Building a solid state relay module
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    So they sell these on Amazon pretty cheap:
    I looked at the different pics that they post from different angles and I got all of the values of the components on the circuit board, but I'm obviously not exactly sure what the schematic would look like so I came up with this:
    But, I'm not exactly sure that it will work, or even if my configuration of the components makes sense in terms of a "stable" circuit given the desired function of it ... I have all of the components but I'm wondering if anyone can take a quick look at my schematic and offer any comments? The power source is 5V
    sigpic
  • R_J
    • 9623
    Re: Building a solid state relay module
    Here is a similar device with schematic http://wiki.sunfounder.cc/index.php?..._Trigger_Relay
    Solid state relay using a mechanical relay?
    These are SSR as an example
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Interesting ... ill play with it on a breadboard and see what I can come up with.
      Thank you!
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        So here's something interesting ... on the other side of the relay, I have a separate 6v source connected to a resistor and an LED ... and when I bias the transistor, the relay switches on and the LED lights up through that separate power source, but when the transistor goes off, the relay doesn't open ... its like it just stays latched ... even if I disconnect the input of the relay and bring both pins to ground, it sill allows current to flow through the relay until I disconnect one of the output pins, where it will stay disconnected until the inputs of the relay are brought high again. I have several of those relays and I tested a few of them and they all exhibit the same behavior.
        sigpic
          What is the spec of the relay/ What is on the output side TRAIC, SCR, Transistor? If they are TRAIC or SCR, they will latch on since those kind of outputs are made for AC.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            I just did a google and apparently the relay requires the voltage at the output to go to zero before it switches off ... so it can only drive an AC load
            sigpic
              Yep.
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                I wonder what would happen if I used it to switch on a circuit that is pulse width modulated ....
                sigpic
                  Current has to drop to 0 (or Less than Holding current) for it to be off.
                  https://cdn.badcaps-static.com/pdfs/...758642a941.pdf
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Current has to drop to 0 for it to be off.
                    which would the be the case with PWM ... although the frequency is much higher than an standard 60Hz AC signal ... wonder how fast those triacs are
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Didn't work ... at least not with an arduino PWM source from an analog pin
                      sigpic
                        You need SSR DC output (I.E. MOSFET) if you want PWM output.
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          A potentially interesting find ... if I use an analog pin as the PWM source to the LED, and then open the relay, but immediately after opening the relay, I tur that pin off then back on ... it still remains powered (it keeps the triac latched) so I started playing with delay times between turning that pin to 0 and then back on and discovered that if I delay by as much as 12 microseconds ... it stays latched... but at 13 microseconds, it trips the triac and breaks the circuit ... so at least we know it takes somewhere between 12 and 13 microseconds to break the triac connection.
                          sigpic
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            What do you mean SSR DC output? you talking something like using a 555 with a MOSFET to generate the pulse?
                            sigpic
                              They make SSR with MOSFET on the output side.
                              I.E. http://www.ssousa.com/MOSFET-Output-SSR
                              Also Look at CRYDOM again, see what DC output is.
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                I see what you're saying ... I was just going to google to see if they made DC load capable SSRs
                                sigpic
                                  It is right there in the link, it can handle AC and DC, or DC only.
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    Depending on circuit topology. you can fashion an AC/DC SSR out of a bridge and a "switch". The bridge ensures the switch always sees the same polarity signals across it. But, this increases the drop across the SSR.
                                    • AlexVG
                                      Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                      by AlexVG
                                      I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                      I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                      (This board does not respond, only the LEDs light up in a circle.
                                      The liquid damage is catastrophic and restoration is impractical).
                                      (I bought this board to get the WiFi module and camera).
                                      The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                      If...
                                      10-22-2024, 07:20 AM
                                    • repair-it
                                      TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                      by repair-it
                                      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                      10-11-2023, 07:18 PM
                                    • CoinCoin88
                                      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                      by CoinCoin88
                                      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                      09-15-2025, 03:36 AM
                                    • jm1234
                                      9V relay temperature 40C
                                      by jm1234
                                      Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                      I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                      05-09-2024, 03:03 AM
                                    • m1ch43lzm
                                      70mai Dash Cam A510 - help identifying connector on camera module
                                      by m1ch43lzm
                                      Hi everyone
                                      I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                                      The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                                      I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                                      05-11-2025, 06:02 PM
