the lightning protection module is a mile away, it's over at the opener. I wonder if adding a thick ground wire to the door rails would help, but to what? The pad? or Mains ground? It's hard to know if the rails/door are the antenna for the discharge, or the lighting surge comes in on mains.
          • redwire
            • 3907
            For the Liftmaster 990LM possible bill-of-materials:
            Code:
            where				Qty		Description				mfgr		p/n		Mouser		Digi-Key
            Sensors				2		TVS DIODE 1,500W 33.3VWM 69.7VC DO-201	ST		1.5KE39A	511-1.5KE39A	497-6607-1-ND
            Neutral-GND			1							Original	GNR14D431K
            						MOV 275VAC 6kA Disc 14mm 		Bourns		MOV-14D431K	652-MOV-14D431K		118-MOV-14D431K-ND
            						MOV 275VAC 6kA Disc 14mm 		TDK Epcos	B72214S0271K101	871-B72214S271K101	495-1412-ND
            Line-Neutral and Line-GND	2				need thermal fuse	Original	GNR20D431K
            						MOV 275VAC 10kA Disc 20mm Thermally Protected	Littelfuse	TMOV20RP275E		576-TMOV20RP275E		F4042-ND
            						MOV 275VAC 10kA Disc 20mm Thermally Protected	Eaton		MOVTP20V275N		504-MOVTP20V275N 		283-MOVTP20V275N-ND
            Sensors ground			1		Original	GNR14D201K
            						MOV 130VAC 6kA Disc 14mm		TDK Epcos	B72214S2131K101		871-B72214S2131K101 		495-1436-ND
            						MOV 130VAC 4.5kA Disc 14mm		Bourns		MOV-14D201K		652-MOV-14D201K 		MOV-14D201K-ND
            						MOV 130VAC 6kA Disc 14mm		Panasonic	ERZ-V14D201		no stock			P7217-ND
            • alwalker
              • Jun 2023
              • 17
              • US
              #86
              I would think the mains ground. I wish I had an easy way to install an extra ground rod near the basement opener. That one is furthest from the electric entrance panel. BTW--I did check the condition of the ground rod and wiring at the meter. No problem there. I do suspect since the opener I have had the most lightning problems with is the furthest from my electric panel and that ground rod another ground rod directly attached to the rails might do the trick. I wish I could do it easily in the basement without tearing up the concrete floor to add a ground rod. It's doubtful the wife would approve
              • alwalker
                • Jun 2023
                • 17
                • US
                #87
                Made it all the way through 2024 without a lightning strike taking out the 14LG479-2C emitter board. Not so lucky this year though. I have another emitter board fried with the almost daily thunderstorms we've been getting this summer in NC. What would be a good replacement for D103--it is dead shorted. The 5mm 940nm led's I see on Ebay perhaps?
                https://www.ebay.com/itm/37637395887...3ABFBM1Lfw6YVm
                • redwire
                  • 3907
                  From what I can tell the Rx is 950nm and you'd lose 20% sensitivity at 900 or 1,000nm. So 940nm will work OK.
                  But, there are wide angle (IR remote control) and narrow angle (light curtain or obstacle sensor) IR LED's.
                  I think it's originally a narrow angle one, you can see the LED die/cup is at about the middle or further back. It might even be special if the end is fat?
                  The eBay ad one is closer to the end (die cup) so I think it's a wider angle IR LED, like for IR remote controls.
                  With the big lens it makes a narrow beam. As long as the fit and alignment (white holder post #9) are kept the same, give it a try.
                  For the lightning zaps, I think all you could do is move the obstacle senors off of the metal rail, put them on some wood so it cannot arc to them. Or change to a plastic mounting bolt.
                  • alwalker
                    • Jun 2023
                    • 17
                    • US
                    #89
                    I ordered some TSAL6200 diodes from AliExpress. If the diode is true to the specs it should do ok. I also have some nylon bolts coming to see if isolating the mounting will stop my lightning damage issue. It may take a year or two before I know if that resolved the issue. I'll try to remember to post an update on how that works out.
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • hobostove
                      Corsair RM1000e - Help identify 5VSB Zener diode
                      by hobostove
                      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                      There's a 22ohm resistor that's melted and open, but it still has the bands.
                      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                      It looks like the diode connects the source and drain of a TNY284...
                      03-27-2025, 02:25 PM
                    • nev1001
                      What zener diode might fix the sound on Maestro Mayhem gaming chair?
                      by nev1001
                      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                      I think an issue could be a zener diode (or capacitor) which has shorted out.
                      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                      04-17-2025, 05:09 PM
                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                      by sam_sam_sam
                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                      I bought this from an eBay seller but unfortunately they only had one
                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                      I bought three of from them to also make battery packs with this output power limit in mind
                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                      04-23-2025, 05:50 AM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
