Turning on and off AC MR16 LEDs with logic level DC
    • Jul 2011
    • 6064
    Re: Turning on and off AC MR16 LEDs with logic level DC
    Originally posted by redwire
    Tore apart a Philips MR16 LED bulb. I busted it up a bit because of the glass housing and silicone glue.
    The main board has a bridge rectifier and 270uF 30V filter cap with AL8821 boost-converter for MR16 LED's.
    The bulb has a 20V COB LED with current control SOIC-8 PLD1B/H1A01A and 0.75R current-set, on the heatsink. I'm not sure what that is for. It's a two-pin connector between the boost and LED board.
    This is different from the ones that I have taken apart
      • 31196
      Originally posted by budm
      Can you please provide the link to that info?
      Resistive load (non inductive resistor, lamp (PTC)): An RMS voltage produces the same heating effect as a the same DC voltage.
      it was on eevblog a while back, it was part of a discusion of hallogen lamps burning out much faster on dc supplies vs the ac electronic transformers / toroids.
        • 31196
        nice led,
        makes me want to go look at these lights at £-land with the intension of stripping them!
          • Jul 2011
          • 6064
          Originally posted by stj
          nice led,
          I was thinking the same exact thing when I saw the insides of that LED module
            • Jul 2011
            • 6064
            When and where did you buy them from
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Ah interesting, I was thinking these LEDs were buck converters but a boost converter would be equally a legitimate solution...
              Now whether the rectifier can stand 100% duty cycle DC is the next question...
                • 31196
                it will be 1A atleast.
                as for dc/ac the frequency of mains really isnt fast enough to make a difference to the diodes current handling.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Well, if they are all 1N4001s that support 1A continuous, a bridge, two of the diodes would be conducting half of the time. So the average current for each of the pairs would be only half amp as they would not be conducting half of the time, and the RMS power dissipation would be 0.7V * 0.5A average = only 0.35W compared to now, 0.7V * 1A = 0.7W - double the power. Plus heat generated could derate the diodes.
                  So it depends on how the rectifiers are made, if they used something other than 1N4001s then it would be better. I saw a couple designs using 1N5820s which would give much more headroom, but the premise is still there.
                    The way the unit is sealed like that, I will doubt that it will properly dissipate the heat.
                    • redwire
                      • Dec 2010
                      • 3912
                      The Philips glass LED MR16 I got at Home Depot. Can't remember if 35W. Their old style has a bunch of small LEDs while the new ones went single COB, across the board in their floodlights and spotlights. The COB sucks because it is very narrow angle and not as bright. But the CRI is the best I've seen. Cree products are no longer in HD stores.
                      I also got GU10 for mains power instead of 12VAC. The Ikea 7.5W 600lm GU10 is also very good but 2700K a bit warmish. 17 leds and also uses bridge rectifer.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Well, the GU10 is completely different, it's more akin to A19 bulb systems, which we're forced to use isolation anyway and thus making this thread go off a tangent by eliminating the H-tree and open collector/drain solutions...
                        The 1G Soraa MR16 has a single very bright unit AFAICT. It's a 50W replacement and is significantly brighter than a 20W halogen MR16 that I have. I also have another newer MR16 LED which also claims to be a 50W replacement - it is very bright too, but just a tad dimmer than the Soraa but uses less power. I can't really tell the light output difference without a light meter. Both have similar beam output.
                        • redwire
                          • Dec 2010
                          • 3912
                          I think all AC-powered LED bulbs use a bridge rectifier up front, so DC operation would be possible. "dimmable" verses "non-dimmable" is an issue.
                          Soraa: "Works with trailing edge and leading edge phase cut dimmers, 12V AC magnetic and electronic transformers and 12V DC transformers"
                          Are you wanting to use AC or DC to power the LED bulbs?
                          I think the options so far:
                          1. Use a relay or triac on primary or secondary of the step-down transformer
                          2. MOSFET SSR on secondary
                          3. Use a BJT/MOSFET after a rectifier giving DC to the lamps.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            "12V DC transformers"... hah.
                            Well that's the question post in the original post, suppose I had both 12VDC and 12VAC available, which is the cheapest (primary goal; also considering damage to the LED lamp module if DC can damage the rectifiers due to 100% duty cycle) and correspondingly most efficient way (in terms of power waste) as a secondary goal to power and control them.
                            I'm just a bit concerned because the lamps do not explicitly say AC/DC, they just say AC.
                              • Jul 2011
                              • 6064
                              The problem is you do not know if it has just one diode or it is a bridge rectifier unless you take it apart and look
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                They're bridges for sure, since I can turn the DC around and it will still light!
                                • Pipolups
                                  Corsair K70 LUX RGB dying LEDs
                                  by Pipolups
                                  Hi there !
                                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                  10-08-2024, 11:58 AM
                                  Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
                                  This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  09-06-2024, 08:00 AM
                                • ohren
                                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                  by ohren
                                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                  The models launched in 2018 and 2019 respectively....
                                  09-08-2023, 05:24 PM
                                • korben_dallas
                                  Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                  by korben_dallas
                                  Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                  I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                  I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                  MY QUESTION:
                                  I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                  02-14-2024, 12:23 AM
                                • Yanleb
                                  LG 60PK550 Logic Control Board EBR63450301
                                  by Yanleb
                                  Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                  The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                  But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                  All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                  C57: 3.30V
                                  C61:...
                                  07-20-2023, 12:38 AM
