Newb asks eye-rolling questions.
  • Kessler
    • Oct 2009
    • 6
    So after doing the software and basic hardware side of computer repair for years, I figure it's high time I learn how to properly replace those 2-3 bad caps rather than throwing an otherwise good board in the garbage.
    I'm in Canada and just ordered a Weller WES51 soldering station which should be here tuesday.
    1) That leaves me with 2 questions. What is the best multimeter for doing motherboard repair priced between $40-75. I've seen a few that measure capacitance but their upper limit is 200-400uf (which makes them pretty much usesless, correct?)
    2) If you were going to order $30 or so worth of caps to start off with, what would be a good all purpose selection of size and spec? I understand I can use a 1000uf to cover all the lower sizes but I'm still a little confused about voltages. Also, is width only a limitation when caps are close to each other?
    I'm learning so go easy on me The last electronics course I took was in grade 9 so I have no memory of it.
    I already have a good selection of solder, a desoldering pump and wire, picks etc. Anything else I'm missing??
  • i4004
    • Oct 2006
    • 2029
    Re: Newb asks eye-rolling questions.
    1. you wanna measure esr(ohms) and to that extent i would suggest esr micro
    contact this guy
    https://www.badcaps.net/forum/member.php?u=12802
    it's essentially rather simillar to atlas esr
    ( http://www.peakelec.co.uk/acatalog/jz_esr60.html ), but much, much cheaper
    offcourse, you can get anatek blue
    http://www.anatekcorp.com/blueesr.htm
    but it seems that with kits they have a tendency to misplace parts etc.
    also, it can't measure capacitance...
    either way, you need to know esr...
    • Kessler
      • Oct 2009
      • 6
      contact this guy
      So, can caps be tested on the board or do they have to be pulled? It seems to me that if I have already pulled the cap I'm going to be putting a new one on regardless.
      • Gianni
        • Jul 2008
        • 681
        • Italy
        You can measure caps on board but the measure is not accurate, especially when you have some caps in parallel.
        Of course if they are damaged (ESR out of spec) you can discover it easily with an ESR meter.
        Question 2: I don't believe you can cover all lower size with 1000uF, at least I will not replace a 220uF with 1000uF and some time you have not enough space.
        I have not recapped a large number of board, anyway in my little experience I have seen most common value are 1000uF 6.3-10V, 1500~3300uF 6.3-10V, 1000~2200uF 16V.
        If I were you I will buy caps based on the PSU or MOBO I have to recap.
        You can see some premade kit for some MOBO and get an idea of what type of caps are used.
        By the way you can buy caps from Topcat, the owner of Badcaps.
        Ciao
        Gianni
        "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
        H. J. Brown
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          To do it right you need:
          An ESR meter.
          A resistance meter.
          A capacitance meter.
          On the uF meter, 0-5000uF would be best. [Get those occasional tiny's and 4700uF that show up questionable.] At least something that can do 220uF to 3300uF because those are common.
          For ESR, low is good but there are some problems checking it.
          Very high grade caps have ESR below .01 and that's below the range of most ESR meters. [At least those that aren't 100's of $$.]
          In that case the meter might show ESR as Zero and everything is fine.
          - But Zero on an ESR meter would also show up if the cap is shorted, and that's bad.
          You need to check with a regular resistance meter too in order to be sure.
          ESR Ohms should be low and DC Ohms should be high [after the cap charges from the meter].
          The voltage marked on a cap is a limit like a load rating on a rope.
          It's okay to use higher volt caps in a circuit with a lower voltage just like it's okay to use a rope to lift less than it's rated weight.
          Be advised though that use of a cap on a lower voltage will effectively turn the cap into a lower voltage cap. This is because the thickness of the Oxide layer [which is the actual Dielectric in Electrolytic caps] will adjust in thickness based on the applied voltage. The technical term is "Re-formed", as in the layer is re-formed to a new thickness. [This only matters to people that salvage caps for re-use which in some parts of the world is the only way to get decent caps -and- is sometimes done temporarily to verify the board is worth buying replacement caps for.]
          If you only have $30 to throw at caps you are better off waiting to see what you need and then ordering them. [Yeah, waiting sux but so does having the wrong size in stock and having to order and wait anyway.]
          A cheapie multimeter [for DC Ohms anyway] is good enough for resistance checks or tracing circuits because you aren't looking for a specific number, just the gross condition. Open, short, high, low. - Doesn't have to be very precise, just correct.
          For PSU/Mobo voltage checks a basic non-junk one should do just fine.
          Should be good to at least +/- 0.1 VDC and +/- 0.01 VDC would be much better.
          Caps in parallel with other caps have to be pulled for ESR checks.
          For DC Ohms or uF checks they should be pulled.
          Yeah, I know the ESR meter ads say you don't have to pull caps but on motherboards that's usually bunk.
          Mann-Made Global Warming.
          - Dr Seuss
          • Kessler
            • Oct 2009
            • 6
            An ESR meter.
            A resistance meter.
            Very informative post, thanks!
            So if I grab an average multimeter that does resistance, and capacitance to at least 5000uF and an ESR meter, I'm set.
            • i4004
              • Oct 2006
              • 2029
              but where will you find multimeter that does up to 5000uF?
              usual range of cheap multmeters is up to 20uF.
              then you have much more expensive meters that do just capacitance, and which have enough range.
              offcourse, you also have esr micro that does both esr and capacitance for 55$..heh...
              http://preher-tech.com/esrmicro.aspx
              (that's older version, that was 45$)
              on top of that just a cheap multimeter, yeah.
              (offcourse, if you can find multimeter that does up to 5000uf more power to you!
              then indeed only it and esr meter)
              in that case you don't need any of above-mentioned instruments, right?
              <wink>
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • studdy05
                Bricked HP Probook 450 G7 Bios questions
                by studdy05
                Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                Ive got...
                Yesterday, 09:24 PM
              • UL161
                Need Help Identifying Parts on a crossover and a few other newbie questions
                by UL161
                Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
                1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
                2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
                09-29-2024, 03:17 PM
              • cloghin
                newbie questions
                by cloghin
                Apologies if I am asking the wrong questions , but not sure how else to start:
                I have an A2251 / 820-01949 Mac book pro with no power, 20 v on USBC meter and 0.05 Amps. Following this link ( below)
                * Do I need to remove the board from case so I can access its other side ? The link calls for measuring PP3v3_S5 ( I suppose this is in diode mode with positive probe on ground) , but I don't know how to do that without removing the board from case.
                * I have the FlexBV board , are the values displayed in volts diode mode only ? Because my etekcity multimeter shows...
                09-26-2024, 11:48 AM
              • KYBOSH
                Samsung UN50TU8000 - Dead Panel Forensic Questions
                by KYBOSH
                I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                Later I checked for shorts on the panel PCB boards but could not find anything.
                When I took a look with the FLIR i noticed the 2 resistors...
                08-10-2024, 08:39 AM
