QFP128 desoldering / rework question
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have to change a QFP128 chip for a repair I am doing. I've replaced 48 pin QFP chips (such as AS-15) before a few times but never a QFP128
    With the AS-15 I basically add some 60/40 solder to the pins all around to reduce the melting point, apply flux and use the hot air station to unsolder.
    I then use drag soldering with 60/40 and use flux plus desolder braid to clean up the shorts between pins and a jewellers loop for close examination of the work
    I was thinking maybe of trying the same technique on the QFP128 but maybe to use something like Quick Chip low melt solder
    Just to make things more complex this is a double sided PCB with a lot of SMDs on the other side underneath where the qfp128 is
    Any suggestions?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8203
    Re: QFP128 desoldering / rework question
    cut off all the legs with an exacto knife or dremel tool, then take the legs off the PCB with lots of leaded solder and solder wick? It all depends on how much room you got.
    • R_J
      • Jun 2012
      • 9552
      I agree with the above, most damage occures trying to remove a bad ic all at once, just be carefull not to cut any traces
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        To be honest I used the technique of cutting off all the pins a lot when working on through hole with internal ground plane / layers / vias and found that is the best way of working on those boards
        With SMD DIL or QFP I found that coating the pins with flux then applying a liberal amount of 60/40 to all sides of the chip with a soldering iron (so effectively I have one area of solder on each side, all pins shorted together) then using the hot air station to desolder works very well
        But as I mentioned i never tried on something with so many pins as QFP128
        What got me wondering about using very low melting point solder alloy was videos such as this one https://www.youtube.com/watch?v=ezYcYF94_k4
        That looks like a good bit of kit - a bit expensive but not stupidly so.... if you do this for a living. But I would think a cheaper way to heat the PCB would work just as well, its mostly down to reducing the melting point of the solder
        I never tried this Quick Chip stuff before though and it seems expensive to me. Anyone used that or can suggest a cheaper alternative? There are products such as this on ebay https://www.ebay.co.uk/itm/Low-Melt-...4AAOSwEK9UEZBr and others that seem similar and are a lot cheaper but are they any use for this sort of work?
        • NCSailor
          • Mar 2016
          • 9
          I would be hesitant to cut the legs... Too easy to cut any tracks that run from the pad under the chip.
          Chip Quik is a little expensive but it works and it is a lot cheaper than replacing a damaged PCB or at a minimum repairing some pads and tracks.
          I suspect that some of the other low melting point products work also, but the Chip Quik kit https://www.chipquik.com/store/produ...ucts_id=210001 comes with good flux and a proven product. It is enough to do quite a few chips and good to have on hand.
          • llonen
            • Sep 2014
            • 495
            • hampshire
            I used to use a generic low melting point solder which was the same as quick chip, which I purchased by the roll until I invested in a half decent hot air rework station (Hako FR802) when I am back at the workshop later today I will see if I can find what solder I used to use.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Hey that would be useful info if there is a cheaper alternative that does the same job.
              Actually CPC/Farnell Have the chip quik kits in stock for just over £10 + VAT and free postage on orders over £8 in the UK. So I think I will order some and give it a go - my missus is back in the UK this week so she can bring over to me
              One thing I'm a bit confused there is a SMD1 Chip Quik kit and a SMD1NL Chip Quik kit for very similar price, the NL being the lead free one.
              As Chip Quik is meant for desoldering not for soldering, is the NL kit supposed to be better for removing components from lead free boards, in as much as it works better on higher melting point lead free solder, or is it just intended not to leave traces of lead on the board after rework - if you were bothered by that sort of thing?
              Rich
              • llonen
                • Sep 2014
                • 495
                • hampshire
                Right you are looking for commercial solders that contain the following
                51%In / 32.5%Bi / 16.5%Sn (60°C eutectic)
                66.3%In / 33.7%Bi (72°C eutectic)
                57%Bi / 26%In / 17%Sn (79°C eutectic)
                54%Bi / 29.7%In / 16.3%Sn (81°C eutectic)
                This site are the one I have used in the past
                https://www.somersetsolders.com/sear...%20Temperature
                https://www.somersetsolders.com/tin-...der-paste/p195
                A little more expensive than I recall, but they used to do smaller quantities. The main problems I used to find with this stuff amongst others it used to leave a hard to remove deposit which I found would interfere with subsequent soldering / rework.
                Hope this is helpful
                  master hoarder
                  • May 2008
                  • 12175
                  Just use your hot air station to unsolder the chip. If board is "extra tough", put it on a grille atop your kitchen's stove top / burner, and put the heat to low (both gas and electric burners are okay). Let the board heat on the bottom for a minute or two, then blast the chip with your hot air station from top. The solder should melt a little quicker and the chip should come out easier. Just make sure you don't try to pull the chip with the solder still not melted, as that can pull traces out. One thing I do to avoid that is I give the chip a little nudge when I think it has reached temperature. If the chip moves easily on all corners, it's ready to go. If any corner feels stuck, keep heating a little more (or crank up the temperature a little bit).
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
                  • corrize
                    Best way to solder LVDS connector for beginner (and qfn) ?
                    by corrize
                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                    See the test :
                    https://youtu.be/bNAzC-EvqHs?t=1767
                    With hot air from bellow the board, that's...
                    03-09-2023, 02:57 AM
                  • myth77
                    UV solder mask - high temp resistent, recomendation?
                    by myth77
                    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                    Is there any solder mask...
                    03-28-2022, 04:04 AM
                    03-31-2024, 02:12 PM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
