What are these battries ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    ^^^^^Spelling fail
    Good day folks. Nice and straightforward here: my Braun electric shaver which I've used for the past 5-6 years could definitely do with some new batteries since they're on the wane after such a long time and I feel the need to recharge it a lot more often.
    After a lot of effort, since it's waterproof and sealed very tightly, I managed to finally crack the shaver open and get to the batteries buried deep inside. Being that it's a fairly modern device, I was expecting to find a lithium battery in there, but instead I was met by THESE....I though "ok, simple enough. AA NiMh batteries, but then I had a closer look at them and there's a catch: literally, there's a catch at each end They're the most bizarre things ever and as far as I'm concerned they may very well exist in just this one device only. The cell has got two little nipples at each end which engage with some clips in the holder to hold the batteries and also make contact. Outside of that, they're identical in size to AA batteries, but I just couldn't come up with a good (enough) idea of holding them in there, because there's no springs like in normal AA holders - they rely solely on those metal "snaps" to hold them in there, so a regular AA would just fall out, even though I'm sure it would work just fine electrically. I was thinking of shoehorning a washer or something in there, but it wouldn't stay put...my local electronics store WAS able to identify these cells and source them for me, but the price was rather high and I wasn't sure it was worth it, so I thought I'd do some digging on my own. There's no specs on them either (as far as I remember at least, because I don't seem to have taken any pictures all around the label and I'm only assuming that's because there was no info in those areas).
    Any ideas as to what these are ? I HATE it when they do stuff like this just to force you to throw away a perfectly good device. I CAN use it with the adapter, but what's the point ? I don't have an outlet in my bathroom and certainly don't want to lug an extension cord with me when I travel....damn crooks :|
    Wattevah...
    • 20933
    Re: What are these battries ?
    You could try a stainless steel rivet,riveted through a washer ,then solder it on .
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      You mean solder it to the batteries ? Wouldn't that be *ahem* "not recommended" ?
      Wattevah...
        • 20933
        Its ok if you don`t leave the soldering iron on it too long, and do the soldering in a safe place and take a few precautions.
        • mariushm
          • May 2011
          • 3799
          Meh... you could just just get a AAA rechargeable battery and solder wires to each end and inside the device.
          700mAh vs 1500-2000mAh ... it will have long enough charge to last a shave.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            I could do the same with AAs then...even better. All I care about is capacity and not having to recharge them so often.
            Wattevah...
            • redwire
              • 3910
              I haven't seen those oddball battery pins before. I would try pry them off, they don't look spot-welded.
              For my shavers, I solder wires on AA Eneloop Pro 2,500mA batteries.
              Just use flux, pre-solder the wire ends and use the least heat possible, do it quickly to not melt the internal seal.
              The shaver has been great, maybe too good. New battery internal resistance must be lower or because I oiled/greased it up. It runs must faster so I added a little resistor to slow it down- shaver burn hurts. Who needs 7,000RPM?
              Older Brauns have a "poison pill" so that you can't reuse the shaver after opening the case. A metal pin falls down and jams the cord-jack so you can't use it
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                The one I got (thankfully) only gave me a hard time opening it because of some very tough clips, but other than that there's no "anti-servicing" mechanism.
                It also uses a constant current circuit (?), so no matter how high the input voltage is, the motor always runs at a constant velocity. Conversely, when the battery is low, it still runs smoothly and you never actually hear it getting slower. There's a battery monitoring circuit in there which just shuts it off and prevents you from turning it on again until you charge it when the battery gets too low (a red LED also flashes to indicate why it wouldn't turn on). It's been doing this a lot recently: in between passes, when I stop to rinse my face, the shaver would suddenly decide it's had enough and wouldn't turn back on again, even though it wasn't showing any signs of slowing down a second ago, so I have to trick it by briefly plugging in the charger and then going back to the washroom to pick up where I left off....
                Wattevah...
                  • Jul 2011
                  • 6039
                  Do you have or someone that has a battery spot welder you just need to remove the button on the old battery and reuse them with the new battery and you can use AA Eneloop Pro 2,500mA batteries or any good quality batteries
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    pull nipples off old ones then place onto new ones ..might not even need soldering or welding .
                      • 31026
                      same, but i get my loops from ikea - rebranded:LADDA
                      they are half the price!
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        grow a beard ...
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          That looks like the replacement I used in my Panasonic ES8243 shaver
                          Got it from www.akku-wechsel.de
                          Mine seems to be a standard 14500 with the extra nipple each end
                          I'm now using the original battery, with nipples removed, in a flashlight which uses a 14500
                          better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                            • 31026
                            14500 is a lithium code, these are NiMH.
                            • petehall347
                              • Jan 2015
                              • 4426
                              • United Kingdom
                              https://www.fix.com/parts/shaver-raz...C-aa-67030923/
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                https://www.aliexpress.com/item/Orig...571562600.html
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  There you go....the prices are STILL too high, so I'd be better off hacking something with some more "reasonably" priced NiMhs.....
                                  Wattevah...
                                    • 31026
                                    go to ikea.
                                    • redwire
                                      • 3910
                                      Ikea Ladda 2450mAh are $2.50 ea. in Canada and 34,90 lei/4-pack in Romania. I don't see them for sale at Ikea USA. I'll give them a try.
                                      I get Eneloops on sale with the charger kit (about twice the price $5 ea.) so now I have a million chargers lying around.
                                      Men's shavers are such junk now, it makes sense to repair them.
                                      Braun's shavers MSRP over $300 now, $60-$70 for blades and the foils
                                        • 31026
                                        yea, shavers are the new dyson vac cleaner as far as prices are concerned!!
                                        what pisses me off is they cost so much and they still put low capacity cells in them.
                                        phillips use 700mA cells in AA format.
                                        wtf - the weakest loops are 1000mA i think.
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • howardc64
                                          Where do repair shops buy MB replacement batteries?
                                          by howardc64
                                          Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                          Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                          BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                          07-25-2024, 10:42 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • dbuergi
                                          DIY: Modified smart charger for all types of batteries
                                          by dbuergi
                                          sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                                          Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                                          My first work was to bring my Samsung watch battery back to life with was not recognized...
                                          07-18-2025, 03:17 AM
                                        • davidebaldini
                                          UPS ruins batteries every three months
                                          by davidebaldini
                                          Problem description:
                                          My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                                          UPS model:
                                          The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                                          10-02-2019, 06:19 AM
