Simple Electronics?
  • keyboardcowboy
    • Apr 2006
    • 73
    Simple Electronics?
    i am pretty confused on this, suppose that i have a 6V DC motor that consumes lets say 5W (supposition),now what happens when i connect it through a resistor to the same 6V battery off course it will run slower due to the resistor but is the power requirement the same???..ie
    power absorbed by resistor+power absorbed by motor=power absorbed by motor without resistor
  • etnietering
    • Apr 2009
    • 379
    Re: Simple Electronics?
    Nope, it will be lower, because by adding the resistors you're increasing the overall resistance of the circuit.
    To find how much power draw there will be, you need to calculate the resistance of the motor. the power equation is Power = Current*Voltage. you know the power and the voltage, so you can calculate the current. In your example, you have 5w = I * 6v, so I = 5/6, or about 0.8333 amps. now that you know this, you can use the resistance equation Voltage = Current*Resistance to calculate the resistance of the motor. 6v = 0.8333 * R, so you get R = 7.2 ohms. Say you had a 4 ohm resistor you wanted to hook up in series with the motor, like you said. So then the resistance of the circuit would be the sum of the resistances, 7.2 + 4 = 11.2 ohms. So using the resistance equation again you can calculate the current: 6v = I * 11.2, and you get I = 0.536. then use the power equation to calculate the power draw: P = 0.536A * 6v, P = about 3.2W.
    Hope this helps!
    • PlainBill
      • Feb 2009
      • 7034
      Hope this helps!
      You math is impeccable, but there is one problem with your facts. You assume that the resistance of the motor is constant. This is not true in many cases. The current draw (resistance) of a motor will vary with load and speed.
      PlainBill
      • keyboardcowboy
        • Apr 2006
        • 73
        thanx for clearing it up
        • Nevillet
          Simple PIR sensor circuit to drive a small motor
          by Nevillet
          Hi All,
          I'd like some help designing a simple circuit for driving a small DC motor.
          The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
          I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
          Can somebody design me a simple circuit for me using something like a 2N3904?
          I'm happy to include a relay if that makes sense.
          Many thanks.
          https://www.badcaps.net/forum/attachment.php?attachmentid=3...
          07-09-2023, 10:48 AM
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
        • juergenb
          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
          by juergenb
          i am asking for some Help.
          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
          The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
          So i got a few of these from Banggood.
          I swapped the motor and now i have a new fault condition.
          In a working Frother you would press the start button, it will light red and work for a few minutes.
          If you press longer it will light blue and just mixup the milk.
          With the new Motor it just starts...
          03-23-2021, 11:24 AM
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • sbt123
          charnwood w821 mini wood lathe motor problem
          by sbt123
          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
          10-27-2024, 03:43 AM
