cap chart
  • bogart219
    • May 2009
    • 196
    • usa
    cap chart
    Yellow,
    I was wondering if anyone has or knows where to find a chart that shows the worst case esr values for electrolytic capacitors. I have the dick smith esr meter. They have some values printed on the face of the meter but I would like to have a more extensive chart to keep from guessing. Thanks!
  • japlytic
    • Oct 2005
    • 2086
    Re: cap chart
    http://www.chemi-con.co.jp/e/index.html
    Click on "Aluminium Electrolytic Capacitors" and then on "Group Chart".
    For general purpose capacitors, refer to the ESR values of the KMG Series.
    For low ESR capacitors, refer to the ESR values of the LXV or KY Series.
    • bogart219
      • May 2009
      • 196
      • usa
      Re: cap chart
      Thanks Jap!
      • bogart219
        • May 2009
        • 196
        • usa
        Re: cap chart
        Originally posted by bogart219
        Thanks Jap!
        Hey Jap, I was looking for a chart thats like on the front of my esr meter. Do these charts you referred me to show worst case esr?
        • Wizard
          • Mar 2008
          • 2296
          Re: cap chart
          These are fresh capacitor values. Anything above these is considered bad.
          The ones on the ESR meter is worst case and judged to be rough guide, make a guess between values like 330uF, 39uF so on. Like plotting a curve and hit the new dot between dots.
          Cheers, Wizard
          • bogart219
            • May 2009
            • 196
            • usa
            Re: cap chart
            Ok, I see. Thanks again!
            • chth96
              by chth96
              03-09-2024, 10:03 PM
            • SluggerB
              Help identifying Aluminum Electrolytic SMD cap values
              by SluggerB
              I am trying to re-cap a Tivo unit, but am unfamiliar with how to decipher SMD Aluminium cap codes to capacitance and voltage values to swap them out. Here's what is on each cap...
              07-25-2023, 12:50 PM
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • rashidjafar
              Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
              by rashidjafar
              I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
              Values for :-
              PC43 : Capacitor [3x1.5mm]
              PL7 : Inductor [2x1mm]
              PC39 : Capacitor [1x0.5mm]
              Any ideas would be appreciated.
              I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
              08-07-2025, 05:10 PM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
