What are these battries ?
  • Rulycat
    • Apr 2010
    • 724
    Re: What are these battries ?
    Originally posted by stj
    yea, shavers are the new dyson vac cleaner as far as prices are concerned!!
    what pisses me off is they cost so much and they still put low capacity cells in them.
    phillips use 700mA cells in AA format.
    wtf - the weakest loops are 1000mA i think.
    Poundland sell 2 x 800mAh AAs. Penny pinching where you can't see it.
      • 31259
      i bet those are 1st gen, not LSD (low self discharge)
      1st gen NiMH drain over a few months, LSD can stay charged for years!
      • brethin
        • Dec 2008
        • 1907
        I just use enloops and stick tiny super magnets on each end for my shaver, works fine.
          • 31259
          that wont work in any shaver i'v been in, the wires hold it in place.
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • howardc64
            Where do repair shops buy MB replacement batteries?
            by howardc64
            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
            07-25-2024, 10:42 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • dbuergi
            DIY: Modified smart charger for all types of batteries
            by dbuergi
            sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
            Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
            My first work was to bring my Samsung watch battery back to life with was not recognized...
            07-18-2025, 03:17 AM
          • davidebaldini
            UPS ruins batteries every three months
            by davidebaldini
            Problem description:
            My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
            UPS model:
            The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
            10-02-2019, 06:19 AM
