Re: Ender 3D Printer but I am having problems with software help need
Interesting, I've gotten many 3D prints (FDM) that are actually water tight... Also got a few that were not. Depends on a lot of things.
I've mostly used Cura as it seems to do better (though not perfect) with the particular printer I'm using. Slic3r doesn't have a direct profile and people don't seem to care about it anymore in favor of the fork Prusaslicer instead :-(
Heh. 3d printers have a "bed" which has limited dimensions. My printer can get roughly 125x125x125mm. If a part is thin enough, you can print it diagonally and get more length, bot not many things are skinny and long. So it's a printer limitation, not a bench size limitation, though my bench is a bit limited also.
[I'm more interested in playing with their laser cutter, presently, as I have some panels that I need to fabricate -- with odd shaped holes]
As for as relocating the brick, I wanted it in the power supply to give it some weight.
I also can't stand cords everywhere.
There are plenty of benchtop power supply designs up on thingiverse with a remote brick. Plus, I have a bunch of these power supplies with broken cords. To fix them you pretty much have to break the case, and get a proprietary jack from china.
3d printers are great for making custom mounting straps and hanging things. I have made a bunch of one-off hangers.
It's true, I'm jealous of your rack mountable power supply. You know you can get rack rails pretty cheap, right? I bought a pair of these recently, they don't look quite 1/8" thick, but they are close. Definitely strong. I'd have no problem putting a rack in underneath my bench.
The two towers are Z800 workstations -- each has a dedicated UPS (though the UPS for the one on the left is elsewhere on the floor having its battery replaced). The large UPS on the left powers the three disk shelfs located just to the right of it. Cardboard boxes are spare disks -- you'll find them littered around the place (hoping to get this cleaned up before the next millenium!)
The cables hanging from the underside of the bench (a beige set, a black set, and another beige set) are mouse+keyboard+video for three "headless" machines located atop the bench in those general areas. This makes it easy to hook up a keyboard and monitor without having to crawl behind stuff to access those connectors on the machines themselves. There's a "free" monitor with a long cable on a swing arm just off the right edge of the photo so I can tether it to any of the headless machines in the office (there are probably 10 such candidates).
Just off to the right -- beyond the extent of the bench -- is the office laserjet sitting atop a T5220 server. Which, in turn, sits atop two 12-drive SAS shelfs. There's a 16 port switch attached to the underside of the bench just above the rightmost UPS to handle the hosts on that side of the office.
The top of the bench has the three headless machines (pushed way back to barely be accessible), a keyboard/mouse, a pair of 30" monitors (that float above the headless machines -- which is why they are so inaccessible!), a surface pro 3 (acts as my music player for that side of the room), a B-size scanner and a bunch of sh*t ^H^H^H really neat stuff :-/
I could possibly fit a power supply atop the three shelfs in the center of the photo -- but, then I'd have to find a place to store the spare disks! (the space above the big UPS is verbotten as it gets warm and there are magnetic fields, there.
And, a real rack would take up more space (esp depth!) than just stacking the devices does. Though using slides would make it easier to service those devices (to service a "lower shelf", I have to unload the drives from each of the shelfs above -- else they are too heavy to lift --- and then move them OFF the lower shelf).
Remember, there are two more similar photos! (I've got way too much stuff!)
In regards to LED testing, how do those power supplies operate in regards to CC/CV mode? Is current always limited, or can you turn it off? Does voltage float if CC mode is enabled?
Do the dual banana plugs have a standard spacing? I searched and found one that was 14mm on center. That's an easy one to implement (I think)
Interesting idea. I think I'd rather the pot fail than be locked on high voltage, I'd have to see if that makes the buck converter go high or low.
Or, ensure you don't have anything valuable connected to the supply WHILE you are adjusting it!
On a schematic, you will often see a pot (that is being used as a variable resistor, not a divider) with the "unused" end tied back to the wiper. Keep in mind that you put mechanical stress on it when you adjust it (think about trim pots that aren't designed for much use!)
BTW, I have seen some mention of being able to gang up power supplies if they have a ground plug. Do you know what the ground plug is connected to? Wall ground? Something else?[/QUOTE]
I think much depends on the design of the power supply. Some will share current. Others won't.
I tend to find a supply that is big enough for whatever job I have at hand (I have cartons of "bricks" to choose from).
