Christmas lights string keep blowing
  • caphair
    • Nov 2011
    • 1249
    I have a series-parallel incandescent style Christmas lights. The first string has gone out, I find a blown bulbs. The bulbs are rated at 2.5v .425w.
    The only other bulbs I have around are rated at 2.5 .2w. I tried replacing the .4w bulbs with the .2w and when plugged in, lights flashed momentarily then went out again.
    I now find that other .4w bulbs have blown and the .2w seems ok.
    Could this have happened because of mixing the wattage? I figured the .2w replacement would have been brighter and the rest a little dimmer but still working.
    Mixed bulbs issue or wiring?
    • 31283
    Re: Christmas lights string keep blowing
    sounds about normal having to replace upto 6 lamps to get it running
    • caphair
      • Nov 2011
      • 1249
      Lol so mixing different wattage bulbs didn’t cause others to blow just a coincidence? Every time I replace found blown ones it keeps blowing again
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        Now that I think of it, it is sort of a coincidence that had cause. It wasn't the different wattage bulbs, but rather the fact a lamp blew in the first place.
        Remember all the bulbs in the string had the same MTBF from the factory so it's not unexpected a lot will blow around the same time so to speak...
          • 31283
          the biggest problem was the "self shorting" lamps designed to not blackout the whole string when they fail.
          every failed lamp causes an increase in power to the remaining ones.
          couple that with lazy people who dont fix it until several lamps are out and you see the issue.
          • caphair
            • Nov 2011
            • 1249
            So would have to keep replacing the ones that blow every time I power it on or just replace them all at once lol
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              trouble too, can't see all the bad bulbs until one burns out on the side you see all the time...
              I guess it's a good reason to throw out the whole string every season... or maybe flasher bulbs slightly increases useful life?
              • caphair
                • Nov 2011
                • 1249
                Yeah it sucks I was testing in continuity mode a lot of them.
                So mixing different wattage bulbs is ok to do? Granted it might affect brightness but it wouldn’t cause other bulbs to burn out?
                I have tons of the .2w bulbs and none of the .4w. I have to swap out the plastic bases to make them fit into the strings
                  master hoarder
                  • May 2008
                  • 12175
                  Make a test jig so that you can test each individual bulb quickly.
                  Basically, take a socket that fits these bulbs and give it 2.5V from an adjustable power supply. Then take each bulb that appears dead and plug it in. If it lights up, it's good. If not, junk it.
                  That said, if you don't have an adjustable PSU to give 2.5V easily, then use a 5V adapter and connect 4x 100-Ohm 1/4 or 1/2 Watt resistors in parallel (or, alternatively, just use a single 25-Ohm 1 Watt resistor). Connect the parallel resistors in series with the socket for the 2.5V bulb. This should allow up to around 0.25 Watts to pass to the bulb @ 2.5V, so both the 0.2 Watt and 0.4 Watt bulbs should be able to light up and show if they are working or not.
                  Yeah, unfortunately these things are too cheaply made to be worthwhile to repair (unless you are really bored or curious to do so.) Pretty wasteful when you think about it. I told my family to stop buying this junk long time ago. We still keep a few good strings that are better-made. (And some of the LED ones without any control circuits are actually quite decent.) But other than that, if they break, I just scrap them for parts (wires, plugs, and etc.)
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3266
                    • Singapore
                    i see this is more corner cutting and planned obsolescence. they want u to keep buying a new led light strip from them every year during christmas to keep them in business! haha!
                    good call from momaka calling them out! and asking his family to stop buying those! lol! i'd do the same too!
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • Francesc V.
                      Christmas lights - Something I am doing wrong
                      by Francesc V.
                      Hi:
                      i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                      I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                      If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                      Could...
                      03-11-2023, 07:38 AM
                    • edugimeno
                      Diagnose real-vintage Strong-Hammer arcade machine
                      by edugimeno
                      Hi there!
                      My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                      I am attaching several pictures of the machine.
                      It basically has 2 sides, left side has
                      • 2 x 220->12+24v transformers
                      • 2 relays (1 moves motor UP, other moves motor DOWN)
                      • IGF and breakers for safety
                      Right side is shown on pictures. It has 3 boards ( top-down)
                      • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                      02-29-2024, 11:05 AM
                      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                      12-14-2023, 07:45 PM
                    • bialag
                      Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                      by bialag
                      I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                      Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                      03-25-2025, 05:56 PM
