how-to solder SMD capacitors
  • vtboy2k
    • Sep 2009
    Hi, I've been a long time reader of this forum but finally registered. I've just received a Toshiba laptop with bad SMD capacitors. Was wondering if there's any guide on how to desolder and solder in the SMD capacitors. There's a picture of the four silver capacitors I'm trying to replace in the following post (last post) here
    I have ordered the following Panasonic SMD capacitors .
    Thanks in advance.
  • Player2
    • Aug 2009
    • 98
    Re: how-to solder SMD capacitors
    The best way is to use a hot air station to heat up both leads and then pick it off with tweezers. If you don't have access to this, you can try alternately heating one side, pulling the cap up a little, heat other side, pull up a little, etc; but using this method it is very possible to peel or damage the traces.
    • Toasty
      • Jul 2007
      • 4171
      2 soldering irons and a helper to pick the cap off.
      veritas odium parit
      • Krankshaft
        • Jan 2007
        • 2328
        More soldering stations like the Hakkos also have tweezers to remove 2 lead components like this.
        These for the 936-937 models:
        http://hakkousa.com/detail.asp?PID=1265&Page=1
        This one for the FX-951:
        http://hakkousa.com/detail.asp?CID=&PID=2401&Page=2
        The alternate lead heating method always worked for me and I've never ripped a trace myself.
        Hot air is good as long as you control where you're applying it and don't apply it for too long otherwise you will do more harm than good to nearby components.
        • Toasty
          • Jul 2007
          • 4171
          Hakko's nice, but they're not for the occasional repairer/weekend warrior (unless you can't find enough ways to blow your cash). Just waaaaayy too much money. $200 for 2 soldering irons and a hinge???!! WOW!
          veritas odium parit
          • i4004
            • Oct 2006
            • 2029
            http://www.mcmelectronics.com/product/21-8230
            • Toasty
              • Jul 2007
              • 4171
              Now that's more like it! Nice catch.
              veritas odium parit
              • vtboy2k
                • Sep 2009
                hmm buying the soldering equipment does add up quite a bit. might have been cheaper if I had sent it to a repair shop
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Hey! Those are two temperature regulated irons and a hinge .
                  Some Hakko stuff you can find real cheap shipped from China got the 200 dollar (FG-100) tip temperature thermometer for 53 bucks shipped. I opened it up and checked it out it was 100% legit. It just shows you how much of a cut people get before it gets to your door.
                  Unless you're doing loads of SMT caps day after day then it's not worth it for a special tool. Heat one leg tilt heat the other.
                  Nice find on the Tenma tweezers I have their isolation transformer and HV probe they are both well built.
                  • Toasty
                    • Jul 2007
                    • 4171
                    >>Hey! Those are two temperature regulated irons and a hinge.<<
                    My bad.
                    >>Some Hakko stuff you can find real cheap shipped from China got the 200 dollar (FG-100) tip temperature thermometer for 53 bucks shipped.<<
                    Ahhh-soooo! You have Hong Kong Connection.
                    Pray tell! Dammit!
                    Toast
                    veritas odium parit
                    • i4004
                      • Oct 2006
                      • 2029
                      32$ for soldering tweezers is too much?
                      and if you don't want that(and already have soldering iron), then do what krank said
                      "Heat one leg tilt heat the other."
                      are you afraid you'll hurt that bad cap upon removal?
                      <wink>
                      also, there are alot of video gudes on youtube etc.
                      see
                      http://www.curiousinventor.com/guide..._Soldering/101
                      (see portion at 7'09'' at that video)
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        You'd probably get plowed with the hourly rate to replace these components and I can tell you it's going to be way more then 32 bucks or the cost of a soldering iron and solder.
                        From my experience most places are just going to try to sell you a new motherboard anyways. There are so many so called "techs" out there that are nothing more than module swappers.
                        • Tube_Dude
                          • Feb 2011
                          • 51
                          Hi Krankshaft
                          I got one of this too. I presume the multiturn pot is for calibration, but there is one another little trimmer too. Have any idea of the calibration process or what each trimmer does?
