Failed RF power transistors...DC testing (i.e. with multimeter)?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    When a RF power transistor fails, is it still possible to test it at DC? Do they tend to typically fail in a way such that you can't detect at DC (unlike the fact most power switching transistors fail as short and can easily be detected at DC)?
    Granted transistors can fail in more ways than one, but curious if anyone had experience with RF power transistor failures...
    • 31281
    Re: Failed RF power transistors...DC testing (i.e. with multimeter)?
    the gain can slowly drop over time,
    i have seen them fail in the frontend of some nokia cable boxes.
    if you have a meter/tester that shows HFE/gain and you have the datasheet then you should be able to check the spec.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      The hFE/beta tester is also done at DC which I wonder if it's sufficient...
      Using diode check in-situ, it seems okay, but I dread taking this device out of circuit however... going to be painful to desolder.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        What kind of Rf power Transistor are we talking here?
          • 31281
          i assume it's one of the ceramic discs with gold plated wings!!
          • redwire
            • Dec 2010
            • 3912
            In-circuit testing rarely works because there are shunt inductors or transformers in tuned circuits, so you get low ohms across the diode-junctions.
            Newer RF PA parts are mosfets, BJT's with Si-Ge and older stuff was Si BJT.
            I find RF PA transistors fail short or open with not much in between. As I recall, they are arrays (like mosfets) of tiny transistors in parallel, so one shorting usually takes out the entire die.
            ESD or bad antenna SWR usually kills them because they are low voltage parts.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              Thanks, yeah I guess that's what I was wondering, "short or open with not much in between". Yes it's a goldwing ceramic. But weird I did seem to get the characteristic C-B and B-E 0.7V drops of BJTs, which after thinking about it, should be near 0 with the inductors! I need to look at it again.
              Still kinda weird, there is protection circuitry on the board. Also I'm curious how much of a SWR hit if you put a multimeter probe on the circuit while running...isn't that going to mess with the impedance of the wire? :o
              The other question is whether it's worth repairing these radios if it turns out to be these RF power transistors...
              • llonen
                • Sep 2014
                • 495
                • hampshire
                I guess that rather depends on the value of the kit in question, I used to repair quite a lot of amateur radio equipment when it was a more popular interest and still get work this of nature in from time to time. Your going to need an appropriate 50 ohm load and rf power meter as a basic starting point, and while a dvm in volts mode should present a high impedance however they are not generally that useful for measuring RF. You can use a scope, mostly these are very high impedance devices, some have 50ohm inputs for which you will need to take care with and use an appropriate 50 ohm attenuator.
                Mostly the lower power devices are relative inexpensive, they go up in costs by power and relative rarity of device(s) though.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  Yeah, that's the problem. It's an old single band mobile radio. I don't think the radio goes much for ebay prices (probably 30 USD at most, and shipping kills the deal) hence the hesitance on buying an ebay transistor for it... those gold wing transistors aren't cheap.
                  I've hacked up a homemade RF probe frontend and the readings I get are very much in line with the transmitting experiments that I've done. I don't have perfect correlation but it's very reasonable. The homemade dummy load is not very good but also seems to be fairly consistent (it doesn't get warm when it should!)
                  • redwire
                    • Dec 2010
                    • 3912
                    Depending on the frequency, hams are converting some transmitters from BJT to mosfet. It's also a popular mod for CB radios.
                    For your TX, the problem might be upstream at the driver stage, or bias for the final PA stage that need to be checked. It's odd the transistor looks asleep but tests OK.
                    The make/model of radio might help, if a schematic exists. I think multimeter leads do upset the SWR seen at a point but at a few ft of wire it is usually nothing compared to the wavelengths. It's usually capacitance that loads or affects an RF circuit then.
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      Replaced emmc.
                      Terminal log
                      UART
                      AC_ON
                      E-B
                      FDE enabled
                      06-01-2025, 02:11 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      09-06-2024, 05:59 AM
                    • dragometin
                      Hitachi 40HYC42
                      by dragometin
                      TV Model: Hitachi 40HYC42
                      Power Supply: 17IPS71
                      MainBoard: 17MB95M
                      Panel: VES400UNDS-2D-NO3
                      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                      Is there any variants on 17IPS71 power supply's?
                      UART output pins 10 and 12 on scart connector:
                      Code:
                      12:24:04.595
                      08-08-2024, 05:53 AM
                      HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 02:15 PM
