Re: Directly replacing NiMh cells with Li-Ion cells - bad idea ?
We'll see how long it lasts and if it goes up in smoke. I don't know what protection this thing really has.
7.5 minutes is ⅛ hour, which is an immense load. 1.5Ah / ⅛h = 12A (in the "new" vacuum. The old battery in the old vacuum was 1.3Ah/⅛h = 10.4A) I suspect the Li-ion may last a few more seconds in the old vacuum due to 200mAh higher capacity...
well you mention 10A, i would be surprised if the cell was rated above 4A
most small ones arent.Leave a comment:
The battery appears to be wrapped and no real good markings visible on it. I suspect it should be just as good as both vacuums have similar runtimes (~7.5 minutes) and initial battery capacities (3.6V@1.3Ah vs 3.6V@1.5Ah).
Heck the motor is about the same size too.
Well I put it together with some damage, the plastic seems to have gotten very brittle over the years. With the battery charged to 4.2V it seems that the charger has cut off. Have to see if it charges correctly after it's discharged a bit.
The vacuum cleaner really SUCKS now!!! Even compared with the original NiCd cells, then again the original NiCds were quite used up.Leave a comment:
post a photo of the battery markings so i can look for the spec.Leave a comment:
Well, I picked up another junk handheld vacuum cleaner for a buck. I grabbed it because it seems to still be spinning, and said "lithium 3.6V" ... Jackpot, it might actually match the specifications I need for the one I have.
I opened it up, and it appears to have a similar wiring diagram...battery straight to the switch and motor. It looks like it has a single small circuit board in it, wonderful, it's got to be a protection/charger board. Inspecting it closer...weird, no big FET on it? This thing needs to withstand 10A and no SOT-23 will do it, must at least be a D-PAK?
Oh well, so I pulled the battery and the circuit board and measured the voltage. It was down to 3V, which is probably still fine. Supposedly it's a 1.5Ah cell, and it says 3.6V, and appears to also be rated for 5.4Wh - so this is probably a lithium ion manganese cell versus a cobalt or iron phosphate cell. So I stuck it on an external charger bypassing the board, and see how it goes... up in flames maybe? Hopefully not, I still need to figure out how to charge this thing.
Well why not keep this vacuum and ditch my old one? The one I have is a wet/dry unit, and this one has a funky charger connector... Combine and get the best of both worlds.Leave a comment:
You were right: I'm having just a little bit too much fun with this threadLeave a comment:
maybe the vac owner read this thread!Leave a comment:
It's assumed that "he know what he's doing" given that's what he's employed for. There's no real way management can actually gauge a technician's performance and/or overall skills and knowledge, other than keeping a close eye on the service tickets they receive, how they go around handling them and how many they've actually successfully fixed.Leave a comment:
So the company gives freedom to do what ever he wants even it is dangerous.Leave a comment:
Of course - there's a 3 month warranty period for all repairs, which makes perfect sense from the client's perspective (it's also in the law here AFAIK), but it can become problematic for the company if doing semi-functional repairs like these where something is bound to go wrong...Leave a comment:
So the company you work for will be reliable if something goes wrong?Leave a comment:
Vac's still in the shop BTW, all packed up and ready to go. "Mr. Battery" called the client to come pick it up, but he hasn't showed up so far. Guess the chap is too afraid something might go pop and doesn't want to pick it up again LOLOccasionally "Mr. Battery" here gives it a whirl, sucks up some stuff and plugs it back in to keep it all nice and topped up and I'm like talking to those cells "hang in there, he'll relent soon enough"
Maybe the batteries burned so bad there was no evidence left of what caused the fire?Leave a comment:
or he died in his sleep from smoke inhalation!!!Leave a comment:
I find it interesting that the same mod he attempted on a similar vac is still working...or at least it hasn't returned. I can't tell if that's because the chap simply didn't use it or they simply got lucky...both of themLeave a comment:
I wonder how much longer NiCd/NiMH packs would last if there was an overcharge/overdischarge controller ... now that's a thought...Leave a comment:
I mean, I would have probably done the same too, up to a point. But if I see someone is doing something stupid, I'd always offer to lend them a hand, even if it's likely to backfire on me (as in, the other person get grumpy about it, because they thought you are insulting their "intelligence".
). In any case, I would probably walk to the guy and jokingly throw a, "are you still working on this piece of crap"... then just "lightly" suggest that IKEA might have the real proper parts he needs to fix this and just get it done.
Originally posted by DannyxIt's a good thing I had it round the shop, even in this semi-functional form, because it enabled me to assess its suction power, which is certainly not going to be on-par with a canister or mains powered vac, but still satisfactory for the aforementioned endeavors.) does the job OK.
Originally posted by stjthere may not be discharge protection - ni-mh dont need it.
you can just run them into the ground and charge them just fine after.
Only problem with deep-discharging Ni-Cd and Ni-MH packs with series cells is some cells will discharge before others... and the ones that do could be forced to "reverse-charge" from still somewhat-charged cells. Neither Ni-MH nor Ni-Cd cells like this, so they'll get trashed over time. However, if you take the individual cells and deep-discharge them, you can keep them stored like that for years (and in fact is the preferred method for them, as it prevents dendrite growth).
Originally posted by stjit will probably be back!Very likely, yes.
Just like that song:
https://www.youtube.com/watch?v=LjMffHG1V_Q
Speaking of which... Danny, I think you should play that for your colleague while he's fixing the vacuum... see if he gets any hints.
P.S. I think I'm a bigger ass than you, aren't I?Or maybe we are just "disrespectful youth" as your OG colleague would say about us anyways.
(hopefully not chared and in an "evidence" bag!!)Leave a comment:
by AlexVGHi,
I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
(This board does not respond, only the LEDs light up in a circle.
The liquid damage is catastrophic and restoration is impractical).
(I bought this board to get the WiFi module and camera).
The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
If... -
by ChaksI need help to extend the runtime of the ups board (see attached image).
This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
Thanks and kind regards,
chaksindia...-
by flat-eartherI have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries.... -
by Petr0xHi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...05-24-2024, 01:00 PM -
by sam_sam_samIf you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
One note this unit has been repaired already once because of switching power supply regulator ic chip failure
Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
... - Loading...