I recently needed a BIG supply to power an electric wheelchair so pulled a pair of supplies out of a disk shelf -- ~80A+ at 12VDC -- and wired them in series to get the 24V I needed. But, they are designed with their "0V" signal tied to chassis/safety ground. So, I had to disassemble them to "float" their outputs
(else, tying the 12V output of the first supply to the 0V terminal of the second would effectively have tied the 12V of the first to the 0V of the second which is tied to the second's chassis ground which is tied, through the power cords, to the chassis ground of the first which is the 0V of the first! Ooops!)
But, that was a special use application and I'm willing to take the risks.Leave a comment:
As for as relocating the brick, I wanted it in the power supply to give it some weight. I also can't stand cords everywhere. There are plenty of benchtop power supply designs up on thingiverse with a remote brick. Plus, I have a bunch of these power supplies with broken cords. To fix them you pretty much have to break the case, and get a proprietary jack from china.
https://www.ebay.com/itm/10-Space-10...d/311660076356
I have some binding posts enroute from china, they actually look compatible with the current banana jack plugs. We'll see how they work.
https://www.ebay.com/itm/5-Pair-4mm-...d/372171948616
Thanks!Leave a comment:
I think the biggest heat sources, the power brick and the buck converter are far apart, still have plenty of airspace, and the case has a lot of volume compared to thier volumes.
I use this a ton, and the USB charger I added has been my charger of last resort. When nothing else will charge a device, that one will.
I am planning on making a v2 of the case, but I'm considering making it an advanced model with CC/CV control, digipots (control the buck converter), rotary encoders (super fine tuning), and USB control (integration with sigrok?). I'm only kicking around the idea right now and considering requirements, as I haven't actually used a nice power supply, so I don't know what they are or should be capable of.
Not sure if this is the exact same model as mine -- but it looks similar...
For example, I rescued a couple of 4ft LED light strips (illuminators). I was considering mounting these on the inside DOOR edges of the kitchen pantry so they would shine INTO the pantry and illuminate ALL of the shelves (or, at least 4 ft of them!).
But, I had no idea as to how they were internally wired (everything was potted) to even make a guess as to voltage, current, etc.).
So, I set the lab supply for 20mA (a "safe" LED current, in case the lamps were wired in series) and just kept trying higher voltages -- knowing that the current limit would protect me (and being cautious not to exceed any likely component ratings).
Then, once the lamps lit, I started watching where the voltage would show signs of being in the current limit condition to get an idea as to where they WANTED to be operated (ans: around 15VDC).
Likewise, if I am designing something, the lab supplies let me skip the power supply aspect, initially, and still have something to evaluate.
I'd snapped a pic of some binding posts to give you an idea as to what you (and sam) might want to consider, going forward. The smallest JACKS that I have are illustrated near the center of the image (I can't take pictures with this phone worth a damn; but, its more convenient than my iPhone or any of my "digital cameras")
Note the yellow one in the center adjacent to a blue "binding post". I've aligned the two of them based on their "seating surface" (front of enclosure). You can see that they protrude roughly the same amount into the case. I was prepared to argue that you might want to opt for the binding posts, going forward.
But, I stumbled on the OTHER photos (scroll right) and see that your "cheapest smallest available on ebay" are a fair bit smaller than mine. So, disregard.
You may, however, consider the spacing of the jacks. I'm not sure you've ever seen dual banana PLUGS (see pic)? This would allow you to mate a specific cable to the box -- instead of two individual "test leads".
Finally, with your off-board pot (Vadj), consider tying the wiper to the "unused" end of the pot. In this way, if the wiper ever loses electrical contact INSIDE the pot, there will still be a fixed resistance between the two leads running off to your brick. I.e., it will be as if you'd suddenly turned the pot to one extreme (instead of the pot appearing to be removed from the circuit).
[At the very least, you should understand what MIGHT happen in your circuit if the pot fails in that way. Pots get dirty.]Leave a comment:
sam: Are you saying you want to print the case, or are you saying you want to design something similar? If you want to print the case, make sure your printer is calibrated properly. If you don't have a set of calipers, you reallly need to buy a pair. I use the older version of this one nearly every day.
https://www.harborfreight.com/6-in-d...per-63711.html
If you want to print the case, the hardest part is getting the parts.
If you want to design a case like that, download freecad and download the design file I provided. Go take a look, poke around. If you want to start using freecad, you will absolutely have to watch some youtube tutorials. My basic steps are, download models of the products used from grabcad.com, or model them in freecad. You can then use those models to determine fitup and also to cut mounting holes, etc. From there it's pretty much just making sure you don't have unprintable overhangs, etc.
