Is this a fusible resistor?
  • bluto
    • Oct 2007
    • 560
    This is from the power supply of an LED shop light. The light went completely dead suddenly. I removed the SMPS board and it looked really good except for some bad solder joints. I touched all of them up but the light was still dead. I then found this open resistor that was between the neutral wire of the plug and the transformer. The color bands seem non-standard. Does it indicate 13 ohm, 30 ohm...? I am not sure. What should I replace this with?
  • truclacicr
    • Apr 2019
    • 356
    • australia
    Scratch the middle of the body until you expose the resistance element. Then measure the resistance between the element and each lead. Hopefully one side will be intact.
    • bluto
      • Oct 2007
      • 560
      Hmm, I couldn't get a reading from either lead... But measuring the element from both sides measured around 1.5 ohms. So guess the official value is probably only 1 or 2 ohms?
      • truclacicr
        • Apr 2019
        • 356
        • australia
        1.5 ohms is a standard value, so it could be that.
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • gica69
          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
          by gica69
          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
          Resistor shows orange range silver gold and green lines.
          Thanks in adv...
          07-21-2025, 09:49 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
