Repairing a heater wire in a toaster.
  • sigmeyer
    • Feb 2020
    • 147
    • Serbia
    First of all i just wanna say i love posting on this website and i get alot of useful feedback doing so , i just wish i could do it more often...
    Okay , so i am currently doing nothing because of the corona outbreak thing and i was trying to repair a cheap toaster that i have...And unfortunately it is just as i thought , the heater is broken. And i was wondering what can i do about this? So here is what i tried so far
    I have dissasembled an old chinese soldering iron and i took the heater wire from it to try reconnect the broken heater wire... and it worked untill the wire melted and right back at the same problem ... however i was thinking of putting extra strings of wire when connecting them and it seemed to bypass that part of a heater without even heating up the wire i put... not sure how long this is gonna last.
    Any thoughts on this?
  • sigmeyer
    • Feb 2020
    • 147
    • Serbia
    Re: Repairing a heater wire in a toaster.
    Also the heater wire is just 1 big continuous heater ... No seperate ones , so if there is just one break , the whole toaster stops working.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      best to use a new element ...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        If you insist on repairing, you have to crimp. You're probably better off using the same gauge heater element but if all else fails, just jumperring with a short piece of copper wire will do. No heat there but the rest of the heater will work.
        However unless the heater element was mechanically damaged, the heater may pop somewhere else soon, likely the heater is near end of service life...
        • sigmeyer
          • Feb 2020
          • 147
          • Serbia
          Yeah , i used a large wire gauge to connect it ..it worked like that for a day and it failed, i just thing its interesting that its not the wire that burns ... but the heater itself just burns at the end of connections.Im thinking that the connection surface is way too small so the heater burns out at the very place it touches the copper wire. I wonder if crimping it would make any difference... BTW the heater is just some flat piece of wire maybe half a centimeter wide.
          If i were to crimp the wires how would i do that without those crimp connectors?
          • sigmeyer
            • Feb 2020
            • 147
            • Serbia
            Im sorta thinking of just scraping it for spare parts if nothing else..
            • R_J
              • 9535
              I repaired one a long time ago, I made a small ferrell about a quarter to half inch long out of thin tin that fit over the element and used that to crimp the broken element together.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Yes it needs to be crimped together with a proper crimp connector and needs to be done properly. Twisting the wires together will not do, and obviously not soldering. Ideally it needs to be welded together, and a good crimp will be just about as effective as a weld.
                • sigmeyer
                  • Feb 2020
                  • 147
                  • Serbia
                  Thanks for the suggestion , i will try this one out.
                  I would like to learn how to weld but dont have the machine.
                  I have some scrap metal laying around and will definitely try this...Never repaired a heater before so this will be the first one. thanks again. I dont have a crimping tool either so im just gonna try to do it with pliers.. Will upload some pics for you guys to tell me what you think.
                    • Jul 2011
                    • 6037
                    If you have a high current transformer ( 5 amp or more - more would be be better ) and a couple of nails you could weld them together but you have to have a way to turn off transformer power for this to work
                    You have to leave it connected long enough for the metal to glow a little bit
                    If you have a battery spot welder it would be easier to do
                    • sigmeyer
                      • Feb 2020
                      • 147
                      • Serbia
                      so here it is my crimp job... seems to be doing good .. i tested it 3 times at full settings and no problem ... the large aluminium piece seems to dissipate heat at that weak point... so i think this toaster will be good untill the heater fails somewhere else. Thanks again for the suggestion R_J great call
                      Um i was actually thinking of buying a cheap welding machine... dont have big transformers laying around...
                        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                        by sam_sam_sam
                        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                        12-16-2023, 08:39 PM
                      • emeskay
                        Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                        by emeskay
                        We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                        08-06-2024, 07:13 AM
                      • mar1in
                        Fix broken tinsel wire on Speaker
                        by mar1in
                        I've saved a pair of Philips AH 495 speakers from landfill and diagnosed the woofers are not working due to a loose or broken tinsel wire just on the joint of the cone (left wire on the picture)
                        What's the best and easiest way to fix this without damaging the cone ?
                        Can this be simple soldered on?...
                        10-12-2023, 05:07 PM
                      • edugimeno
                        Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                        by edugimeno
                        Hi!!
                        Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                        I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                        At a certain point, moving stuff around, I put all wires back in place and...
                        03-24-2024, 02:31 PM
                      • madan1
                        Diesel heater emergency power supply / poor man's UPS
                        by madan1
                        Hello everyone.
                        Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                        12-18-2022, 08:05 PM
