Remote pump control ideas.
    • 31248
    Re: Remote pump control ideas.
    so use fixed i.p.
    or set the lease timeout to a month or something
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #222
      Originally posted by stj
      so use fixed i.p.
      I will try that too - it's just a speculation ATM. I'll have to ask my buddy to teach me how to dig through libraries to work out stuff like that. A debugger would really help, that's why meanwhile I'm trying to work out how to do it the "official" way, as opposed to using Arduino's IDE...this is where it gets complicated and requires a lot of time to work out sadly
      Wattevah...
        • 31248
        run the ethernet through a pc and run Linux and Wireshark.
        https://www.wireshark.org/
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          #224
          So as to see what's being transmitted ?
          Wattevah...
            • 31248
            yes, and what the response is.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #226
              I don't have the latest code my buddy worked with - it's on his laptop at work where the boards are currently chillin'. I set up a baby monitor camera to watch them over the weekend, that's how I know what they're currently up to
              Ok, get this: the client managed to somehow get itself unstuck and actually shut off the output to the relay like it's supposed to, to keep the place from flooding if it loses connectivity. There's an LED on the relay which I can see on the camera, in case you're curious how I know that. No idea why it happened after so many damn hours though and where it got stuck...
              Moving past that, it's like the client's currently got no network cable plugged into it, because it's stuck in the "errBeep" loop. Again, this will all be easier to follow once I actually show you guys some code, but my buddy and I created an errBeep function to have some feedback. Basically it's a bunch of calls to tone() and noTone() to make that buzzer sound like a PC POST code when it fails to detect a GPU or memory - some pattern like that. In this case, it's calling the errBeep function because it can't get through to the server board next to it.
              The reason I say it's like it's got no cable plugged in is because of how fast the errBeep function is looping, which happens if the board's got no IP to work with, such as when the cable's not plugged in. If the cable IS plugged in and it HAS an IP but still can't connect to the server, the errBeep function loops more slowly, at around 10s intervals, because the client.Connect(server, port) function hangs for a while trying to do its thing and THEN calls errBeep function if it returns false (fails). Then it tries again - halts for a few seconds - fails again - calls errBeep.
              I think the board is somehow smart enough to know there's no network to work with and immediately returns a false on client.Connect(server, port) function, hence calling my errBeep in rapid succession. We were aware of this and it's a good side-effect. Still, no idea what's happening in the background right now. This is where a debugger would be really handy, though I'm not sure how easy it will be to port this code of ours (good or bad) over to STM32 Cube IDE.
              Wattevah...
                • 31248
                set a fixed i.p. for both ends.
                then you can remotley ping them to check for life.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #228
                  I'll try that too, to at least check if it's a DHCP issue or something wrong within the code. For instance, through experimenting, me and my buddy discovered some time ago that you're supposed to handle disconnecting the client from the server after each "poll" in a rather specific way, otherwise the same exact thing happens - code freezes to the point where it no longer PINGS. It seems where you call the client.stop() function on both the server and the client is critical to this. He found a combination which sort-of works now, which is running on the boards right now, but apparently something is still crashing...we won't know for sure if it's this or something else, or it wasn't related to this at all this whole time....
                  Wattevah...
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    #229
                    Originally posted by redwire
                    Suppressing arcing at the motor contactor is expensive and hard to do. It's a big motor and nasty high voltages there. Not really feasible. Best is to keep the MCU away from it, or in a metal box.
                    There is alternative. Using SSR or Tyristor. But these are much more expensive than a relay.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      #230
                      Yeah, that's way beyond the scope of this project at this point - we're still struggling to get the control side out of the way...
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        #231
                        The randomness continues: woke up today, checked my camera, client was connected and relay output was on....go figure. It somehow managed to get through....after like 10+ hours for some reason...
                        Wattevah...
                        • tmhobadcap
                          Pioneer VSX-522-K remote control not working???
                          by tmhobadcap
                          I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                          At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                          12-24-2020, 01:44 AM
                          HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
                          This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                          09-06-2024, 06:50 AM
                        • piipo
                          Old Privileg 5.1 speakers remote control question
                          by piipo
                          Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                          09-18-2024, 01:55 AM
                          HP mt44 Mobile Thin Client Mobile thin client Specification for Upgrade or Repair
                          This specification for the HP mt44 Mobile Thin Client Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client boardview and mt44 Mobile Thin Client schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
