DIY Backup with sealed lead acid battery
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Recently someone suggested that I'd install an alarm system in my apartment and my brain instantly sprung into action and began devising plans for making one rather than buying an off the shelf unit. It's a lot cheaper for one thing and secondly nothing beats a good DIY project The brains will be an Arduino of course and the system itself would be relatively easy to implement....DAMN easy in fact: just a couple of IFs to monitor some switches...that's not important.
    What IS important is that we want this thing to run even when the power goes out so we need some sort of battery backup. Of course I could just plug the adapter that powers the whole system into an UPS, but it seems too "simple" for my taste I was thinking of making my own battery backup system with one (or more) UPS batteries. The operation would be fairly straightforward: run on battery when mains is not present, switch to mains and charge battery when it comes back...The switching can be something as simple as a relay (which I did in the past for a different project), it's the charging that's going to be the most challenging so as not to kill the battery.
    I was thinking of something very basic like an adapter simply hooked up to the battery. The label says "charge at constant voltage" and there's some values on the battery usually 13-14v, so I was thinking what if I just apply 13v straight to the battery ? I've seen plenty of battery charging circuits online, most of them involving an LM317 in some fashion but to keep it as simple and dirty as possible, I thought of the above method....it would probably become an issue if the battery is drained and the charge current is too great. Seeing how I'll have an arduino as the brains, I can have it interact with the battery as well to start/stop charging when certain values are reached. Any ideas on this battery backup portion ? It could even be a generic application for other projects, not just an alarm system.
    Wattevah...
    • Jul 2011
    • 6070
    Re: DIY Backup with sealed lead acid battery
    I have tried this with a Parallax Basic Stamp controller the results were so - so
    Meaning that the repeatable was not as good as it should have been for my liking
    I table the idea for a different way to keep track of the changing of the battery
    If I were to this again here is how
    I would approach this time around
    I would find a charger that is made for the type of battery that you are going to use
    and have your controller restart the battery charger if the battery is low and if did not do it for it self
    I would have the controller setup in such a way that if your battery voltage stays to low is to high for how many hours that it shows up as an alarm
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      What exactly did you try ? Measuring the charge current with the micro ? What were the limitations you noticed ?
      Wattevah...
        • Jul 2011
        • 6070
        I had the controller turn on and off a LM317 in the current mode and using a
        Digital to analog convert chip to monitor the voltage on battery it would either over shoot or under shoot the voltage settings that I had in the program
        This would happen over a period of time
        The battery would not stay fully charged
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          One problem I've always faced when dealing with batteries is how to check the voltage on it WHILE it's charging, because the meter, microcontroller, whatever it is, is always going to see the "adapter" voltage going into the battery and not the actual value of the battery itself, since they're in parallel.
          Wattevah...
            • Jul 2011
            • 6070
            This is where you put your voltage sensor on the battery and have the controller turn on and off the charger and while the charger is off ( for set amount of time for the battery voltage to stabilize ) this is when you read the voltage if the voltages is low turn the charger back on until it reaches the voltage cut off in your program
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Oh so I WAS right in my assumption: there's no way around it but to somehow disconnect the incoming voltage. Good idea, but it would have to either sample at rather slow intervals or very very fast...don't know which approach is industry standard in stuff like cars, phones, laptops etc.
              Wattevah...
                • 31255
                so what's wrong with a chair, a shotgun, a reel of tape, and some string??
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Too old school
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Another interesting one here (the second version). I could replace that 555 with the arduino used to run the alarm module, so I don't use two separate ones. Put all of this into a box, mount it on the wall somewhere and we're good to go....running wires for the sensors would be a bit of a chore, but hey, whatcha gonna do...
                    EDIT: had another look at that schematic and may have spotted a problem, though it's not mentioned, so perhaps I don't fully comprehend how it operates: when the LM317 is active, wouldn't the resistor divider on the right immediately detect the battery as being charged causing it to oscillate ON-OFF-ON-OFF very fast ? My idea is that when the battery is discharged, the circuit will begin charging it and as such apply voltage to the output terminal. This is connected to the resistor divider which would make it read the charge voltage and not the actual voltage in the battery, thus the circuit would turn off. As it does so, the "real" voltage appears again, triggers the circuit to charge and so on...could be a bad analysis though.
