Problems writing MX25L25673G
  • modtool
    • Jul 2015
    • 63
    • Italy
    Hi to all, I'm facing a problem writing to an MX25L25673G SOIC-16 bios chip (part of an HP EliteOne 1000 G2 27") with a Willem programmer 5.0B (with software PCB98D12c4).
    I know my programmer is old and I've planned to buy a new one but it worked until now with every eeprom I've faced in different devices, this is the first time that is giving me this kind of problem and I need to urgently solve it because I've already changed the fried southbridge and cleaned its ME fw, so I need to finish the last step of the repair.
    This Willem supports some 256Mbit eeprom, I can choose between MXIC, Winbond and cfEON, it also recognizes the IC by the "Auto select chip" button as MX25L25635E/MX25L25735E, I have read it correctly many times but writing to it give always the same error, when verifying data written, always at the same address 0x344003, with the same wrong bytes.
    I've read the written bin after the error and comparing the file extracted to the one I'd like to write, they are the same only in the first 0x344002, after which there are chunks of other data similar to the one I'd like to write but the comparison fails.
    After some correct readings, I've also erased the entire IC and lanched a "blank test" and it verifyed that the IC was full of FF, so erasing process completes correctly.
    Since I don't have an adapter for this SOIC-16 IC, I've "build" one with flying wires (shorter than 4cm), I don't know if this can be the cause of the wrong writing, but if it was shouldn't it be a problem also in reading?
    I've tried taking away the jumper for 3v3/3v6 voltage option, in order to feed the IC with 3v6, but it changed nothing.
    Have someone faced this problem before?
    Can someone suggest using a different software?
    Can someone suggest some settings in the software or the hardware (there are many dip switches and jumpers on its board) of the Willem programmer, please?
    Thank you in advance
  • modtool
    • Jul 2015
    • 63
    • Italy
    Re: Problems writing MX25L25673G
    Can anyone share an advice for this problem?
    I've bought an adapter for soldered SOIC16 to SOIC8-DIP, I've compared the wirings that I've used before and they were the same, but also with the new adapter I can read and cancel this eeprom but I can't write correctly to it, the verification stops always at the same hex point 0x344003.
    I've tried with a CPH341A owned by one of my friend's and all goes well, I don't understand why the Willem recognizes the eeprom but fails at the verification step.
    It seems it could be some wrong software settings, something like an expired timing or the likes.
    Has anyone tried to write to this eeprom with the Willem before or can suggest something, please?
    • DynaxSC
      • Apr 2021
      • 477
      • Poland
      It's probably a software issue (old compiler used, something like a year 2000 problem), or a wrong definition of the eeprom size (too small size), maybe you can find some configuration file for the different chips in the software, and edit this to be correct. Or maybe wrong operating voltage applied (3,3V instead of 1.8V, or vice-versa - check the chip datasheet) ???
      I would'nt waste my time and would buy CH-341 programmer with respective adapters, it costs really peanuts on Aliexpress and solves the problem. There is many software for them, and you can define/edit the chip definition files, create new ones. They work really very raliably, had only once an issue with an unrecognized chip type, but editing/adding a new definition solved the problem. But pay attention, as old versions of the programmer may require a voltage mod, you'll find it on the net how to do this. I think I have described this also somewhere on this forum.
      • modtool
        • Jul 2015
        • 63
        • Italy
        Hi DynaxSC, thank you for your answer and advices.
        I didn't know that the CH341 was so cheap, I finally bought one and I managed to write properly the MX25L25635E (I have not yet concluded the repair of the HP EliteOne after the southbridge replacement and ME cleaning, maybe there's something else broken, but that's another question ).
        As it was an old version, I did the voltage mod so that data lines are feeded correctly with 3v3 instead of 5v, but it was really easy.
        Funny to note that two days ago I had to correct a bios of a Lenovo notebook that didn't start, the IC was a Gigadevice GD25Q64BSIG, the CH341 read it correctly but erasing or writing it made the programmer to be shut down as it was extracted from the usb port (you could heard the usb disconnection sound) and every software I used (Colibri, NeoProgrammer etc) gave an error about the disconnection of the programmer, one time it crashed the driver (included in Colibri folder, working with other 4 types of ICs I tried these days) and also Windows 10 to a BSOD.
        I then used my old Willem programmer and had no problem in reading or erasing or writing to that IC.
        Have you ever had such a problem?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          i have this problem with MX ic too. CH341 is VERY basic programmer. buy RT809F. vay better programmer with autoswitch to 1.8V
          • modtool
            • Jul 2015
            • 63
            • Italy
            Ok, I understand, @ktmmotocross thank you for your advice
            • jean luc ferre
              laptop hp g72 b52sf screen problems
              by jean luc ferre
              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
              06-07-2025, 03:27 PM
            • Hondaman
              USB problems?
              by Hondaman
              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
              08-12-2024, 03:26 PM
            • clabr
              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
              by clabr
              Need help to solve some problems with this laptop.
              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
              Before this had happened I observed some other problems:
              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
              12-02-2021, 08:09 AM
            • ohren
              What problems could this blown cap cause in a Marantz SR5400?
              by ohren
              I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
              R533 right below it in the photo is charred, but measures the correct value.
              1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
              10-21-2025, 09:02 AM
            • jean luc ferre
              display screen problems after changing motherboard
              by jean luc ferre
              First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
              I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
              Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
              Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
              09-11-2025, 10:28 AM
