Isolation transformer
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Firstly I feel this is something I should already know the answer to but it eludes me. Anyways I have been in the repair business for some 15 years or longer and I still don't have an isolation transformer yeah (bad me). So I starts looking at options for 2-3kw isolation transformers and and the price is a little more than I would like to pay out.
    So I gets thinking I have a number of 230v/110 CTE step-down isolation transformers for working on power tools which I also get in for repair from time to time. They are around 3kva rating is there any reason I can't connect two of these back to back to make a 1:1 isolation transformer.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: Isolation transformer
    Assuming they are in fact real transformers, then sure.
    Just make sure it's not actually an autotransformer - some of those step-down ones are. And those won't give you any isolation at all!
    -David VanHorn
    • CapLeaker
      Leaking Member
      • 8136
      I found plenty isolation transformers in a regional ham flea market. I've got one, but hardly use it. I guess that depends on what one repairs.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        To be honest its not something I have ever felt the need to setup, it might be useful for scoping smps I suppose but I have a battery scope for that furthermore most of them are such cookie cutter designs the need to scope out stuff on them is largely irrelevant to me.
        I will have a go at setting this up but I am certainly not paying the going prices for 2-3 kva isoloation transformers. So its a couple of 230/110 cte transformers then, I might need to obtain one more since two are in regular use and one is used for testing 110 volt tools which leaves one spare. I will let you know how I get on.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4951
          • New Zealand
          Originally posted by llonen
          It might be useful for scoping smps I suppose but I have a battery scope for that
          True, that will prevent you from shorting something to ground, but it will not protect you from a direct mains connection.
          Using the isolation for the DUT, with a battery scope or not, will be a bit safer.
          -David VanHorn
            Originally posted by agent24
            true, that will prevent you from shorting something to ground, but it will not protect you from a direct mains connection.
            Using the isolation for the dut, with a battery scope or not, will be a bit safer.
            +1.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              be careful using 2 yellow bricks like that .
                I would verify that they are not Auto-Transformer, you can easily verify by checking the resistance between the windings.
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Already checked on the one spare now looking for another
                  • OddJohnny
                    Isolation Transformers
                    by OddJohnny
                    Looking to start servicing power tools. I’m looking for isolation transformers for 415/230/110V either separately or combined/tapped, above 5KVA. I’m based in the UK. Any suggestions on where I can source?
                    02-16-2024, 04:17 PM
                  • harp
                    isolation transformer from two 240/12, wiring?
                    by harp
                    When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                    So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                    11-25-2022, 05:11 PM
                  • amelbye
                    is it ok to replace a dual output transformer with two single output transformers?
                    by amelbye
                    Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                    Now that's a challenge - luckily...
                    08-21-2020, 08:51 AM
                  • ohren
                    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                    by ohren
                    Hello!
                    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                    Measured voltages with no load:
                    After rectifier diodes
                    12V: 6.17 V
                    5V: 5.67 V
                    Secondary transformer pins AC measurement (really don't know if this says anything)
                    12V: 2-2.5 V
                    5V: 1.04 V
                    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                    03-18-2023, 10:33 AM
                  • mikey5791
                    Is it possible for transformer substitution?
                    by mikey5791
                    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                    My questions are
                    1. How do i test to see if the transformer is in good working condition?
                    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                    Hope you guys understand what i was asking. My intention is...
                    11-03-2022, 02:11 AM
