Friwo EC205 battery charger at 60Hz?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Weird, any of you EU'ers know about Friwo?
    I happened to get one of these EC205 chargers, it has the two-pin plug.
    For grins I tried hooking it up to my recently acquired 750VA "chinesium" step up autotransformer (complements my 250VA French brand (Sabir) unit I guess). Both of them are around 230V-ish AC output, and of course at 60Hz because I don't have a VFD.
    Well anyway, I had three NiMH cells in it and let it charge up. After many hours I checked this unit.
    WOW THIS THING GOT HOT!
    I wonder if it's because I was running it at 60Hz or because this thing is a piece of excrement? I think it's still working however.
    Anyone know about these units? The charger has German and English text on it, but the plug looks like UK due to thinner prongs, but I suspect DE plug looks very close.
    • 31277
    Re: Friwo EC205 battery charger at 60Hz?
    u.k. does not use 2pin, other than old shavers - with fat pins.
    i know the plug your talking about, it's used in places like italy a lot and will fit in a schuko socket - badly.
    does it contain a linear transformer, or is it a switching psu?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Strange, then what is used in the UK? This device has a two prong and a squashed hexagon plastic piece that the prongs extend out of... It's weird to me that it has both German and English written on it, but omitted the countries in between... I'll need to find or get some pictures up I suppose.
      Not sure what it has since I haven't opened it yet; it feels dense enough it could have a linear (which should be fine at 60Hz) but it's not THAT dense. Since it appears it can charge AA cells individually I'm not sure what it has. I haven't opened it because it uses tri-wing security screws and I can't find my security bit set.
      Can't tell how old this thing is either but I would guess no older than around 20 years, might be younger. I don't see "Made in China" anywhere which is odd...
        • 31277
        british "shaver" plugs have fatter pins.
        pisses people off when they try to use a "travel adapter" and it wont fit - they have to buy a "shaver adapter"
        a linear transformer may run hotter at the wrong frequency, but a switching psu wont care because it just rectifies it to dc.
        infact it may run at 110v even if it's not marked on it.
          • 31277
          btw, as far as age - they are on sale on amazon - i searched the part number.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Does not appear to be a current model as it doesn't show up on Friwo.de website...
            Since Friwo is still in business, it shouldn't be that crappy of a device?
            Strange though it is designed for 50Hz, at a higher 60Hz frequency, a linear PSU's transformer's core shouldn't saturate. I would imagine it too is a laminated steel core, but can't think of why there would significantly be more eddy current losses at 60Hz.
            Haven't tried it running at 120VAC yet...
              • 31277
              i suspect it's a switcher in it.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                RUBBISH! This thing is rubbish!
                It's linear, not switching, tiny little iron core transformer in it!
                Gar-Bage! Nothing worth salvaging in this, just those tri-wing self tapping screws if even...
                I wonder what to do with this thing, likely belongs in file 13...
                  • 31277
                  well if you need a charger, and dont need 9v.
                  i recommend a Liitokala Lii500-Engineer
                  https://www.banggood.com/LiitoKala-L...-p-999106.html
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    Nah, no big need for it, it was just something I had that I could test the step up autotransformer without blowing
                    Probably could also try the autoranging wall warts too, but the charger was obviously designed for 220V. I could also plug the other autotransformer into the autotransformer and see if regular devices work...
                    ... or something can completely blow up at 480V
                    Pictures added for your viewing pleasure or pain, depending on how it's viewed
                      • 31277
                      i like the last option!
                      maybe re-charge some old batteries at 480v!!!
                      it should handle it, the diodes and resistors wont go over-voltage!!
                      battery BOOM-time!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        I do wonder if these autotransformers can hold 480V without arcover or not.
                        Seems like it's very possible to select the wrong voltage, is the expectation to destroy fuses, the autotransformer, or the downstream device?
                          • 31277
                          well, the transformer is just a divider/multplier, so as long as the laq is thick enough to prevent the windings arcing, they wont care.
                          that charger is outputting about 1.5v so if you double it your outputting 3v and that wont harm the diodes or resistors.
                          so i suspect other than a bit more heat, your just going to cook some batteries - got any old alkalines?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            Right, I was wondering how sturdy the (autotransformer) voltage converters were, if you accidentally set the voltage input wrong and plugged it in. I would suspect people in the 220V areas would have more experience setting the autotransformer input to 120V and plugging it in, theoretically resulting in that 440-480V
                            Alas for us puny 120V'ers, we only can test the lower winding for sturdiness (drawing more current out of the secondary output just causes more strain on the input winding/core...)
                              • 31277
                              autotransformers are rare in europe,
                              very few people have japanese (100v) or u.s. imported electronics.
                              our industial powertools are 110v for outdoor safety,
                              but they run through a fully potted isolation transformer with a 55-0-55 output with the centertap bonded to earth.
                              so the wost that can happen is you get a 55v shock.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                I suspect there are laws that force the manufacturers to prevent people from connecting those isolation transformers backwards?
                                  • 31277
                                  no, we have freedom to kill ourselves.
                                  just as long as it's intentional and cant happen by accident.
                                  which is unlikely!
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8706
                                    The autotransformers that I have indeed can be set in the wrong direction... so why these and not that... (plus the fact autotransformers are not isolated!!!)
                                      Auttransformer can be used as buck or boost I.E. like the way they used in the UPS that has AVR and there is no need for isolation since the Neutral in goes directly to the Neutral out, it has its use and purpose. VARIAC is basically variable AUTOtransformer
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8706
                                        Right, alas, I was wondering if you had an autotransformer in a 220V area and you set the input to 120V with 220V going in, what's the chances you get
                                        1. 440V out
                                        2. Molten piece of copper, steel, and fire mess when the insulation arcs over...
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
