Shorted resistor replacement
  • Welchs101
    • Sep 2008
    • 979
    Problem: I am trying to repair an LCD monitor and i came across a "shorted" resistor (see enclosed photo). I am trying to find a replacement resistor but i am having problems. From the color code (red, black, white, gold) the value of the resistor is 20000MegOhm........but this does not seem right. Seems to high.
    Am i reading it wrong?
    Could have resistor gotten "burned" and changed the colors?
    With a resistor that high why even have one in the circuit. YOu cant find a resistor with that high a value on digikey.
    Can anyone help?
  • Toasty
    • Jul 2007
    • 4171
    Re: Shorted resistor replacement
    Shorted resistor? No. Resistors go up in value.
    I'm guessing your reading 0.2Ω and thinking shorted. It's likely a 0.2Ω resistor and the silver band looks white. Red(2) - Black(0) - Silver(x.01) - Gold(5%)
    That also looks to be a carbon resistor, which is a no-no in modern electronics. Fire hazard. If that were truly burned-up, it would show it.
    Toast
    veritas odium parit
    • Welchs101
      • Sep 2008
      • 979
      Your correct. The resistor does measure 0.2ohm.
      But from the picture the "white" band sure does look white.......doesnt it?
      Thanks. What you have said makes sense. Guess i keep looking for something else to be the problem.
      • Harvey
        • Apr 2007
        • 264
        Could be a choke, the colour codes seems the wrong way for a resistor..
        • Agent24
          I see dead caps
          • Oct 2007
          • 5008
          • New Zealand
          That looks like a really old style resistor, especially for an LCD.
          Is the board marked with anything underneath to suggest if it's a resistor or choke?
          -David VanHorn
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • harp
            high voltage high resistance marking resistor
            by harp
            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
            08-26-2024, 01:42 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • OOF DIO
            ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
            by OOF DIO
            (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
            (Had 3 problems, now just 1)
            I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
            I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
            I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
            04-19-2025, 05:03 PM
          • socketa
            A Shorted wirewound resistor?
            by socketa
            This resistor is from an ATX APFC PSU that connects bridge rectifier negative to primary capacitor negative
            I think that it's a current sensing resistor for the APFC
            Is it correct that it's color code indicates that it should be 0.47 ohms?
            I measured it to be around 0.08 oms
            The PSU blew up (visible arc flash) after problems with a powerstrip, but i got it working now after replacing the 10A fuse, rectifier, etc and removing/shorting the APFC diode locations and using a jumper in place of this PFC current sensing resistor
            I don't think that APFC likes being connected...
            05-15-2022, 04:50 PM
