Dimmable LED incandescent replacements
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Has anyone had success using dimmable LED replacement bulbs? Which brand(s) and which dimmer(s)?
    Despite using "recommended" (by lamp manufacturer) dimmers, we seem to end up with low frequency (~2-3Hz) flicker at certain intensity levels.
    We're using 2 x 75W BR20's for the "problem" currently -- wanting to increase to 10 on that branch circuit (dimmer rated at 600W so it is currently only operating at ~5% load capacity)
    • Jul 2011
    • 6037
    Re: Dimmable LED incandescent replacements
    This is very hard to find a good quality LED bulbs that are dimmable
    The dimmer are pretty much the same story
    With out building one your self this about only thing that I can tell you at this point
    I have wanted to this myself but I have not figured out or found a ready made solution
    Now you can find ready made LED switching power supply but I have so far not found one that has the dimmer build into it
    Now you can find the dimmers and I have not tried them yet either because I do not know how many LED I want to run and what wattage and so on
    Now if this is a project that you would like to work on I might be able to put some input into and do some testing as well
    I have use some PWM power supply on LED before and the results were not bad but you could not dim all the down maybe down to 10 to 15 percent and this just a guess
    What I might try use is some capacitors on the output to smooth out the pluses which might work I did this on a PWM Servo value ( because it was hunting ) ( still in use today) and the results were pretty good for this application approach but weather this would work on some LEDs lights this is a hole another story
    I will have give this a try and see if this approach will work on LEDs lights or not
    *** How easy it to find the PWM signal in this dimmer device ***
    *** Is the PWM signal being done with a micro controller ***
    ***Or is it being done with a PWM ic chip and if so which one ***
    *** Or is this being done in the switching power supply to adjust the voltage output or current output ***
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      This is very hard to find a good quality LED bulbs that are dimmable. The dimmer are pretty much the same story
      I think the bulbs are the bigger part of the problem. They've already got "smarts" to figure out how to drive the LEDs off of the AC signal so need a way to sort out when that "AC" has been modulated (by the dimmer) and make sense of it.
      We've some bulbs that dim rather nicely -- but, at certain points, flicker at several Hz. This is just outright annoying.
      And, the RFI of others have made OTA radio reception impractical.
      That wouldn't work for "bulbs" that are intended to be powered off the (dimmed) AC mains.
      I have "bare diodes" that I can dim nicely with an adjustable powersupply. But, those have dedicated wiring; the bulbs that I'm interested in dimming are "general area lighting" and I've no desire to rewire the house just to support a bastardized scheme to drive them.
      We'd replaced branch circuits driving hundreds of watts of incandescents with LED "bulbs" (A19's). If you can drive an incandescent lamp, you can typically drive 5 or 6 times as many "equivalent watts" of LED lamps with the same dimmer.
      CFLs are even worse -- more like 50%. We have LOTS of incandescents that we regularly dim to "minimum" which gives just enough light for "sleepytime eyes" to see what's in the room (when overnight visitors wake, they can find their way around without having to turn the lights "on"). But, they are dim enough that eyes that haven't yet adjusted to the darkness can't see...
      For CFLs, this is laughable.
      The dimmer is just mangling the AC mains as it would for an incandescent bulb. The LED driver is encased within the COTS LED (incandescent replacement) "bulbs"
      • diif
        • Feb 2014
        • 6978
        • England
        I'm dimming cheap no name GU10 3x1W bulbs here. I had to buy a special type of dimmer for them so there was no buzzing.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          That's probably because most AC dimmers, act like a run-of-the-mill UPS inverter. You will hear buzzing much like CRTs on a cheap UPS inverter.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          "”Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mí mismo
            Great Sage é½Šå¤©å¤§č–
            • 30983
            no, it's because regular dimmers have a big choke in them and mains is in the audio-spectrum
            • delaware74b
              • Apr 2009
              • 628
              Dimmable LED lamps are an ever-changing technology. Few lamps are the same in 2 years from today.
              I have found a series of dimmers that have reliably worked with these lamps. The Lutron CL-series dimmers appear to work with 90% of the line-voltage dimmable LED lamps. These dimmers are a hybrid which handle 600 watts incandescent/halogen and 150 watts LED or compact fluorescent (remember those things). There are also higher wattage units available but you won't find them at big blue or big orange - special order at an electrical supply house and $$$$$
              Stupidity should be a crime, especially for drivers. I have NO patience for them.
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                That's what we have. The problem doesn't appear to be IN the dimmer but, rather, in how the lamp handles a certain "operating point" -- they dim linearly to a very low level. But, just before reaching 100% ON, enter a narrow region where they flicker very visibly.
                Note that none of our applications would ever see 150W of LED load (most lamps on a circuit is 8 and figure ~12W each, max)
                I may try swapping out the dimmer (we have lots of them, here) to see if that changes anything. It's obvious that the lamps behave identically so changing them would likely be ineffective.
                  • Jul 2011
                  • 6037
                  If they are incandescent lamp dimmers then that might be the problem because of the way they are made for incandescent lamps unless dimmer made really bad you would not notice it but with LED lamps you would notice it
                  One other note I have taken apart LED lamps before and a lot of ones I have taken apart the switching power supply are crap
                  I have also seen that a lot of LED modules are also crappy made as well if you try slowly bring the voltage ( powering from a bench power supply) they will flicker until you bring up the minimum voltage up for all the LEDs to light then everything good after that
                  The LED modules run on a voltage from 24 volt to sometimes over 60 volts if you happen to find some 48 volt LED modules the switching power supply are easily found on EBAY
                  The biggest problem is finding good quality LED modules and I have been having a lot of trouble finding good quality LED modules with out paying an arm and a leg for them
                  • tester272001
                    • 91
                    I have had allot of success with Feit brand dimmable LED retrofits. The color temperature is always less yellow than incandescent but acceptable.
                    • CG2
                      LED uplighter dimmer burnt resistor
                      by CG2
                      I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                      02-14-2024, 09:23 AM
                    • caphair
                      Christmas lights string keep blowing
                      by caphair
                      I have a series-parallel incandescent style Christmas lights. The first string has gone out, I find a blown bulbs. The bulbs are rated at 2.5v .425w.
                      The only other bulbs I have around are rated at 2.5 .2w. I tried replacing the .4w bulbs with the .2w and when plugged in, lights flashed momentarily then went out again.
                      I now find that other .4w bulbs have blown and the .2w seems ok.
                      Could this have happened because of mixing the wattage? I figured the .2w replacement would have been brighter and the rest a little dimmer but still working.
                      12-22-2020, 07:25 AM
                    • slybunda
                      Gemcon capacitor replacements?
                      by slybunda
                      taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                      there are 2 caps which im looking to get replacements for.
                      Branded as Gemcon
                      single 100uf 16v 6.5mm x 11.5mm
                      single 100uf 50v 8mm x 11.5mm
                      lead spacing is around 3mm
                      there is space for 16mm tall caps
                      rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                      the caps have...
                      02-05-2024, 03:36 PM
                      How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                      by sam_sam_sam
                      About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                      Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                      12-14-2023, 07:45 PM
                    • burom
                      Xbox 360 Xenon Modern Capacitor Replacements
                      by burom
                      I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                      I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                      06-07-2024, 05:10 PM