CG: I really don't have any regrets on that design, I'm pretty happy with how it turned out. Space is at a premium, that model fits on my bed with maybe 2-3mm to spare. Maybe if I had more space, I'd have fit a fan, but I have been pleasantly surprised that at most, the supply gets only slightly warm. I think the biggest heat sources, the power brick and the buck converter are far apart, still have plenty of airspace, and the case has a lot of volume compared to thier volumes. So passive radiation seems to work really well. I have to get around to posting a new picture with an actual knob on the pot, it dresses it up quite a bit, really makes the product look finished. Otherwise, I took a long time, and it came out just how I wanted it to. Maybe I would have added an XT60 connector to get direct 19.5v out.
I am planning on making a v2 of the case, but I'm considering making it an advanced model with CC/CV control, digipots (control the buck converter), rotary encoders (super fine tuning), and USB control (integration with sigrok?). I'm only kicking around the idea right now and considering requirements, as I haven't actually used a nice power supply, so I don't know what they are or should be capable of.Leave a comment:
I going to side track this discussion a little bit and ask this question
How do I go about making an enclosure like this
https://www.thingiverse.com/thing:4126979
I'd also ask yourself whether you're looking for a "special" enclosure or just something to keep the guts from spilling around the bench each time you use it!
[In college, I had a buddy who would "air wire" all of his circuits (point-to-point), wrap the entire "ball" (it ALWAYS came out like a ball!) in TOILET PAPER and then gently stuff it into an appropriately sized coffee can. (!) A bit of masking tape on the front with a wax marker indicating what was inside.
And, unrelated to the enclosure (yet without looking into the circuit topology), I'd wonder if it would be relatively easy to add a programmable current limit? I have several "triple output" digitally programmed bench supplies that I often use -- simply because I can type in a voltage and/or current and use them as voltage sources or current sources (wanna drive an LED string? Figure out the minimum Vout that you'll need to excite the string, end-to-end. Then, type in current level you'd like to drive at. Apply load... voila! (you could set the current limit with a knob by monitoring the ACTUAL current being sourced while it is IN the limit condition)Last edited by Curious.George; 04-30-2020, 04:37 AM.Leave a comment:
https://www.thingiverse.com/thing:4126979Leave a comment:
I have been following this discussion and it has become very interesting
Yes it has become way of topic —>
But not really because it things to think about when doing a project of any kind but the more complicated it becomes the more thing you have to think aboutLast edited by sam_sam_sam; 04-30-2020, 04:00 AM.Leave a comment:
I don't think you could get printed parts to the quality you could show to potential customers. But it could be good to evaluate fit up, etc. If you could get a print high enough quality to show to customers, it would have to be SLA (or some other process that I'm not up on), and you would probably have to post-process it somehow.
But, if, for example, the lens was so hazy that you couldn't see the indicator behind it (or, perhaps, discern its color), then it would be hard to move ahead with formalizing that indicator choice in the HOPE of the production parts being "sufficiently better".
If I told you the production version would "weigh twice as much", you could get an idea as to whether that is "acceptable". If I told you it would cost twice as much, you could evaluate that price point in your mind (and wallet). Or, twice as big, etc.
But there are many qualities that are hard to quantify.
What's "twice as soft"? Or, hard? Or smooth? Rough? What does twice as COLD mean? Or HOT? Even if you could find a formal definition of these things (e.g., the Rockwell hardness scale), folks wouldn't be able to relate to it.
How do you say "this will be twice as clear"? (or, whatever) How do you relate to that? Or, twice as brittle/fragile/flexible?
<shrug> I'm going to just have to "try" and revise my strategy based on results. Maybe I'll be lucky. Maybe not.Leave a comment:
I don't think you could get printed parts to the quality you could show to potential customers. But it could be good to evaluate fit up, etc. If you could get a print high enough quality to show to customers, it would have to be SLA (or some other process that I'm not up on), and you would probably have to post-process it somehow.Leave a comment:
[quantities]
Yes. If you're making "lots", your costs are the cost of the mold plus the weight of the molded parts, regardless of size/shape/complexity.
What I really want to do is design the (molded) production parts -- but use 3D printing to get a "touchy-feely" prototype in low quantities (e.g., ~150 pieces).
But, before that, (hopefully) to get a pre-preliminary part by printing one or two, locally (e.g., a local printer or a Maker House). to see if they CAN be printed (what "material" problems I might encounter) as well as how good those 150 "purchased prints" might later be.
(i.e., if I couldn't get a clear lens, then why bother? "Pretend you can see through this" doesn't cut it!)Leave a comment:
Ah, well, that changes things!Leave a comment:
Yeah, I'm not sure the costs of injection molding make sense even at a few hundred pieces, which is why I haven't looked into it. I'd much rather get a metal casting setup, it would be sweet to be able to do "lost pla" casting. There are some reputable print farms out there, I'd check the cost of both for your run.Leave a comment:
Yes. There are very different constraints for injection molds vs. printing.