                          Thanks!
                          • dossman
                            • Feb 2011
                            • 35
                            This looks like something I could use, now all they need is a little vacuum cup that comes down and lifts the chip up.
                            • magicknees
                              • May 2011
                              One thing you'll need is a good way to see what you're doing. I have a stereo microscope (thanks to my last job going out of business sale) as well as a headgear magnifier. It is amazing when you can really see what you're doing how much easier it is. It is easy to see if you've had too much caffine too (you shake alot).
                              The head gear is cheap, $20 or so. My stereo microscope is worth $900 new. It is not for sale btw. I use it all the time. You can see bad solder joints and smd caps look like wooden blocks the kids play with. The soldering iron looks like a 6" log.
                              enjoy
                              • tronxkid
                                • Jun 2011
                                • 20
                                I use lots of low-end equipments and I find them quiet useful for sometimes. For your question the best answer I can give is to buy a cheap 50$ hot air station. KADA is a good low-end brand.
                                de soldering using soldering iron is a risky thing. too much heat and too much force can easily erase traces on the pcb.
                                • Longbow
                                  • Jun 2011
                                  • 623
                                  Undoubtedly, high tech soldering/desoldering equipment can make this job easier. I have never owned or used it however. Keep in mind that 50% of the SMD lead is underneath the part! Directing a hot air gun at the part can often desolder a number of nearby parts as well, and blow them off the board if the parts are small - like SMD resistors for example. You don't want that.
                                  Here is a method that worked well for me for SMD caps in most cases. Get yourself a some good flush cutters and cleanly clip off the cap as near to the bottom as possible (depending upon clearance, size, etc.) The cap will then come apart very easily with a little help from a dental tool at which point each leg can be desoldered individually. I found that this method avoided lots of broken and overheated traces and in general made the job possible. In many cases, the caps can leave electrolyte on the pc traces, which has to be cleaned off. It eats away the copper traces and worse, the electrolyte travels along the traces underneath the green coating, and may dissolve traces some distance away from the bad cap. Check continuity if in doubt.
                                  Is it plugged in?
                                  • Evil Lurker
                                    Warranty Voider
                                    • Feb 2011
                                    • 454
                                    I have taken an aluminum crimp terminal, filed the outer edges till somewhat sharp, then bent it to where it can heat both sides of a SMD simultaneously and mounted it on the end or my iron tip. Then I simply used a pair of tweezers to pick it up.
                                    I had thought about taking a pin and superglue the tip to the SMD, put a drop of water on it to instantly harden the glue, and remove the glue via the appropriate solvent.
                                    For resoldering use mechanics soldering paste, the kind where the solder has been ground or mixed up in the flux and then simply touch each side with your iron, or hit it with some hot air.
                                    • acedogblast
                                      by acedogblast
                                      11-02-2024, 05:13 PM
                                    • dragon3x
                                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                      by dragon3x
                                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                      power on.
                                      Here are some examples :
                                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                      switching supply area).
                                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                      than 6.3 V.)
                                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                      I replaced capacitors with aluminum-polymer.
                                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                      03-21-2025, 02:46 PM
                                    • corrize
                                      Best way to solder LVDS connector for beginner (and qfn) ?
                                      by corrize
                                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                      See the test :
                                      https://youtu.be/bNAzC-EvqHs?t=1767
                                      With hot air from bellow the board, that's...
                                      03-09-2023, 02:57 AM
                                    • slybunda
                                      AA and AAA battery charger capacitors?
                                      by slybunda
                                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                      it has inside:
                                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                      2 x 470uf 16v LZ105c branded as G.Luxon
                                      not heard of these brands are they any good?
                                      iv attached photos of the charger and the board inside for an idea on the type of...
                                      12-24-2023, 04:41 AM
                                    • petemanuk
                                      BGA solder balls not connecting - help pls
                                      by petemanuk
                                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                      11-16-2022, 05:21 AM
