static in speakers and limiting inrush current
  • evilkitty
    • Nov 2017
    • 299
    I got this amp board
    * https://www.ebay.com/itm/125299680050 (dual TPA3116 amp)
    and i got this boost converter
    * https://www.ebay.com/itm/192032921916 (150W DC-DC Boost Converter)
    i am getting a annoying squeal.static noise out of my speakers
    on a side note turning the volume knob on is tripping OCP/SCP on my PSU, so i need some way to limit the inrush current (the system reboots when the amp is turned on, bios is set to boot on when power is restored)
    the boost converter is powered using 12v and is set to 20v
    would replacing the 4 chong 1000uf 35v caps with UFW1V102MHD would fix the static? what about just using a/some 10W resistors, i have some 5 and 20 ohm ceramic cement resistors on hand, should i replace the caps on the boost converter?
    maybe i can just put a 5 ohm resistor on the 12v feed, i assume the resistor will not blow up with the momentary ~30W load as i assume it would need to heat soak before it would melt or blow like a 0 ohm resistor used as a fuse
    I have attached a document for my power supply
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: static in speakers and limiting inrush current
    So, have you talk to these people? https://www.arduino.cc/
    • evilkitty
      • Nov 2017
      • 299
      I started getting some very odd behavior while testing some stuff and either i reversed the input power or one of the caps on the boost converter up and failed, i swapped in my spare and put 3 20 ohm resistors in parallel (should not be able to pull over 24Watts), now i only have a little static when the speakers are not playing audio
      probably should not use both black and white wire when you work with both AC and DC
      same static with external power brick as i get with my psu
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I believe in forgetting the color code as it changes with what project one is doing. Create your own color code maybe with flamboyant color like pink and purple.
          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
          The bq24745 features dynamic power management...
          10-23-2024, 02:50 AM
          MT3608 Step-Up Converter IC Datasheet
          The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
          Internal soft-start results in small inrush current and extends battery life.
          The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
          10-07-2024, 05:02 AM
          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
          I tested the battery cells there are installed right now and they are testing good with no issues that I...
          02-04-2025, 08:08 PM
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
