Do NTC inrush limiters wear out?
  • John843883
    • Nov 2012
    • 71
    After having a TV power switch wear out and arc I'm wondering if its possible for those little NTC inrush limiters to wear out too and allow more inrush current to flow from not acting fast enough or its values drifting over time. The TV is about 8 years old and its a 42 inch CCFL backlit with a large 220uF input filter capacitor, mains voltage is 240v.
    Is this possible or am I barking up the wrong tree?
  • R_J
    • Jun 2012
    • 9607
    Re: Do NTC inrush limiters wear out?
    I have seen ntc's go open but not really wear out. Its likely the switch just went bad, I've seen that before. just a cheap switch.
    • japlytic
      • Oct 2005
      • 2086
      On a related subject, the "on" resistance of PTC resistors will increase to the point where it will be unusable every time the maximum current is exceeded.
      • John843883
        • Nov 2012
        • 71
        Was it a Toshiba TV by any chance or did the switch look like this one?
        Good to know, thanks.
          TV uses NTC for inrush current limiting, not PTC.
          NTC: it will have resistance rating at 25c, this resistance value is the one that limits the current when the TV is first turned on, as it is heated up the resistance will go down.
          Typical values uses in is between 5 ~ 8 Ohms range.
          • evilkitty
            static in speakers and limiting inrush current
            by evilkitty
            I got this amp board
            * https://www.ebay.com/itm/125299680050 (dual TPA3116 amp)
            and i got this boost converter
            * https://www.ebay.com/itm/192032921916 (150W DC-DC Boost Converter)
            i am getting a annoying squeal.static noise out of my speakers
            on a side note turning the volume knob on is tripping OCP/SCP on my PSU, so i need some way to limit the inrush current (the system reboots when the amp is turned on, bios is set to boot on when power is restored)
            the boost converter is powered using 12v and is set to 20v
            would replacing...
            08-13-2022, 10:30 PM
          • em132
            Help: Looking for guru input on upgrading an S12II-based PSU
            by em132
            The supply in question is an unused/"NOS" Antec EA-500 "80-Plus" (not the "Bronze") with Seasonic's early "500W" S12II board. While I don't yet have this supply in hand, I fully expect it to be filled with OST RLS and RLX. I plan to replace these with FR/FS Panos (mostly).
            Of course, I also plan on replacing the big kahuna on the primary side. To that end, I'm currently holding a pageant to determine who'll wear the tiara. Here are the four finalists:
            The ravishing "Lady in Red" is the current crowd favorite, largely...
            03-08-2024, 09:24 AM
          • yohnsee
            Power-one FNP1500-48G repair
            by yohnsee
            Dear forum members,
            I came here for some help with repairing this PSU.
            I have attached every pdf I could find for it. I even contacted ABB (this company bought Power-one back then) and asked for schematics, but they didn't even answer.
            This nice PSU came to me with short on the mains filter capacitors (2 of them were leaking the electrolyte, and caused a short) and it even blew the inrush current limiters. I attach a few photos, so far I have done the following:
            -desoldered all main capacitors, cleaned the mess and digged down to the inner layers to see, if there is...
            04-09-2020, 01:52 PM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • noTurner
            Acer VN7-571G - turning off by itself without warning and doing a restart
            by noTurner
            Hi. I'd like to ask something about one of my laptops, the "VN7-571G", which is behaving abnormally. It turns on and I can use it for a while. I upgraded the hardware of the laptop to be more responsive and reliable, but it turns out that it's not reliable at all. It originally had 8GB of RAM, a 1TB hybrid SSHD and a WiFi 5 card. I upgraded the RAM to 16GB, installed a 128GB SSD and instead of the SSHD, I installed a normal 2TB HDD for files. So far so good. Then I cleaned up the fans and replaced the thermal paste with some fresh Arctic MX-4. Proceeded to upgrade the WiFi card and installed...
            11-23-2023, 06:43 AM