                    Second possible analysis of the issue: the LM317 is used as a constant current source and not a constant voltage source (it's more of a combination of both in fact), so it slowly ramps up its output based on the current drawn by the battery (due to that sense resistor on its OUT pin), which would make more sense in conjunction with that voltage divider because it doesn't always output 14v or whatever, but slowly "gets there" when the battery no longer draws current through the current sense resistor.
                    Wattevah...
                      • 31255
                      a friend of mine used a car alarm for his place - the chinese 2way type with a pager!!
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Yeah, that's an off the shelf solution but that's not really relevant: the battery backup could be used for any system, not strictly an alarm system. That's just the system which comes to mind as needing backup more than anything else.
                        Wattevah...
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Here's what I had in mind: I adapted the example diagram....I spent all 5 minutes doodling in MS Paint so it's going to be brilliant Didn't really think it through: just threw together some lines and replaced most of the passive components with the arduino.
                          The way I see it on paper: we need some sort of voltage reading, so the resistor divider on the right was given to us right off the bat and should stay in the circuit AFAIK. We can use that to "measure" the voltage with our arduino to cut off the charging when it's reached 13.5v or something, which is where the next part comes in: in "charge mode", 2n4401 is "open" and not acting on ADJ pin in any way, so the LM317 does its magic and charges in constant current in conjunction with the current sense resistor (typical application AFAIK). The arduino then turns on 2n4401 and pulls the ADJ pin to GND, bringing down the output to 1.25v or something like that. I threw an extra "Isense" line on there for no real reason...I just realised.
                          ...as I'm writing this, I'm starting to notice that the arduino is probably superfluous for this application, which could be pulled off with discrete components to measure a goddamn battery
                          Wattevah...
                            You will need more than 15V feeding the circuit.
                            https://cdn.badcaps-static.com/pdfs/...3ef99622bc.pdf
                            What is the purpose of 15V Zener?
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              According to the original schematic (since I didn't alter that portion) it prevents the LM317 from exceeding 15v.
                              Wattevah...
                              • Curious.George
                                • Nov 2011
                                • 2305
                                • Unknown
                                Discrete components don't have (significant) memory. You will find that your circuit "works" -- with a new battery; then fails miserably as the battery ages or develops faults.
                                Of course, if you don't really CARE about how well the backup is performing, then these won't be issues for you!
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  My building hasn't experienced a power outage in ages TBH, so the battery would spend most of its life "idling", which may or may not be detrimental to its health and it might fail just as I need it and SLAs are relatively expensive (by my standards at least), so maximum battery life would be important, that's why I thought I'd "smarten" the thing up a bit by including a uController of sorts.
                                  Wattevah...
                                    • 31255
                                    why not use a car battery, and have a circuit that disconnects it with a relay for 99% of the time once it's charged.
                                    no need to waste power with 24/7 charging of a cell that has no load.
                                      • Jul 2011
                                      • 6070
                                      You are making this more complicated than it needs to be why ?
                                      Use a battery charger controller that is responsible for the charging of the battery use one that charges at a high rate then powers down as battery voltage hits 13.8 to 14.5 volts then goes to stand by
                                      Have your controller take care of this part
                                      All you need to do is once the battery is completely charged turn the charger of then once a day check the battery voltage and check it the stand still charge if it is below 12.5 then turn the charger back on for a certain amount of time and recheck the next day if no charge is needed then skip that day
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        Exactly what I was planning on doing, but to do that we need SOME sort of monitoring and rather than messing with discrete stuff which is prone to large errors, I thought I'd use a micro.
                                        Come to think of it, efficiency is another aspect I haven't taken into account: the alarm system (which let's face it is not even designed yet) would be a small consumer. I was also thinking of having it run a DVR and some cameras....straight off the battery Haven't tried it yet, but the "classic" approach in this industry is to have a proper stand-alone UPS plugged into the mains, the SMPS for the cameras and DVR plugged into that, so when power goes, it would essentially go
                                        DC from battery>AC by inverter inside UPS>DC by adapter for DVR > DVR. I'm no expert but I'm wondering (outside of cost), is this more efficient than just going:
                                        DC from battery> Dc input of DVR ? Just a thought.
                                        Again: charge battery when mains is available to a certain level, disconnect it and forget about it, toggle battery over to the DVR when power goes out (simple relay job).
                                        Wattevah...
