Acer VN7-571G - turning off by itself without warning and doing a restart
  • noTurner
    • Nov 2022
    • 61
    • Austria
    Hi. I'd like to ask something about one of my laptops, the "VN7-571G", which is behaving abnormally. It turns on and I can use it for a while. I upgraded the hardware of the laptop to be more responsive and reliable, but it turns out that it's not reliable at all. It originally had 8GB of RAM, a 1TB hybrid SSHD and a WiFi 5 card. I upgraded the RAM to 16GB, installed a 128GB SSD and instead of the SSHD, I installed a normal 2TB HDD for files. So far so good. Then I cleaned up the fans and replaced the thermal paste with some fresh Arctic MX-4. Proceeded to upgrade the WiFi card and installed a Intel WiFi AX200, which works perfectly fine as well. But..
    The laptop turns off for some reason as if it would not get enough power. The battery was old so I got a brand new battery to replace that as well, but yesterday it did the same thing again! Even with the new battery.. And it ridiculously showed me 76% of battery wear level after turning off and and on again! (which was the same wear level it had with the previous battery, but sometimes it showed 13% as well)
    And now the laptop simply does not work reliably. It simply shuts off without any warning. Just like it would be a restart, but without warning. I don't really know what to do next. I didn't damage anything on the board as I'm sure that I have disassembled 800+ laptops, for repairing and/or cleaning the inner parts etc.. But I don't have any information on what could cause that issue. I mean.. if it would overheat, it wouldn't turn on again instantly after it shuts down, right? And why does it still think that the battery is "bad"? The battery wear level fluctuates from 0% to 75%, this is really the first time I'm experiencing something like that.
    Do you guys have any ideas or did some of you experience a similar issue?
    Then please let me know!
    Regards,
    Emre
  • shouri
    Dell latitude e5490 auto restart
    by shouri
    Hi guys, can someone help me?
    I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
    Board model is dm70 la-f401p rev:1.0 2017-09-20.
    At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
    After a few days test, is seems ok.
    Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
    12-10-2024, 09:27 PM
  • alex26
    Samsung Qled QE58Q60 restart
    by alex26
    Hello. I have a Samsung qled model QE58Q60TAU.
    The TV restarts continuously and without an image. If I disconnect either half, the TV does not restart, but in both situations I have absolutely nothing on the display, only the backlight is on. I checked the CKv signals and the rest VGH, VSS etc. I measured them against the ground and between them and found between VGH and VSS a resistance of 106 ohms on the B side of the screen (right). I isolated all the signals on the right side and covered them with scotch tape and absolutely nothing has changed, it doesn't restart but I have no picture...
    12-29-2024, 03:12 AM
  • canhnguyen777mc
    THINKPAD T460S auto restart after shutting down???
    by canhnguyen777mc
    I'm having problems with my Lenovo thinkpad T460s laptop.
    It will automatically restart when shutdown.(uses battery)/
    Using the adapter + battery is ok. But when the adapter disconnected it will automatically restart.
    I tried reinstalling the operating system and testing in the PE environment but nothing changed.
    I think the problem is in BIOS SETUP.
    Can someone help me?​
    11-02-2024, 09:01 PM
  • Sokha Vitou
    Surface Laptop 3 Model 1873 AMD randomly restart
    by Sokha Vitou
    hello everyone. please help i have a surface laptop 3 AMD model 1873 that randomly restart. i don't think it has bad CPU, because when tried to stress test by CPU-z it not restart or has anything wrong, it just randomly restart when normal use ( browser, or watch video....). i tried to replace U6701 and U6702 but don't see any thing change.
    I'm tried to fine any glue on internet but no luck. I'm looking for any advice from you guy please....
    07-03-2023, 08:43 AM
  • jeewantha
    Lenovo Ideapad 300-15ISK No Display After Restart
    by jeewantha
    Lenovo Ideapad 300-15ISK No Display After Restart.
    Then need press & hold power button till all LEDs are off.
    After it press the power button it is power on normally.
    This is always happening when restart laptop.
    Machine Model : Lenovo Ideapad 300-15ISK
    Model Name : 80Q7
    Serial Number : PF0GH4XL
    Board Model Number : BMWQ1_BMWQ2 UMA NM-A482Rev:1.0 2015-09-16
    Please help to fix this problem...
    09-30-2024, 07:56 AM
