Isolation transformer
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Firstly I feel this is something I should already know the answer to but it eludes me. Anyways I have been in the repair business for some 15 years or longer and I still don't have an isolation transformer yeah (bad me). So I starts looking at options for 2-3kw isolation transformers and and the price is a little more than I would like to pay out.
    So I gets thinking I have a number of 230v/110 CTE step-down isolation transformers for working on power tools which I also get in for repair from time to time. They are around 3kva rating is there any reason I can't connect two of these back to back to make a 1:1 isolation transformer.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5091
    • New Zealand
    Re: Isolation transformer
    Assuming they are in fact real transformers, then sure.
    Just make sure it's not actually an autotransformer - some of those step-down ones are. And those won't give you any isolation at all!
    -David VanHorn
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      I found plenty isolation transformers in a regional ham flea market. I've got one, but hardly use it. I guess that depends on what one repairs.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        To be honest its not something I have ever felt the need to setup, it might be useful for scoping smps I suppose but I have a battery scope for that furthermore most of them are such cookie cutter designs the need to scope out stuff on them is largely irrelevant to me.
        I will have a go at setting this up but I am certainly not paying the going prices for 2-3 kva isoloation transformers. So its a couple of 230/110 cte transformers then, I might need to obtain one more since two are in regular use and one is used for testing 110 volt tools which leaves one spare. I will let you know how I get on.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5091
          • New Zealand
          Originally posted by llonen
          It might be useful for scoping smps I suppose but I have a battery scope for that
          True, that will prevent you from shorting something to ground, but it will not protect you from a direct mains connection.
          Using the isolation for the DUT, with a battery scope or not, will be a bit safer.
          -David VanHorn
            Originally posted by agent24
            true, that will prevent you from shorting something to ground, but it will not protect you from a direct mains connection.
            Using the isolation for the dut, with a battery scope or not, will be a bit safer.
            +1.
            • petehall347
              • Jan 2015
              • 4449
              be careful using 2 yellow bricks like that .
                I would verify that they are not Auto-Transformer, you can easily verify by checking the resistance between the windings.
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Already checked on the one spare now looking for another
