DIY Backup with sealed lead acid battery
Re: DIY Backup with sealed lead acid battery
Some battery maintainer circuits:
https://www.youtube.com/watch?v=qxyVqjCuR80
https://circuitdigest.com/electronic...2v-sla-batteryNever stop learning
There is no need to be fancy charging a lead acid battery.
Constant 13.5V float charge - for cells rated for such usage (most are, but check) - will be just fine.
I just installed a CCTV system for my house. Two cameras plus NVR box from Amazon. I added a lead acid battery to the unit itself, connected to the 12V of the hard disk drive which is permanently connected to the AC adapter input. Then I modified the AC adapter to tweak the output voltage to 13.5V so this would keep the lead acid cell topped off.
No fuss needed. As soon as the power cuts out the battery automatically takes over because it's in parallel. And it back-feeds the cameras through the power lead. A tiny 12V, 1.2Ah battery gives the unit an approximately 1 hour runtime, perfectly sufficient for running through short black outs (which the majority of power cuts are.) I can confirm that the HDD will operate perfectly correctly up to around 15 volts DC for those curious.
Only disadvantage right now is that if the voltage drops to the point where the HDD stalls (approx 9.5V) then power comes back on, the unit won't automatically re-mount the disk...I need to figure out how to get this to work. But, that's pretty unlikely, because once the battery drops below 10V, it usually only has a minute or so of runtime left before the whole unit resets.Last edited by tom66; 11-21-2018, 05:22 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Of course, this would be totally doable here as well, but I fear it may lower the life of the battery than if I were to disconnect it entirely, hence the original idea.Wattevah...Comment
Well, I suppose it depends on what kind of lifetime you are expecting.
I have seen alarm and fire panels use designs just like mine, constant float charge, and they get 7-8 years out of a battery.
Most lead acid cells have less than 10 years life. But lead acid batteries are also highly recyclable and low cost.Last edited by tom66; 11-21-2018, 05:53 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Not sure about their low cost. They don't seem cheap, to me at least....I'm not sure how the devices (cameras, DVR, etc) would behave when the voltage of the battery begins to drop and it's somewhere in the "sweet-spot" threshold between the device actually running at its lowest acceptable input voltage (say 10v) and not running at all. It could cause some quick undesired transitions between the off and on states, the effects of which I don't know...Wattevah...Comment
What if I went the opposite way: up to 24v ?
EDIT: ok, I wrote that before I even thought about it - stupid idea considering I'd have to step it down to 12v again, which would lower the overall efficiency. I reckon for maximum efficiency there should be as little conversion as possible.Last edited by Dannyx; 11-21-2018, 11:59 AM.Wattevah...Comment
same concept, use a simple buck or boost convertor to get a constant voltage until the battery is depleted.
go look at julien's video's
https://www.youtube.com/user/julius256/videos
he has been building convertors on a plank of wood with an arduino to drive it!!Comment
The down side of float charging is they don't give you the fast charging rate that a normal charger would.
Only disadvantage right now is that if the voltage drops to the point where the HDD stalls (approx 9.5V) then power comes back on, the unit won't automatically re-mount the disk...I need to figure out how to get this to work. But, that's pretty unlikely, because once the battery drops below 10V, it usually only has a minute or so of runtime left before the whole unit resets.Comment
Note that the float voltage (as with the charging voltage) varies with temperature. So, a "constant" works best when temperature is also constant. E.g., at higher temperatures, a battery outgasses at a lower voltage (what's the tempco of your AC adapter?).
What limits the charge current? I.e., when battery has drooped to ~10V and mains power comes back on... Are you counting on the current limiting inherent in the AC adapter to do this? I.e., if you used a BEEFIER adapter, your charge current would be "less limited"?
Deliberately open the battery lead when the voltage drops to a certain point (add plenty of hysteresis so it doesn't oscillate, there.) You can probably use something as small/cheap as a 555 (to exploit its high current output to drive a relay coil, directly)Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
Seconded. Maybe use a resistive divider that needs at LEAST 10VDC (or whatever the minimum acceptable battery voltage is). Use a voltage regulator chip to keep the 12V at a constant level for the DVR to use. For the resistive divider, fuse it at like 1A or 2A and connect that to the battery. Connect the coil terminals from the resistive divider to negative, and switch the power to the voltage regulator using that. Then when the power comes back on, the adapter kicks on and the relay restores power to the DVR.Comment
I was thinking of the resistor divider idea to "monitor" the battery's voltage and toggle the charging on and off, but we'd run into the same issue of the divider seeing the adapter voltage rather than the actual battery voltage, so I'm still bidding on the constant current LM317 idea. Correct me if I'm wrong in my assumption.Wattevah...Comment
The "less healthy" the battery, the more your voltage/current source will "pull" the battery in "their" direction.
Even if you "disconnect" the charger in an attempt to monitor the battery by itself, you'll still find surface charge will mislead your (high impedance!) attempt to probe the voltage (and, from that, determine state of charge).
[You'd have to "burp" the battery to remove that charge before you could see the true state of the battery]Comment
So I say periodically disconnect whatever is charging the battery (be it an adapter directly, or a purposely built circuit), then probe it via the resistor divider for X seconds/minutes to get a (relatively accurate?) reading. If the reading is high enough and not dropping too fast (which would indicate a faulty battery which is not keeping the charge), keep the battery disconnected from the charger. If it's below a certain threshold, throw it back on the charger.
In battery mode, I believe the battery should be disconnected to prevent over discharge which shortens the lifespan of SLAs....deep cycles batteries are too expensive for this purpose. Even if a boost converter would technically be able to continue powering the load even when the battery is below 10v, it's not a good idea to drain it to the absolute 0....Wattevah...Comment
So I say periodically disconnect whatever is charging the battery (be it an adapter directly, or a purposely built circuit), then probe it via the resistor divider for X seconds/minutes to get a (relatively accurate?) reading. If the reading is high enough and not dropping too fast (which would indicate a faulty battery which is not keeping the charge), keep the battery disconnected from the charger. If it's below a certain threshold, throw it back on the charger..
maybe use these bits (read the datasheet - it can monitor voltage, and current flow AND direction!)
https://www.youtube.com/watch?v=8ikyp4lu45MComment
Not sure whether I should go with a 24v or 12v battery. A 12v one would still require a "master" supply voltage of (I'd say at least) 18-19v to charge it, through a control circuit of course....this is if we want the "advanced" version.
A simple version would be to simply keep the battery attached to the same terminals as the rest of the devices (which has been suggested, of course) and let it take over when the power fails, but this also eliminates any possibility of control - it just runs until it's completely flat, possibly causing intermittent behaviour when it starts to reach the "dead zone" like one of the cameras failing or displaying crap....Wattevah...Comment
All this is complicated by the fact that there will be measurable differences in voltage based on battery temperature, as well as age, state of charge, etc.
And, you have to be able to "tell" your monitor that you've replaced the battery (if it is trying to adapt to the battery's characteristics, over time).
You can find endless opportunities to learn if you want to tinker with batteries. Or, you can find something that has already got that expertise built in!Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by sam_sam_samThis started a few days ago and does this about every 8 hours
After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
The battery backup is about 3 or 4 years old
Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start -
by sam_sam_samRight now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
https://batteryhookup.com/products/3...ttery-with-bms
These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue... -
by sam_sam_samhttps://www.ebay.com/itm/405035016711
I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
- Loading...
