Power-one FNP1500-48G repair
  • yohnsee
    Semi-noob
    • Dec 2017
    • 198
    • Hungary
    Dear forum members,
    I came here for some help with repairing this PSU.
    I have attached every pdf I could find for it. I even contacted ABB (this company bought Power-one back then) and asked for schematics, but they didn't even answer.
    This nice PSU came to me with short on the mains filter capacitors (2 of them were leaking the electrolyte, and caused a short) and it even blew the inrush current limiters. I attach a few photos, so far I have done the following:
    -desoldered all main capacitors, cleaned the mess and digged down to the inner layers to see, if there is an other blown copper trace inside (luckily did not find any)
    -soldered in 1 main cap. per side for test (the 7pcs on each side is connected parallel)
    -soldered 2 NTC inrush current limiters in (for test)
    -soldered the 2 PFC coils on the opposite side of PCB, so I have more place to measure (this PSU is really crowded)
    -As doing this, I measured the coils with an ohmmeter, they both showed 0.32 ohm, I hope this means they both are good.
    -The switching FETs are not shorted, they all measure good in-circuit.
    -The PFC driver ICs seem a bit off. I assume they should measure identical values, as the whole build-up seems symmetrical. The one on the upper side has 3.5V on PIN3 (over-voltage protection), the lower side one has 1.5V on the same PIN. I was looking at the application circuit in the datasheet of the named IC (L4981A), and it showed that this voltage should come from a voltage divider inbetween +400V and GND. The same applies for PIN14 (voltage error amplifier), the lower side gives different reading than the upper side. Yet, they all measure the same ohmic values to GND and to +400V when turned off.
    You also can see a TOP224GN, it is the standby circuit, and it works fine. It gives 12V, and it gets to both PIC microcontrollers. I can even communicate with the PSU via I2C, but I can only read. Tried to clear the fault bits in byte 128 and 129, with no success. On the backplate there are pins arranged in 4x5. I shorted the corresponding pins to start the PSU (R1 to logic GND) but it does nothing. Now when I apply mains power to the circuit, the front yellow led turns on, but nothing else. It can mean 2 things, according to the operator's manual: input AC low/missing or PSU failed.
    The rectified mains are present on the main buffer capacitors (310V), but the PFC won't turn on.
    Now I am stuck here, have no ideas. Feel free to chime in. Maybe someone out there has a schematic for it, that would be awesome.
    Cheers, Janos
  • CapLeaker
    Leaking Member
    • 8340
    Re: Power-one FNP1500-48G repair
    The output power rails won’t come on until the PFC starts to work. So check the PFC mosfet and the gate drive circuit. It’s hard to see anything much on these pictures.
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      Dear CapLeaker,
      thank you for the reply. I am aware, that the secondary side won't start, until the PFC boosts the main rectified voltage. I have measured every diode, resistor and capacitor around the PFC controllers, compared both sides, but so far nothing seems off.
      I only attached the photos to give you a picture, how the layout looks like. If anything helps, by taking better photos of a part, I will gladly do it.
      Cheers, Janos
      • CapLeaker
        Leaking Member
        • 8340
        did you have the fans connected?
        • yohnsee
          Semi-noob
          • Dec 2017
          • 198
          • Hungary
          Yes, I only disconnected them for the photos.
          One more interesting fact: I connected an external 48V power supply on the secondary side, and when I tried to power up the faulty PSU, it wanted to turn the fans, but only for a fraction of a second.
          Cheers, Janos
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • c_corr
            Asus P4C800-E VRM issues
            by c_corr
            This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
            This board uses mext ICs and Mosfets in VRM:
            - ADP3180 PWM controller - in 3 phase mode
            - ADP3418 as Modfet drivers
            - High side Mosfets STD38NH02L (from ST)
            - Low side Mosfets STD90NH02L
            Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
            I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
            02-08-2025, 11:59 PM
          • bouny56
            Lenovo E15 Nm-c421 usb-c work only in one side
            by bouny56
            ​Hello
            Laptop E15 I5 10gen
            Mb nm-c421
            I have a problem with the usb-c power dc.
            The motherboard start only in one side of the usb-c
            Replace the usb-c port 2 times same problem
            With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
            Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
            Can the pd controler be the fault ? Or something else maybe ?
            Thx
            02-11-2025, 03:15 AM
          • pb1911nt
            820-4924-A Runs suspiciously slow - what could you measure?
            by pb1911nt
            Hi
            I have now a 820-4924 (with a i7 and 16GB).
            I would like to get the device working again for me.
            The Problem is the Device comes to me with a "dead" ssd. I tested on a other 820-4924 (i5-8gb) board and the MAC OS Installation stopped working with this SSD.
            Well i hope/guess its was a easy peasy Fix - New SSD And its working again.. But No!
            I don't know exactly how the procedure should start. But the LCD panel goes dark - then the "chime"(?!) sound comes and only 2 or 3 seconds later the apple comes.
            it doesn't...
            Today, 08:48 AM
