Help identify component
  • imaddicted2u
    • Dec 2015
    • 101
    Trying to identify the component in the pic. It's in an old car battery charger.
  • R_J
    • 9534
    Re: Help identify component
    Looks like it is a UJT 2N2646 should work
    I found the information here: https://forum.nutsvolts.com/viewtopi...0809b&start=15
    Is it bad or does it just check strange?
    • imaddicted2u
      • Dec 2015
      • 101
      Hey, thanks for that. I turned the internet upside down looking for that and nothing fell out...lol. I dig around and see if I have one. Thanks again.
      Haven't tested it yet. Didn't know what it was.
      • imaddicted2u
        • Dec 2015
        • 101
        Tests bad, thanks again.
        • R_J
          • 9534
          It won't check like a normal transistor. But if it checks shorted, it will be bad. http://www.circuitstoday.com/testing-a-ujt
          • imaddicted2u
            • Dec 2015
            • 101
            Right, it checks like 2 diodes. It measures open every which way.
            • imaddicted2u
              • Dec 2015
              • 101
              That last post reads kind of funny...
              The UJT should check like 2 diodes but this one measures open every which way. The only other semiconductors in the battery charger, 2 SCRs and 1 zener diode test ok.
              Thanks R_J for being ever helpful. It's much appreciated.
              • redwire
                • 3900
                I have some 2N4871 UJT. The only readings I get on diode-test is between E-B1, and E-B2 around 0.98V, +ve to emitter.
                There should be an RC phase-delay and the zener must be to back off when battery voltage gets up there.
                • imaddicted2u
                  • Dec 2015
                  • 101
                  Here are some pics in case you are interested. It's a Motomaster model 11-1519 battery charger, 12 volt at 6 Amps. The circuit board has Tenatronics Ltd. 50-114 etched on it. They seem to be from Newmarket, Ontario.
                  The transformer that feeds the board is a 27 volt center tap.
                  • redwire
                    • 3900
                    It looks not bad, anything beats selenium rectifiers lol. Not hard to sketch a schematic. In the late 1970's lots of GE circuits for SCR chargers.
                    The blue Philips electrolytic caps, I find they don't last.
                    It probably eats SCR's if you short the output.
                    It looks more like a "programmable unijunction transistor" circuit?
                    Like this but drives two SCR's.
                    • imaddicted2u
                      • Dec 2015
                      • 101
                      LOL, I thought I was the only one that remembered selenium rectifiers...When my neighbor dropped it off yesterday, I said, I hope that thing doesn't have a selenium rectifier...lol.
                      The SCRs were soldered before I got it so they may have been replaced. I think whoever soldered it before used acid core solder.
                      The only protection is a little glass self resetting breaker in the output, I doubt it's much help for reverse polarity.
                        • 30955
                        i see them still, in old jukeboxes.
                        • imaddicted2u
                          • Dec 2015
                          • 101
                          I already ordered a couple of 2N2646 UJTs based on the link provided at the start of this thread since I can't cross the original part directly. If it turns out to be a Programmable I'll get one of those. I think I'll sketch it out when I get some time.
                          • imaddicted2u
                            • Dec 2015
                            • 101
                            Funny you mention jukeboxes. When I was in school taking electronics in the mid 70s our class project was to refurbish a 50s jukebox.
                            • redwire
                              • 3900
                              Motorola SU316 unijunction transistor. No NTE cross (like a SU112), not in my 1980 Motorola datasbooks. MPU131, 2N6027 are.
                              Also in this thread about Sears 10A battery charger: https://forum.nutsvolts.com/viewtopic.php?f=45&t=8342
                              But images gone due to third party aholes
                              The guy did not get the 2N6028 PUT to work, but 2N2646 UJT did ok.
                              • R_J
                                • 9534
                                I found another circuit that uses a 2N2608 (SU316), with the SU316 listed in brackets in its parts list, so it might just be a fet?
                                • R_J
                                  • 9534
                                  But the circuit does look closer to this, using ujt
                                  The parts list I refered to was this one, the (su316) might have different meaning in this case
                                  • redwire
                                    • 3900
                                    I drew a schematic and it looks like a voltage-controlled oscillator that pulses the SCRs (trigger transformer). I'd guess it's a UJT or PUT.
                                    I think the circuit has some issues... The snubbers are sort of terrible to have AC on electrolytic caps, and the zener should get supplied not from the trimpot. Unless I have drawn it wrong.
                                    Why are the SCR's on an insulator but not the mounting screws? I think that would short the power transformer?
                                    • imaddicted2u
                                      • Dec 2015
                                      • 101
                                      Thanks everyone for your efforts...
                                      I didn't get notifications for these updates for some reason.
                                      I drew this over coffee this morning.
                                      This is a little more rudimentary than yours but here is my rendition...
                                      edit...made corrections to original drawing
                                      edit: adding pic of back of PCB lit up to see traces better.
                                      The SCRs are isolated but from the back side.
                                      • Willybb
                                        • Nov 2019
                                        • 4
                                        Orientation of 2N2646 Component.
                                        Hi Guys
                                        I am trying to fix one of these Canadian Tire Battery Chargers. Found your article and I'm taking a chance that my Battery Charger has the same issue as yours did. Ordered a replacement 2N2646 Transistor. Having issues figuring out the correct pin layout for the 2N2646 I seem to get conflicting Case/Pin layout for this component.
                                        Questions
                                        (1) Is the attached picture the correct pin layout?
                                        (2) What is the correct Case for this part?
                                        Thanks for your help
                                        Willy
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
