cap chart
  • bogart219
    • May 2009
    • 183
    • usa
    cap chart
    Yellow,
    I was wondering if anyone has or knows where to find a chart that shows the worst case esr values for electrolytic capacitors. I have the dick smith esr meter. They have some values printed on the face of the meter but I would like to have a more extensive chart to keep from guessing. Thanks!
  • japlytic
    • Oct 2005
    • 2086
    Re: cap chart
    http://www.chemi-con.co.jp/e/index.html
    Click on "Aluminium Electrolytic Capacitors" and then on "Group Chart".
    For general purpose capacitors, refer to the ESR values of the KMG Series.
    For low ESR capacitors, refer to the ESR values of the LXV or KY Series.
    • bogart219
      • May 2009
      • 183
      • usa
      Re: cap chart
      Thanks Jap!
      • bogart219
        • May 2009
        • 183
        • usa
        Re: cap chart
        Originally posted by bogart219
        Thanks Jap!
        Hey Jap, I was looking for a chart thats like on the front of my esr meter. Do these charts you referred me to show worst case esr?
        • Wizard
          • Mar 2008
          • 2296
          Re: cap chart
          These are fresh capacitor values. Anything above these is considered bad.
          The ones on the ESR meter is worst case and judged to be rough guide, make a guess between values like 330uF, 39uF so on. Like plotting a curve and hit the new dot between dots.
          Cheers, Wizard
          • bogart219
            • May 2009
            • 183
            • usa
            Re: cap chart
            Ok, I see. Thanks again!
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
            • SluggerB
              Help identifying Aluminum Electrolytic SMD cap values
              by SluggerB
              I am trying to re-cap a Tivo unit, but am unfamiliar with how to decipher SMD Aluminium cap codes to capacitance and voltage values to swap them out. Here's what is on each cap...
              07-25-2023, 12:50 PM
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • jorpec
              Changing the scale of an analog meter
              by jorpec
              Hi
              I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
              I wonder how i can accomplish this so the meter would be precise at any temperature ?
              Thnaks
              01-23-2023, 10:37 AM
              How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
              by sam_sam_sam
              About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
              Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
              12-14-2023, 07:45 PM
