Isotech ISR440 Scope lives again maybe.
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    This is the oscillopscope I recently bought to fix my Viglen computer monitor (on another thread). Well after being shown it turned on and a sort of pattern on the screen, I was assured by the seller it worked fine and just needed new probes (it came with none).
    Well it didnt work and I spent a half hour on the phone with him trying things he suggested. In the end the dispay failed completely and the guy apologised and refunded me.
    Well why I was waiting to get another one I thouight I have nothing to loose now and stripped the scope out completely inspecting everything. Straight away I noticed lots of signs of it being in a very damp place and eveven a bit of muddy dust in it. I could even see signs of water ingess on the PCB in some places and water marks & ring marks around solder pads and the solder gone grey. So I cleaned up the board & resoldered all pads like this and gave all switches a clean out with servisol switch cleaner. Well after I put it back together it seems I have it working. I have a line or dot depending on how I adjust focus and intensity etc moving fast or slow across the screen from left to right which I can speed up or slow down.
    Does this sound like its doing what it should do?
    I'm going to use the other scope to fix the monitor but this is a bonus if ive got it working again.
    • 31277
    Re: Isotech ISR440 Scope lives again maybe.
    sounds good, you want the sweep fast enough for a continuous non-flickery line.
    if you have a slow dot you can get screen burn.
    connect a probe and hook it to the test point - then play with the input settings
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      If you have your time/division down below 50ms or so, yeah it would look like a dot moving across the screen... and it should be a dot if you focus it. Getting a line may mean an astigmatism problem but if you can focus it to a dot when the setting is 100ms/div that's what it should look like.
      • roadrash
        • Oct 2015
        • 490
        • U.K.
        Had a sort of square wave form when trying to calibrate to probe. couldn't get it to stand completely still and it scrolled across screen.
          • 31277
          that#s the trigger settings
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            twiddle the knobs like you know what your doing and see if you find one to get it steady .. some pull out for user calibrating .
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              Yes, not triggering properly.
              On easy way to get that is if the trigger channel is not being used as the probe channel (wrong trigger input).
              Dang, I loaned out my fully analog scope, need full pictures of other peoples scope now to refer to; my Tek 2465 is a bit more complicated than necessary compared to most other analog scopes...
              • repair-it
                Need advice testing a samsung power supply board with scope
                by repair-it
                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                07-12-2025, 11:00 AM
                Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
                by sam_sam_sam
                I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
                https://www.aliexpress.us/item/32568...3333736563%21s...
                04-12-2025, 10:24 PM
              • EasyGoing1
                Reading input and output of bridge rectifier on the same scope?
                by EasyGoing1
                I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                06-26-2022, 12:52 AM
                new (old) scope
                by stj
                Metrix OX-8627
                100Mhz dual-trace digital storage CRT scope.
                all controls are digital and it has full remote via IEE488 bus
                very fucking rare and hard to find any info on
                some pics after a recap using about 90 new caps!!
                06-02-2024, 08:47 AM
              • definitely not an expert
                Metex MS 2000 handy scope
                by definitely not an expert
                I have been given a metex ms 2000 handyscope to use for fault finding.
                It works but the 30 year old battery pack is no good, i have purchased the new correct batteries, tryed to put it all back together but couldnt get get continuity between the four 1.2v batteries, upon checking one of the components, a thermal fuse has blown i think.
                now the issue is that I dont know what the part is, how to work out what it is and were to buy the components.
                Im looking forward to getting it going so if anyone could help that would brilliant, and would certainly make my...
                05-08-2025, 07:41 AM
