Help with writing to 93C46
  • xAnGeLoSx
    • Jul 2019
    • 3
    through my internet research i came upon a post with you mentioning that you've done some work on odometer reprograming.
    I am currently in the process of doing that to overcome the dreadfull toyota matrix 299.999km stop, I have desoldered the old eeprom (93C46),
    I have a couple of empty 93C46 chips that i want to copy the contents of the original and modify it and replace it, im doing so because the old chip is brittle and i dont wish to use it
    It should be noted that the old chip is ST 93C46W(x) last character is scratched, and the new chip is AT93C46
    I used an old Windows XP system and a diy serial interface with ponyprog software to communicate with the chip and was able to save the dump and decode the reading and what needs to be modified
    The problem began when i attempted to write onto the new chips and kept getting a write failed error, and due to my limited knowledge in the field i decided that its time to get a propper eeprom reader and writer and i got myself a cheap CH341A, but there was no propper documentation on how to use it and what software to use for that programmer and this is where i am right now
    If any of you can please point me to the right path or give me any guidance that could help me get this job done asap i would really appreciate it
    Thank you
  • R_J
    • 9610
    Re: Help with writing to 93C46
    https://www.badcaps.net/forum/showth...ghlight=ch341a the last post has the software file
    Some info here also https://www.badcaps.net/forum/showthread.php?t=67183
      • 31267
      if your getting write errors then maybe you also had read errors - and didnt know.
      • xAnGeLoSx
        • Jul 2019
        • 3
        I did consider that as a possibility but I confirmed that my reading is correct for the older chip by comparing the KMs on the car with the reading and driving the car around to increase the reading and testing the new reading to see if it reflects the change
        Originally posted by R_J
        Thank you very much for the link, i guess i missed that in my search. but unfortunatly I am still unable to read the chip using the CH341A and i believe i know why, thanks to the english software you pointed me to, the chip options that i get are only 24/25 and 26 series, while my chip is a 93 series.
        Now all the website that sell this USB programmer module claim that it reads the 93 series but i have yet to figure out the propper way to do so, i have some speculations on how to do so but nothing have worked so far.
        just to give an idea, here is the programmer:
        as you can see on the bottom right corner there is labels to show were the 25 andthe 24 series chips go but nothing about the 93. and i have noticed on some russian websites that some people have moved the location of the jumper pin to the right by one pin, when i tried to do so, the computer reported the programmer as a new device labeld as "USB SERIAL CH341A", so i attempted to use the ponyprog software with but it, but no success unfortunatly or i just don't know how to do it right due to lack of experiance.
        Still though, thank you for your help guys and hope to hear from you soon
        • R_J
          • 9610
          The ic might have the wrong pinout (Rotated)
          Some info here also: https://translate.google.com/transla...ml&prev=search
          • Rake
            • Oct 2023
            • 3
            • United Kingdom
            I am sorry to bring up an old thread but I also have an issue writing to the same IC 93C46 SOIC 8
            I am timing a car and need to replace the ecu due to water damage and I’m on the last part but need to turn the immo off and that hex is on the 93c46
            I have removed the chip from the board and have purchased the SOIC 8 to 8 pin DIP ADAPTER and I am using the QQ-4x4 programmer. I insert the chip in the adapter and adapter to the programmer main ZIF socket pin 20/21 positions.
            I managed to get a good read in this slot and then I managed to erase the chip. When I write to it I get a verify error at address 0xFF and csnnnot write the new file to it.
            I assumed the chip was damaged or corrupt so purchased a batch of 10, however, I experienced the same problem with a completely different chip.
            I’m desperate for assistance as this is not my vehicle I was doing it as a favour and at the moment I’ve made it worse.
            I have posted in the introduce yourself post and should be able to write a new thread, but it’s not working so I’m piggybacking on to this
            Any help gratefully received
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Are you sure the bitsize is correct? (8-bit vs 16-bit, also known as wordsize)
              • Rake
                • Oct 2023
                • 3
                • United Kingdom
                Good question I'll look up the data sheet on them tomorrow. I managed to get a write and verify by rotating the adapter in the programmer but I still can't get the car started. Glow plug light solid on and no start
                • SidneyCanadas
                  93C46 and 93C56 EEPROM
                  by SidneyCanadas
                  I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                  https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                  Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                  06-14-2023, 01:16 PM
                • ahmedtou
                  HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                  by ahmedtou
                  help me please
                  I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                  When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                  I will share all the details with you, including the disc information.
                  Code:
                  HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                  Current Profile: BD-R
                  Disc Information:
                  Status: Empty
                  State of Last Session: Empty
                  Erasable: No
                  Free Sectors: 12,219,392
                  Free Space: 25,025,314,816 bytes
                  Free Time: 2715:27:17 (MM:SS:FF)
                  Next
                  08-27-2025, 08:49 AM
                • jordi90
                  Lenovo Thinkpad 20LT-S0KL1G bricked after writing the wrong eeprom
                  by jordi90
                  I was given a laptop with a BIOS locked by a password. I read that one way to unlock it is to read the EEPROM contents, patch them, and write them back. I was using the typical CH341A programmer and clip to do this, but because the clip is so loose, after patching the dump I accidentally placed the clip on the wrong EEPROM and now the laptop won’t boot.
                  Can I do something to fix it? I’ve attached photos.
                  10-09-2025, 01:08 PM
                • dmccul2698
                  Pioneer DEX-P99rs "No EEProm " diagnostic code.
                  by dmccul2698
                  Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                  1). Understand the schematic and check the connections between the EEProm and DSP
                  2). Check the functionality of the EEProm
                  I don't know if this is the unit's problem but it's a place to start.
                  I have little to no electronic experience...
                  04-08-2024, 05:32 PM
                • modtool
                  Problems writing MX25L25673G
                  by modtool
                  Hi to all, I'm facing a problem writing to an MX25L25673G SOIC-16 bios chip (part of an HP EliteOne 1000 G2 27") with a Willem programmer 5.0B (with software PCB98D12c4).
                  I know my programmer is old and I've planned to buy a new one but it worked until now with every eeprom I've faced in different devices, this is the first time that is giving me this kind of problem and I need to urgently solve it because I've already changed the fried southbridge and cleaned its ME fw, so I need to finish the last step of the repair.
                  This Willem supports some 256Mbit eeprom, I can choose between...
                  04-02-2023, 11:56 PM
