Are USB 3 flash drives compatible with USB 2 devices
  • SistMaticZ
    • Jul 2019
    • 72
    • Morocco
    Hello everybody.
    i have an xbox 360 with usb 2 ports .
    Iam using an ODDE optical disk drive emulator known as the Xkey.
    I am planning to buy a USB 3 flash drive to plug it in the xbox 360 via the xkey usb plug.
    can the xkey read usb 3 flash drives ?
    • 31283
    Re: Are USB 3 flash drives compatible with USB 2 devices
    they should be backwards compatable, but i wouldnt trust that.
    i'v had shit made by dell either not see or not boot from usb3 drives.
    • SistMaticZ
      • Jul 2019
      • 72
      • Morocco
      Doesnt matter if it will get down to usb 2 speeds .
      I just want to know if someone got it working
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        I would have to concur with stj, I have one USB3 flash memory that would not boot in a USB2 port on one machine. Still seems to work okay post boot, but would mean they aren't completely compatible with USB2.
        I have yet to try booting that in a USB3 port or another machine, however. IIRC that machine that failed did not have USB3 ports.
        • SistMaticZ
          • Jul 2019
          • 72
          • Morocco
          ok thanks for your clarifications.
          By the way is there some 1 terabyte usb 2 flash drives out there ?
          Am trying to finish my 360 xkey setup for good
            • 31283
            maybe but it will be a stupid price.
            why not use an ssd with a usb adapter?
            or a real drive like a WD Black?
            • SistMaticZ
              • Jul 2019
              • 72
              • Morocco
                • 31283
                your welcome Nick Riviera
                • TMTGTR
                  An Xbox One PSU Odyssey
                  by TMTGTR
                  Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                  =>Background:
                  I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                  06-17-2022, 05:40 PM
                • ekozeko333
                  by ekozeko333
                  🧠 What I’ve Done So Far
                  Flashed...
                  06-21-2025, 02:48 AM
                • corrize
                  Nikon D800 camera - flash don’t work and capacitor don’t charge
                  by corrize
                  Hello, I'm stuck in troubleshooting…
                  The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                  In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                  When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                  10-01-2022, 10:02 AM
                • grimacelord
                  Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                  by grimacelord
                  Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                  After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                  I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                  10-24-2024, 12:31 PM
                • Stevedb
                  Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                  by Stevedb
                  Hi all
                  I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                  Pasw netcomchetumal.
                  Enjoy it.
                  Greetings Steve
                  From Belgium...
                  04-04-2023, 12:42 AM
