Why Electricity is on Ground?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Dear members,
    I have got a mainboard belonging to Dell inspiron n5010 laptop.
    I discovered there is electricity on the ground plane on this mainboard.
    Whenever the power is connected, if I touch the mainboard's ground by my finger, I feel a bit of electricity.
    What component is defective that caused this?
    How to solve it?
    Photos of the mainboard:
    https://www.badcaps.net/forum/showpo...6&postcount=37
    Re: Why Electricity is on Ground?
    How about if you touch any metal part of the laptop, do you get the shock?
    Did you verify that you AC adapter is safe and it is the original power supply? Does it use 3-prong plug?
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      Only metal parts that are connected to the mainboard's ground have electricity. For example, CPU's heatsink.
      The AC adapter is the original one with 3 wires: 19v, Ground, and ID.
      The 19v seems stable. No point on the mainboard seems shorted.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        I observed the ground-electricity problem just in one day. Today, I observed there is no electricity on Ground.
        What can cause the ground-electricity problem in a mainboard?
        Can it be discovered by looking for short on the mainboard?
          • 31007
          if the psu uses a 3pin mains cord, your house has bad earth - or the charger/cord has a bad connection.
          if your psu has a 2pin mains input then it's normal.
          • Mirenia
            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
            by Mirenia
            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
            03-30-2025, 06:47 AM
          • Sraros
            DELL P2217H power issue
            by Sraros
            I have two identical Dell monitors P2217H that don't power on. I took the PSU and mainboards out and connected them on another monitor. Connecting just the PSUs on the third monitor (with similar mainboard) and the monitor worked fine. So both have an issue on the mainboards.
            It seems the 19V rails on both mainboards have a short. Pins 5-6 are the 19V rail, 3-4 is ground, 1-2 is DIM and PWN_ON/OFF
            I circled the caps in green where the short appears. It would be helpful if someone can indicate a suspect or a way to figure it out....
            10-14-2024, 03:47 AM
          • b4hr4m
            Vizio D50u-D1 Mainboard 12v short to ground
            by b4hr4m
            So the tv all of the sudden showed some vertical lines. I turned it off and on again and no picture, no backlight, only sound. It turns on and off by itself.
            I tried to do some diagnostices and traced down the problem all the way to the mainboard. There is no 12v present on tcon connector. One of the coil is shorted to the ground if I'm not wrong (0.011v in diode mode and 7.8 ohm)
            I don't know if it's just one of those caps next to the coil or something major....
            05-04-2021, 08:28 PM
          • Devonavar
            Vizio M43-C1 - How closely do I need to match the mainboard number?
            by Devonavar
            I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
            I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
            Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
            So, I've ruled out the PSU for now.
            The reboot loop...
            08-14-2022, 08:46 PM
          • Malva
            Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
            by Malva
            I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
            Mainboard model: EAX65684604
            PCB marking: EBT62954607
            SPI chip: Winbond W25X20CLNIG Problem description:
            Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
            After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
            • I bought another
            06-25-2025, 02:07 PM
