Fluke 23 Fusible Resistor
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: Fluke 23 Fusible Resistor
    Mine is a Fluke 23 Series II see attached.
    So as the other components are reading open circuit, is there anything I can do to check that they are working? Without over risking more failures of course.
      Which component??
      • habanerocat
        • Nov 2014
        • 96
        • Ireland
        Originally posted by budm
        Which component??
        RJ1, RJ2 and E1, as in the attached input circuit.
          Many people already explain what those component are and what the reading should be when you measure the resistance, may be you just do not understand how those component function.
          See post 11 and 12.
          Do the research on MOV and SPARK GAP, you are lucky to have internet.
          • habanerocat
            • Nov 2014
            • 96
            • Ireland
            See post 11 and 12.
            Ok, I can see where you are coming from on this. I'm no expert for sure, but I was hoping that there might be some simple test to check the functionality of the other components. Would Fluke test these protection devices before shipping I wonder?
            They look good visually so I'll just leave well enough alone. Thanks for all yer help.
            • redwire
              • 3910
              Just a follow up- the 1k 2W Ohmite OY102KE resistor is huge... almost an inch.
              I think it's the smaller 1W OX102KE what is used in the Fluke multimeters? Brymen 867 also uses the 1W part, based on pics.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                The fusible resistor in the service manual is 2W.
                More info
                http://mrmodemhead.com/blog/fluke-87-fusible-resistor/
                --- begin sig file ---
                --- end sig file ---
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  I have just been watching a youtube channel im subscribed too he is trying too repair a fluke 73 not sure if any of you guys can offer him advice by posting in the youtube comments etc https://www.youtube.com/watch?v=Bt0V-tCwk30&t=0s
                  • jinu_j
                    by jinu_j
                    Hi
                    05-03-2025, 10:51 PM
                  • gica69
                    Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                    by gica69
                    I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                    Resistor shows orange range silver gold and green lines.
                    Thanks in adv...
                    07-21-2025, 09:49 PM
                  • bluto
                    Is this a fusible resistor?
                    by bluto
                    This is from the power supply of an LED shop light. The light went completely dead suddenly. I removed the SMPS board and it looked really good except for some bad solder joints. I touched all of them up but the light was still dead. I then found this open resistor that was between the neutral wire of the plug and the transformer. The color bands seem non-standard. Does it indicate 13 ohm, 30 ohm...? I am not sure. What should I replace this with?
                    07-01-2025, 01:30 PM
                  • mikey5791
                    Need help to replace burned resistor in 350w atx psu
                    by mikey5791
                    Hi to all forum members,
                    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                    12-26-2024, 04:55 AM
                  • MidnightRoller
                    Can a resistor lose resistance after hot air?
                    by MidnightRoller
                    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                    02-02-2022, 11:46 PM
