Will this work?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Will this work?
    sigpic
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Will this work?
    No, it will not measure the temperature of the room.
    Nor will the motor turn.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Re: Will this work?
      OK, so for a simple small motor that will be switched on and off rapidly, do you think just a mosfet with a flyback diode would be best?
      sigpic
        Re: Will this work?
        Originally posted by EasyGoing1
        Nope, will not work.
        How did you come up with the circuit?
          • 31157
          Re: Will this work?
          why??
          why are you trying to switch both poles????
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Re: Will this work?
            There's others who are far more skilled with stuff like this than I am, but I'll drop by just for curiosity's sake: the way I see it is that the top P-channel will be stuck off all the time due to R3 pulling it up. If all you're trying to do is run that motor, just the N-channel part+flyback diode should suffice IMO, provided the transistor is kept within its specs. Cheers.
            Wattevah...
              Re: Will this work?
              1) Top MOSFET Q2 is N-CH, bottom MOSFET Q1 is P-CH.
              2) 5V is not enough to turn on high side Q2 N-CH MOSFET.
              3) Q1 P-ch MOFET's body diode D1 will be forward bias so when Q2 is turned on, so why have Q1 in the circuit?
              I have no idea what the OP is trying to do.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Re: Will this work?
                Yeah only need one pull up or pull down transistor to turn the motor on/off. Probably easier to do N-channel pull down when doing the level shift from 5V control to 12V output. And yes, as budm indicated, the top transistor's schematic symbol is Enhancement-N and the bottom is Enhancement-P - and neither will work properly because both are deep in the cutoff region as gates will be negative relative to source (Q2-N) or positive relative to source (Q1-P).
                This is not to mention Q1's body diode is anti-parallel to D4, and thus one will always be conducting with Vf of a diode drop no matter if the power is AC or whatever. D3 and Q2's body diode are parallel to each other and thus D3 is redundant if the body diode can take the load.
                Yeah sorry about the tongue in cheek response of "trying to measure temperature in room" because the objective(s) were not stated. However it is true that if wired the way it's drawn the motor will not turn, mainly because Q2 will remain deep in cutoff and have no way of turning on as drawn.
                (incidentally I was thinking about how to design a grid tie inverter h-bridge for my solar panel project, and came to the conclusion that power darlington transistor suck %#*&! and IGBTs should be paired with NPN if I had the right IGBTs in my parts bin. Too bad I have a boatload of useless NPN and PNP power darlingtons and most likely I have to do high side N-ch MOSFET because I don't have IGBTs or P-ch MOSFETs.)
                • redwire
                  • 3912
                  Re: Will this work?
                  OP is trying to cheat by building an H-bridge with only two switches. Using extra diodes does not work. You need four switches (mosfets) to reverse polarity to a load, in a proper H-bridge.
                  Only one switch (mosfet) is needed to turn a motor on and off.
                    • 31157
                    Re: Will this work?
                    i think he wants a pwm speed controller.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Re: Will this work?
                      Provided he only wants it to run in a single direction, a single N-channel FET can be used for that, can't it ? Provided it's rated accordingly.
                      Wattevah...
                        • 31157
                        Re: Will this work?
                        any transistor will do - the current is pretty low.
                        and a 555 timer.
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          Re: Will this work?
                          That's exactly what I want. I was reading about H-bridges, which seem to be pretty popular in motor control circuits, but since I don't need the motor to switch direction, I thought maybe half an H-bridge would be a more suitable circuit for turning the motor on and off ... perhaps with more solid fly back protection than a single diode?
                          It was just a thought...
                          When I put the circuit into a schematic, I was looking at it trying to visualize current flow and I wasn't so sure it would actually work so I posted it here.
                          sigpic
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            Re: Will this work?
                            H bridges are mostly used to switch direction on motors. They're redundant if you only plan to turn it on/off (and maybe do some speed control too) - a simple transistor will work for that, depending on your motor's power requirements of course.
                            Wattevah...
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              Re: Will this work?
                              If you have split supplies, you can do this with just 2.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Re: Will this work?
                                If you want to really build half an h-bridge or half bridge, you could use the other transistor to stop the motor faster
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  Re: Will this work?
                                  It's a small motor ... similar to the kind that they put in game console controllers for vibration feedback.
                                  sigpic
                                  • BOSCHNJAK
                                    by BOSCHNJAK
                                    ABOUT ME INTRODUCTION FILE
                                    2
                                    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                    2022 BEV, PROJECT ?
                                    2021 BEV, PROJECT ?
                                    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                    12-28-2023, 02:09 PM
                                  • sbt123
                                    charnwood w821 mini wood lathe motor problem
                                    by sbt123
                                    hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                    10-27-2024, 03:43 AM
                                  • hollox123
                                    ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                    by hollox123
                                    Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                    1. Laptop keyboard doesn't work
                                    2. The backlight on the laptop keyboard doesn't work
                                    3. The x2 side LEDs (red) on the laptop don't work
                                    The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                    I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                    But I am strongly aiming that it is somehow a BIOS-related problem,...
                                    05-11-2025, 08:05 AM
                                  • resistor83
                                    lenovo 330s-15ikb, led num lock key always on and numbers don't work
                                    by resistor83
                                    hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                                    I tried updating the bios but the problem remains
                                    https://s...
                                    05-29-2025, 08:06 AM
                                  • mikey5791
                                    Help identify this motor
                                    by mikey5791
                                    Hi all forum members,
                                    Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                    Correct me if i am wrong on the initial test.
                                    Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                    11-24-2023, 07:54 PM
