Help idinifying circuit from Battery Charger
  • davg
    • Sep 2008
    • 536
    The photo is of a circuit in an older car Battery Charger. I was wondering if someone on here could identify this circuit and explain it's function and how it works. It seems to be a very simple circuit to convert AC power to DC power. The two leads from the Transformer connects to the two terminals
  • R_J
    • 9624
    Re: Help idinifying circuit from Battery Charger
    There should be button diodes mounted under each of the brass tabs. 4 diodes making up the bridge rectifier.
    The diodes are likely similar to ar504
    • davg
      • Sep 2008
      • 536
      What should these diodes look like? there is something under these tabs that look like doughnuts?? Can I use a bridge rectifier as shown below to replace that circuit?
      • davg
        • Sep 2008
        • 536
        Tks again R_J yes there are?? first time a have seen a diode looking like that?? The circuit seem to be shorted is there a way to test these diodes?
        • R_J
          • 9624
          Each diode can be tested with a multimeter and diode test. What seems to be shorted? the diodes?
          It looks like all four diodes have a common point, the aluminum plate, so they could have 2 diodes in parallel
          • davg
            • Sep 2008
            • 536
            All 4 of these has a slit in the outer casing which I assume is not normal. Testing with my meter in diode mode and leads end to end gives no reading and the same when I reverse the leads?
            • R_J
              • 9624
              I don't believe they should be split like that, what is the number on them? it should be marked on the side. I t could be the diodes have a high forward resistance so they could show open with a meter.
              • davg
                • Sep 2008
                • 536
                No numbers visible on either of the 4?
                • R_J
                  • 9624
                  People sometimes replace them with 50 amp/400v D0-5 style stud mount diodes
                  • redwire
                    • 3912
                    It looks like the charger manufacturer tried to copy a car alternator's construction with press-fit diodes. But the plastic washers are terrible for heat conduction and aluminum rivets on copper likes to corrode and the skinny wires have to go. Yuck.
                    I would change over to a bridge rectifier module like KBPC5010 50A 1000V $3.00
                    But the big problem really is heat sinking the diodes. Even if you put in huge expensive stud-mount diodes, that small plate just can't get rid of heat very well. I would beef up the heatsink.
                    How many amps is this charger rated? Does it have a fan?
                    • davg
                      • Sep 2008
                      • 536
                      I have a couple of these on hand #72HF80M would they do the job
                      • davg
                        • Sep 2008
                        • 536
                        15Amp 12 & 6 volt 100 amp cranking
                        • redwire
                          • 3912
                          Any diodes used need heat sinking for cooling. This is the hassle.
                          With a 15A load, each diode will dissipate about 7W of heat, roughly.
                          If you use a bridge rectifier module, then all the heat is concentrated in one square for 28W.
                          The VS-70HF is a large 70A 800V stud-mount diode, you would need four.
                          But the hassle is mounting them on the heatsink, the cathode is the bolt so two of the four diodes need insulators or the special version with reverse-polarity (anode to case). Insulators can't transfer the heat, so the diode cooks or the plastic melts and they aren't a great way to go.
                          Simplest fix I think is bolt a 25-50A bridge module on the heatsink, the modules are isolated case so no more hassles with shorts to the metal.
                          Rectifiers from a scrapped PC power supply could work. They are two Schottky's in a TO-220 case and a bit more voltage for the battery. What else you got in the junk box.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8711
                            Yeah probably best not to use a bridge and use discrete diodes - the original design spread the diodes out away from each other for a reason.
                            and holy crap, seeing some china shops selling the button diodes for less than 10 cents a pop in 1000 quantities... wonder how bad they are?
                            • davg
                              • Sep 2008
                              • 536
                              Tks Redwire but I only have two of these vs-70hr's kicking around so I guess that's out? I just recently converted an old PC power supply that I had kicking around to a bench top power supply but I do have a couple of power supplies from a TV receiver not sure what I could get out of that? These board delivers a bunch of voltages but since I am not a tech person I am not sure of the value of what I have in my junk box?? I derive a lot of satisfaction from taking scrap and turning it into something useful but most of my knowledge come from the great people on forums like this. I am a knowledge seeker.
                                • 31285
                                you could do a modern design with mosfet rectification - voltdrop in the microvolts!!
                                • davg
                                  • Sep 2008
                                  • 536
                                  A little over my head?? Trying to work with what I have but maybe you could provide a drawing
                                  • R_J
                                    • 9624
                                    Or buy a new charger when they go on sale.
                                      • 31285
                                      lol - that too.
                                      • davg
                                        • Sep 2008
                                        • 536
                                        Thanks for the comments guys and of course you're right but it's not about the charger,, if it works I will proberly find someone who needs it?? for me it's understanding and accomplishment. I have already learned what that circuit was but I am still not sure how it works? It would appear that the four diodes in that circuit is flowing from anode to cathode or was two reverse polarity?? These button diodes seen to be color coded with a brown side? I will try to find a datasheet for them.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                          Bauer tool battery pack charging with a HERCULES charger modification
                                          by sam_sam_sam
                                          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                          05-06-2023, 12:17 PM
                                          Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                          by sam_sam_sam
                                          I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                          So I have put them on the battery testing machine to drain each battery cell down to...
                                          09-04-2022, 04:45 PM