You can always do "anything" -- but, price tends to make things impractical.
I suspect I will have a bigger challenge with the injection molded parts because you have to arrange for the MOLD to "get out of the way" when you're done! It's REALLY costly if the mold has to have moving "cam slides" to allow it to wiggle out of the way as the part is extracted.
The other big practical problem is that your mold (which costs many kilodollars!) can be "held hostage" to tie you to a particular provider.
And, molds wear, with use. So, you have to make a projection at the onset as to how many pieces you want the mold to yield before it starts degrading (particularly important with small/precise parts).
<shrug> I just have to budget for Mulligans...Leave a comment:
Heh, well, for 3d printing, the main thing is overhangs, and how you don't want them. Things print on the plate and go up. You can't print on air, you can only print on lower layers. Ideally, you want no more than a 45degree angle overhang for perfect printing. Small overhangs aren't a big deal, but they often won't come out perfect. Bigger overhangs require "support" and generally don't come out great either.
Heh, well, for 3d printing, the main thing is overhangs, and how you don't want them. Things print on the plate and go up. You can't print on air, you can only print on lower layers. Ideally, you want no more than a 45degree angle overhang for perfect printing. Small overhangs aren't a big deal, but they often won't come out perfect. Bigger overhangs require "support" and generally don't come out great either. If you want an example, check this out. Download the STLs at take a look. Or load up freecad. The pieces are meant to print on the face and on the back.
This will be payback for all the times I scoffed at my MechE friends over their "obvious" design screwups!!Leave a comment:
Yeah, that's not a trivial task, just designing with one method alone offers limitiations and challenges.Leave a comment:
My approach (to my problem) is to build 3D models of the various bits and pieces involved and then "assemble" them to check for fit, clearance, etc.
What this won't tell me is if some portion of the printed part will be too weak to bear up to the forced deformation required to assemble the parts ("snap in"). It's nothing I've any first-hand experience with so its a crap shoot.
Likewise, if there's enough mechanical strength in places that need it to hold up, over time. E.g., the battery compartment doors on all of my PSP's break... coincidence?
I suspect I could do a finite element analysis but probably stanad a greater chance of screwing that up vs. just making some physical parts and "abusing them".
You would think that sending it out would result in someone who knew what they were doing and had good equipment, but it wasn't the case with mine.
E.g., I wouldn't think twice about trusting someone to make an oversized (feet by feet) print of a photograph for me, today. A decaded ago, I'd want to be in on the process to ensure it all went as planned.
Also keep in mind that you have to design for 3d printing. You can't just print any design, many will fail spectacularly. SLA is a bit more forgiving though. Anyway, if you want me to take a look, shoot me a PM. You probably don't want to post your design...
I have tools that address both approaches. It will just be a matter of "doing my homework" to make sure the criteria for one approach don't undermine the other...Leave a comment:
It wasn't the printer (entirely) that was wrong 7 times, it was mostly my design. Can't say I knew much about involute gears, and getting the size and shape exactly right was fun.
You would think that sending it out would result in someone who knew what they were doing and had good equipment, but it wasn't the case with mine. I suspect you might be able to get a decent print these days, the technology has advanced quite a bit since I put my order in. I was kind of embarrased for the print house, I bought my printer for $160 a few months later and within a month of buying it, I was getting better quality prints than they sold me.
Also keep in mind that you have to design for 3d printing. You can't just print any design, many will fail spectacularly. SLA is a bit more forgiving though. Anyway, if you want me to take a look, shoot me a PM. You probably don't want to post your design...Last edited by clearchris; 04-23-2020, 11:10 PM.Leave a comment:
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by Curious808SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
Brother HL-2140 laser printer
Windows 10
Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...06-22-2023, 11:11 PM -
by ArtefilHi,
One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
The screen displays the following message :
"a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
Have you ever...09-28-2023, 05:11 PM -
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by прямоHi all,
a friend gave me this printer because it's no longer working.
It powers on, but won't do a self-test print and when connected via USB to Windows, Device Manager says No Printer Attached under USB Hubs tree.
The red light doesn't blink either with no paper inside.
I think the firmware maybe corrupted. If someone has a similar printer and can provide a firmware dump, I really appreciate it.
Printer model: Panda PRJ-58U
Flash memory: Boyamicro BY25D16ASSIG4 Photos - Loading...
