DELL P2217H power issue
  • Sraros
    • Jan 2017
    • 223
    • Greece
    I have two identical Dell monitors P2217H that don't power on. I took the PSU and mainboards out and connected them on another monitor. Connecting just the PSUs on the third monitor (with similar mainboard) and the monitor worked fine. So both have an issue on the mainboards.
    It seems the 19V rails on both mainboards have a short. Pins 5-6 are the 19V rail, 3-4 is ground, 1-2 is DIM and PWN_ON/OFF
    I circled the caps in green where the short appears. It would be helpful if someone can indicate a suspect or a way to figure it out.
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Update
    I removed the caps to elimilate at least this one and found a short cap pointed with the red arrow.
    Now the screen powers on, I have the Dell logo for half a second displayed but then the LEDS shut off. I still have power on the monitor though and I can switch on and off the monitor.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Depending what tools you got on hand. My first go to would be to inject power into the shorted voltage rail with a CV/CC bench PSU. Feed power and see what gets warm by dousing 99% IPA on suspects and see which one bubbles.
      Other method is something that can measure minuscule amount of resistance like a micro ohm meter or Leakseeker89.
      Third option is to depopulate the board until the short is gone.
      • Sraros
        • Jan 2017
        • 223
        • Greece
        Thank you for the suggestions. I think your message came right on the same time when I removed the shorted cap.
        So, after removing the shorted cap. The mainboard worked as I said previously by swapping it to a similar Dell monitor.
        Then regarding the LEDs: I changed the BL managing chip with another one I had available, MP3375. This chip needs at R864 a 0 Ohm resistor and now the monitor works just fine!
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Perfect! Another one saved from the bin!
          • keepread
            Dell monitor PSU vs Dell laptop PSU
            by keepread
            Hi there!
            Someone gave me their old monitor, it's Dell S2715ht.
            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
            10-30-2025, 04:45 PM
          • thinkcentre
            Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
            by thinkcentre
            this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
            What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
            I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
            11-09-2025, 12:39 PM
          • SuperJames
            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
            by SuperJames
            This one's a weird one, and still unsolved despite it having gone back to Dell once.
            Specs
            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
            Backstory
            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
            10-23-2023, 04:09 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
