Re: Any way to improve distance of toy remote control car?
Are you sure that's an antenna, looks like a grounded shield for the PCB? What's it look like on the other side of the PCB?
I used to get upto 40 meters on similar rc stuff in the past outside mind you, so look at the transmitter crystal then check with a frequency counter and look at the amplitude with a scope see whats coming out.Leave a comment:
Finally had some time to take this thing apart and check out the antenna. It’s just a square piece of paper with a shiny side that’s connected to the antenna wire. Other side is non reflective and glued to the plastic.
Could I just replace it with a coiled piece of wire?
That said, I do have one old Tyco RC (called "Jacknife", IIRC) that had an integrated antenna, which basically consisted of a long wire ran along the whole body of the car in a loop. Some years later, I was repairing one for a friend's kid, and that RC had a metal circular loop antenna inside - about 6-8 cm (2.5-3 inches) in diameter. I don't remember what kind of range that one got, but it wasn't bad IIRC.
Anyways, you can try replacing that current "antenna" piece with something else. I'd sat a long piece of wire would do just fine for testing. But if that doesn't appear to do anything, it could be indeed like Sparkey55 mentioned: just bad design. And of course, fresh batteries are absolutely a must with these.
One more sidenote: going by the pictures you posted, your receiver board looks very familiar to one of these on eBay:
https://www.ebay.com/itm/4CH-40MHZ-R.../202425771105?
These are much newer than the ones I have in my late 90's / early 2000's RCs (none of them have SMD components). So I just cannot attest to how good or bad these are. But I can tell you that my older toy stuff with longer antennas didn't perform too bad... save for some of them frying a few BJTs on the motor outputs (at least the ones that came with all TO-92 stuff).
*EDIT*
Talking about toys... I just hit post # 8448. That's the dream LEGO Technic car of my childhood. Ironic coincidence?Last edited by momaka; 11-21-2018, 10:22 PM.Leave a comment:
replace it with a vertical wip, your trying to catch waves, not just match the frequency.Leave a comment:
Finally had some time to take this thing apart and check out the antenna. It's just a square piece of paper with a shiny side that's connected to the antenna wire. Other side is non reflective and glued to the plastic.
Could I just replace it with a coiled piece of wire?Leave a comment:
try a foot-long bit of spring-steel wire on the car.
it's what they used to come with.Leave a comment:
I do not know. Could just be designed that way or may need fresh batteries. Most of these really cheap toys (<$20) skimp on parts needed to "tune" for optimum performance to save a few cents on the Dollar. Cheap 27Mhz or 49Mhz crystals that drift like Trump in a porn cenvention. Maybe a 60Khz to 100Khz or more bandwidth on the carrier. This is not competition grade race cars here.Leave a comment:
Well, then need to know what's expected behavior for this device, should it really be conking out at 10ft?
Not sure if bandages like antenna hacks or preamplifiers should be done to fix an underlying problem like battery weakness or improper tuning.Leave a comment:
No. not the only issue. A more powerful transmitter would help with distance but would swamp the receiver when close by and would not be Part 15 approved most likely. A longer receiving antenna might help try using a small loading coil at the bottom of the receiving antenna or boost the receiver with a pre-amp, but the pre-amp may overload anyway.Leave a comment:
Then the only explanation for the issue is receiver tuning?Leave a comment:
Car antenna can only be so big, a ¼λ antenna is quite huge...
Transmitter antenna also needs to be optimized.
But 10ft seems a bit low unless it's one of those tiny RC cars. They should go 30-40 ft without issues. I'd vote for receiver tuning if the transmitter battery isn't half dead...
... and don't use NiMH in the transmitter. Alkaline!!!
(BTW, 27MHz CB, ¼λ = 9ft. So you're dying at quarter wave away...)Leave a comment:
(BTW, 27MHz CB, ¼λ = 9ft. So you're dying at quarter wave away...)Last edited by eccerr0r; 06-02-2018, 08:34 PM.Leave a comment:
Some of these cars use very small antennas so the kids do not pull the table cloth off the table with it. OMG dinner hit the floor!Leave a comment:
the problem is the car, you need a good antenna on it with the length optimised for the frequency.Leave a comment:
Then all the kiddies with RC toys will wonder why they move in strange patterns...
Look ma, I'm not touching the controller!Leave a comment:
fun with antennas.
It's likely a coiled rubber ducky antenna else it has some electronics to impedance match it inside the transmitter. Replacing it likely won't help.
Transmitter batteries must be fresh. Weak transmitter batteries will do bad performance.
Where are you playing with it? Sure there's no noisy interference around from other possible sources?
Any ideas of other people with the same toy have similar issues? Perhaps the receiver needs to be retuned properly to the transmitter.... though doing so might be a bit tricky or impossible...
Unfortunately as this is a Part 15 device you can't bump power on it...Leave a comment:
fun with antennas.
by tmhobadcapI have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked... -
by piipoHi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much1 Photo
09-18-2024, 01:55 AM -
by hemant_2222Hello Everyone,
Hope everyone is enjoying their repairs at hand!.
I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
Please refer to the attached picture, i think the voltage divider is missing...-
by dfearI have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
It came in for a power issue which I have finally resolved by replacing the power supply.
The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
Anyone have a clue how to fix TV?
FYI: I have checked the remote work s by pointing it at my camera on my phone.... -
by wolf1976hi i have a receiver that is destroyed from the overvoltage i guess
my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
the motor fan has not label
i have an other receiver operational
In your opinion can i measure the voltage at the output ?
what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
thanks in advance... - Loading...
