Why does my Uni-T multimeter not measure anything?
  • antoniu200
    • Dec 2018
    • 47
    • Romania
    Hi! So, a couple of months ago, I got tired of me watching my movies and when someone flips a certain switch in the house, my Blu-Ray to stop working for a second, then come back on (the TV being fine, mind you, connected both at the same outlet). So, I took my multimeter (Uni-T UT33B) and tried to measure the voltage of my outlet when that switch is flipped. Dumb me, I set the multimeter for DC Voltage, while connecting the red cable to the Unfused connection. Of course, both the fuses in the multimeter and in my house blew.
    Now, I replaced the fuse in the multimeter, but it still doesn't measure anything. I'll link a video in Google Photos of how it behaves when I don't have anything connected. I suppose there is a short-circuit inside the multimeter somewhere.
    I'll also upload down below a photo of the board of the multimeter. If needed, I'll try and find a schematic of the board as well.
    Any advice on getting this back up and running? I don't want to spend money on another UT33B, rather I'd buy a better multimeter, but I don't want to spend that kind of money right now, as I'll soon need a serious laptop for Video Editing and Android Studio, and those are very expensive.
    The video: https://photos.app.goo.gl/uguwZCw7xSuwmTQu9
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Why does my Uni-T multimeter not measure anything?
    so you had it set up for amps then measured volts ? mmmm have done this to my meters in the past and gave up trying to fix and calibrate them .
    • antoniu200
      • Dec 2018
      • 47
      • Romania
      Well, I'd like to try my luck, as I might need that multimeter working soon. Here is a link to the schematic:
        • 31007
        take the board out and check for burned tracks near the sockets
        • antoniu200
          • Dec 2018
          • 47
          • Romania
          There are some burn marks at the joint of the socket with the board and with that big metal bridge, I'm not sure how to call it. You can see it in the pictures above. Can those marks cause the multimeter to malfunction?
            It is hard to see. May be the trace is blown up.
            • antoniu200
              • Dec 2018
              • 47
              • Romania
              I thought about that. However, I'm not sure that can cause a short circuit in the multimeter.
              I'll try and take a better photo of the burn tomorrow and upload it.
                If the trace from the probe receptacle is blown then the probe is no longer connected to the meter circuit.
                https://www.badcaps.net/forum/attach...1&d=1573479529
                You have 3 probe socket, what are each one since we cannot tell which is which because there is pictures of the front side of the meter, also no pictures of the other side of the board that we can see.
                • antoniu200
                  • Dec 2018
                  • 47
                  • Romania
                  From down to up: Common, Fused, Unfused.
                  Bottom is Common, Top in Unfised.
                  • R_J
                    • 9535
                    What makes you think there is a "short circuit" in the meter? Your video shows the meter working. When turned to 20MΩ it reads O.L that is normal, When turend to DCVoltage it reads 0.00 Volts which is correct without any "voltage" for it to measure. Have you tried it with the probes connected and placed in the Ω scale, short the probes and see what reading you get?
                    Like others have said, when you connected the meter in the "10 amp configuration" You would have likely vaporized the trace connecting the probe jacks to the circuit. That large wire bridge is the 10 amp current shunt for the meter You likely blew the trace connecting the common jack to the rest of the meter circuit
                    Was the black meter lead connected to the com jack when this happened? or was IT plugged into the VΩmA jack.
                    • antoniu200
                      • Dec 2018
                      • 47
                      • Romania
                      The black lead was in the Common jack. The read lead was in the Ampere (Unfused) jack. I tried to measure DV Voltage with that configuration in an AC 230V outlet.
                      So, where should I resolder the Common jack? Should I take a wire and solder the Common jack to the large wire? Would that be enough?
                      What made me think there is a short circuit in the meter is the rise in resistance when I select Ω and then quick drop to OL. Same goes for voltage: see how when I come from resistance it rises and then slowly drops?
                      • R_J
                        • 9535
                        NO. you should LOOK to see if there IS a blown trace. don't start adding jumper wires.
                        Have you tried placing the meter in Ω and check what resistance you get when you short the probes together? maybe the meter is working.
                        The way you had it connected, the large wire shunt was connected across the 10amp and COM jacks. That is what blew the house fuse. it was like connecting a wire across the house outlet. BANG
                        • antoniu200
                          • Dec 2018
                          • 47
                          • Romania
                          I did try that. It showed OL.
                          As for the blown trace, it's definitely seen some good black smoke. It could be blown, it could be fine. Not sure how to test that without another meter.
                          • R_J
                            • 9535
                            If the trace blew it would likely be in this area. Is this where the black smoke is? clean any black soot from the board and provide a clear picture of this area. The COM jack likely connects to the end of shunt wire and also to a trace that connects the COM to the meter common circuit
                            If you look at the schematic you will see that the COM connects to one ind of R14 (0.01Ω) this is the large wire shunt. It also connects to the comon ends of R17,R29 & R30.
                            • antoniu200
                              • Dec 2018
                              • 47
                              • Romania
                              Yes, that is exactly where the smoke is. I'll provide that photo tomorrow, as it's 00:29 right now where I live and at 06:20 I have to wake up.
                              • R_J
                                • 9535
                                The blown trace could also be on the other side of the board, it is a double side circuit board.
                                • antoniu200
                                  • Dec 2018
                                  • 47
                                  • Romania
                                  I'm pretty sure that trace is done-for.
                                  As for the other side, it looks fine.
                                  • R_J
                                    • 9535
                                    Yes, that trace is gone, so get a thin piece of wire and solder it between the COM and the wire shunt. Using a thin piece of wire would be better in case the mistake is made again. I suspect the meter will work fine after that.
                                    • antoniu200
                                      • Dec 2018
                                      • 47
                                      • Romania
                                      Originally posted by R_J
                                      Yes, that trace is gone, so get a thin piece of wire and solder it between the COM and the wire shunt. I suspect the meter will work fine after that.
                                      Thanks! After I do that, I'll report back.
                                      • antoniu200
                                        • Dec 2018
                                        • 47
                                        • Romania
                                        As promised, I'm reporting back. The multimeter is back up and running.
                                        Thanks to everyone who contributed!
                                        • madfreak
                                          Which multimeter to choose : BRYMEN BM 869S OR UNIT UT18B PRO ?
                                          by madfreak
                                          Hello, there were probably topics like this, but I need opinions about these 2 multimeters or maybe there is another one on the market worth to buy ? .
                                          I am going to change the multimeter and I do not know if the 2x higher price for Brymen will convert into speed and comfort of a work ...
                                          What would you recommend?
                                          Brymen BM869s or UNIT UT18B pro?
                                          I care about accuracy and security, and the meter will be used for computer hardware.
                                          Thank you very much in advance for your comments and suggestions
                                          04-30-2022, 01:10 AM
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • yayayee
                                          ASUS GU502GV not powering on - 1285A hot
                                          by yayayee
                                          I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                                          So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                                          I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                                          01-08-2024, 11:04 PM
                                        • nobbnobb1
                                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                          by nobbnobb1
                                          Hi guys,
                                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                          02-03-2022, 11:14 AM
