Getting into PLCs
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    #61
    Re: Getting into PLCs
    Originally posted by Dannyx
    No, I'm not into programming, but I'm willing to learn, so I'd be curious what the contents of such a flash chip would look like and what programmer would be able to read it.
    For higher performance PLC's, you will find compiler code (native to the CPU that's executing it). For cheaper models, you'll likely find some sort of intermediate code that is interpreted/JITed by the processor.
    You won't find stuff that you can read "in English"...
      • 31283
      part number of the flash will help,
      or just spend $800 on something universal with 48 active pins!!!
      the flash will have a bootloader with the code for reading passwords and comparing them, together with the loader routines.
      then it will have a system area for storing passwords and other "settings",
      then a big area for the uploaded user-code.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        #63
        I was hoping it's pretty visible in the picture (I took one of every major chip on there), but in case it isn't it's SST39SF020A which I think is THIS.
        Nope - not happening It would be redundant for this purpose anyway, plus the issue at hand is not so much learning to program a new PLC entirely from scratch as it is recovering the routine the original machine performed, which is only partly known so far due to a complete lack of documentation on these machines (even "known" is a bit generous here - inferred would be more appropriate)
        Also, just the issue I've been having from the very start and why it's not happening:
        Wattevah...
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          #64
          ["Code" not visible in human-readable form]
          Depending on the PLC, the programming tools may hold the "source" off-line (relying on you to maintain it's availability), or, will include tools to "decompile" the image from the controller and (effectively) recreate the original sources.
            • 31283
            i think that part is compatable with a 256k 32pin eprom,
            you could read it with an arduino running eprom/novram software.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #66
              XCP Pro (the software used with this PLC) does have a function to read back from the PLC, but it won't let you do it without the password...
              On this topic, I of course shall want to protect my version of the program on the new PLC with a password as well, but there was something I came across in the manual which put me off: the manual talks about something called "secret download" which sounds like it would do just that - password-protect the PLC to prevent writing/reading, which these guys already did with theirs - but the slightly broken english made it sound like it would lock down the PLC entirely and would prevent ANY subsequent attempts at reading/writing to it, even if you purposely do it and know the password....damn chinese tech
              Wattevah...
                • 31283
                do you want to read the flash?
                i can explain in detail how to do it with just an arduino, and a chinese €1 adapter pcb.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #68
                  Go ahead, just for reference. I'm not sure it would help with cracking the password, but still useful to know in the long run, why not
                  Obviously I have to pull off the chip first...preferably without destroying pins and traces, which is not going to be easy with all that lacquer they poured on the PCB. Then I'd need the adapter and then something to read it with...I didn't know the Arduino can do that.
                  Wattevah...
                    • 31283
                    https://www.jammarcade.net/programmi...-arduino-mega/
                    you can mod that to read any parallel memory device.
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      #70
                      Systems implemented with PLCs are notoriously easy to "steal" -- buy the sensors and actuators that the original manufacturer used, buy an exact copy of the PLC that was used, transfer the "software" from the PLC to the new one and you've cut the original manufacturer out of the loop (sale)!
                      So, you want to be able to "lock up" the "source code" (ladder logic, etc.) that is embodied in that PLC so that the counterfeiter can't clone it.
                      At the very least, you want to ensure the counterfeiter can't blindly clone the code (without bothering to understand it: "This SEEMS to work good enough, as is!") to cut the manufacturer out of the subsequent "purchase(s)".
                      As many industries using PLCs in their process control applications have staff that are competent with PLCs -- though not, perhaps, capable of designing a complete system from scratch (amazing how many folks can MODIFY an existing system yet are clueless as to its basic design) -- you also would like to obfuscate the sources so the counterfeiter can't "see" how you've solved the problem. And, by extension, can't see how to make the changes they would like -- without enlisting your help ($$).
                      Whenever your customer (or competitor!) can freely purchase the components that you have purchased and used in your design, you are at risk for them cutting you out of the loop. You want to raise the bar so they need to invest as much effort trying to steal your work as they would have to invest to create their own ORIGINAL work.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #71
                        Doesn't seem to be so much for reading chips as it is for writing to them. Not sure about one thing though: is this the same thing as the NAND in TVs ? Those always fail on Samsungs and I thought this might kill two birds with one stone and I'd be able to reprogram those as well (provided I find the correct software)
                        Wattevah...
                          • 31283
                          here's a better one - just increase the number of address pins.
                          https://github.com/frisnit/Arduino-Eprom-Writer
                          and no, you cant really clone high density flash with it because you cant re-map around bad sectors on the new chip
                          you can read any parallel memory with it though - as long as it's 5v tolerant.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            #73
                            Well, just for those who are curious about the display for these things as well, here's some shots of what's inside one of these OP320 displays. This is one of the newer ones we received and I successfully created a program for. I distinctly remember there were some slight differences between this one and the "original" TouchWin ones which came installed on those water filter stations.
                            There's three of those: one of them works but has vertical streaks across the middle of the display due to moisture, the second was completely dead but I managed to revive it (corroded trace somewhere) and the last one turns on but doesn't do anything else: just the blue backlight comes on but never boots. My idea was to take the microcontroller from that one and solder it onto this one, or even better, swap the whole board if it fits, which I believe it doesn't because of one of those slight differences I mentioned. This is of course assuming the micro is not the cause of the failure to begin with ! ! I think that one uses a flex cable to connect the two boards, whereas this one uses header pins.
                            Wattevah...
                              • 31283
                              looks like an off-the-shelf graphic lcd, and an obsolete 4k microcontroller.
                              not much to it.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                #75
                                I guess I should probably dig into the dead one some more, since I feel I didn't give it the required amount of attention before giving up....granted, the time constraint was rather short, so I just left it in there so there wouldn't be a hole in the panel of the station
                                Wattevah...
                                  20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                  by sam_sam_sam
                                  I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                  At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                  Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                  04-09-2023, 08:04 PM
                                • BOSCHNJAK
                                  by BOSCHNJAK
                                  ABOUT ME INTRODUCTION FILE
                                  2
                                  024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                  2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                  2022 BEV, PROJECT ?
                                  2021 BEV, PROJECT ?
                                  2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                  2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                  12-28-2023, 02:09 PM
                                • Ugur87
                                  MacBook Air M4 A3240 Brand New Water Damage no Image
                                  by Ugur87
                                  I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                  08-28-2025, 01:09 PM
                                • edugimeno
                                  Stagg sms12p audio amp has water damage
                                  by edugimeno
                                  Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                  I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                  There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                  There is only one signal wire connecting the first boards...
                                  05-24-2025, 06:00 AM
                                • RetroComputingGrotto
                                  Water Damaged Toshiba 48L1435DB
                                  by RetroComputingGrotto
                                  I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                                  The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                                  10-07-2024, 08:23 AM
