Hot Air Station - Air Pump Failing
  • Agent24
    I see dead caps
    • Oct 2007
    • 4963
    • New Zealand
    Re: Hot Air Station - Air Pump Failing
    I've not done it, but I have opened other similar pumps (desoldering gun and aquarium air pumps), which were fairly straightforward.
    As madan1 says, these designs are very simple.
    -David VanHorn
    • madan1
      • Nov 2016
      • 682
      • Bulgaria
      Originally posted by caphair
      Is replacing the diaphragms a straight forward thing?
      Totally... nothing to mess up.
      Remove the parts circled in red ( 4 bolts per side + 1 big in the middle ) as a whole, the diaphs are the yellow things, each is held by a bolt and 4 small plastic pins. Keep an eye on the gaskets around the diaphs, cause you might need them ( if you do not have new ones in the repair set )
      Anyone know if these pumps can be purchased assembled anywhere?
      Most likely you can.. still depends on where you live.. of course China is always an option.
      p.s. When you are installing the new diaphs, you might have issues positioning the piston because of the magnets wanting to stick to the solenoids. If you remove the bottom/top plate, you can get the solenoids out and make you life easier
      • caphair
        • Nov 2011
        • 1249
        Thanks madan1 for that. Seems easy enough
        Do you know the name of the pump if I’m trying to find the entire assembly? Curious on price compared to just the diaphragm kit
        • mmartell
          • Oct 2013
          • 3189
          IIRC I found one pump on AliEx but the price was too high to make the repair worthwhile. I could not find the diaphragm kit.
          Hopefully you'll have better luck.
          • madan1
            • Nov 2016
            • 682
            • Bulgaria
            try searching for "soldering station pump", "rework pump", "yihua pump", "hakko pump" etc.
            https://www.aliexpress.com/item/Pull...245511084.html
            https://www.ebay.co.uk/itm/Original-...a/222256079311
            On mine I just cut out the diaphragms from a sheet of rubber. Not really the best solution, but still did the work.
            Here is another "bad diaph." project - https://okelectronic.wordpress.com/2...ion-repairing/
            p.s. I was also not able to find locally, China or EU a pump repair kit.
            • caphair
              • Nov 2011
              • 1249
              #26
              @madan1 What type of rubber did you use? Might go that route. Was it durable enough to get proper air speed?
              Also do you know the type of glue use to secure the hoses at each end? Mine has a white-ish type of glue
                • 31058
                hoses are probably done with silicone sealant.
                get it from a builders shop in a cartridge, or you get ripped off if you buy small tubes.
                • madan1
                  • Nov 2016
                  • 682
                  • Bulgaria
                  #28
                  I did not use any glue for the hoses. Just zip tied them to the nozzles.
                  The rubber sheet I got from a local shop.. it's just a generic 1mm rubber sheet. It's not really the best solution, because it is too stiff, but works for me. I use the air usually for small smd components and do not really need high air volumes.
                  I think silicone rubber sheets will be better.
                    • 31058
                    get a pair of thick rubber gloves and cut them up??
                    • caphair
                      • Nov 2011
                      • 1249
                      #30
                      Today the air flow started acting up and cuts out unless on the highest setting.
                      Sometimes after going to the highest setting and back down it’ll work but not consistent.
                      I measured the ac voltage at the connector going to the pump and when it’s working it steadily rises from 38vac on lowest setting to 118vac on highest.
                      When it cuts out it measures from 28-34vac on any setting except the highest which kicks the pump back on at 118vac
                      Would this be an issue with the pump itself?
                      • redwire
                        • 3910
                        I think it's mechanical stiction in the pump, high friction that needs it set high to get it moving, rotating.
                        • caphair
                          • Nov 2011
                          • 1249
                          #32
                          Would that explain the voltage readings when it cuts out?
                          • redwire
                            • 3910
                            A stalled pump rotor would draw more current and give lower voltage for a given control setting. Once it's spinning, the voltage reading would go up. It's just an AC light dimmer/TRIAC doing the speed control, no regulation. A multimeter with true-RMS will read the voltage more accurately.
                            So I'm thinking the pump is getting stuck and it's not the electronics at fault.
                            But if you suspect the pump speed control TRIAC circuit, you could put a 25W light bulb in place of the motor and see how it works as a light dimmer.
                              • 31058
                              are you sure it's a phase-angle dimmer?
                              my old station had a 555 timer driving the triac.
                              • caphair
                                • Nov 2011
                                • 1249
                                #35
                                I’m honestly not too familiar with the two types or the operation of these units. What should I look for to determine? Here’s a pic of the unit.
                                Does the hot air heater run straight off the mains and the soldering iron off the 24vac tap?
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  #36
                                  Do these diaphragms look bad?
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    #37
                                    I connected a 40w bulb (lowest wattage I had) across the motor terminals and it lights but dimly and doesn’t increase in brightness with increasing air speed knob, only when on full air speed does it get brighter.
                                    So seems like a controller issue. How would I go about figuring out the problem? Weird that sometimes it works. I tried gently tapping on components when it’s acting up hoping maybe a bad solder joint but it had to affect
                                    • redwire
                                      • 3910
                                      I think this YH852D+V2 pump is mains AC powered, with other 852D+ variants instead using the 24VDC wand blower fan. Here I see three triacs, two opto-couplers, one DIAC.
                                      The AC triac controls are 24VAC to the soldering iron, the other for switching mains to the hot air heater, and last one Q7 for phase-control switching (what I think is) AC mains to the pump. I might be wrong but I think it's a fish-tank kind of pump so it needs AC.
                                      There is a 1MEG trimpot U3... for the pump speed control (minimum?). Careful the TRIAC heatsink is hazardous live, if you go in there with a screwdriver to twirl it.
                                      Trimpot U1, U2 by LM358's are for temperature cal.
                                      I have found bad potentiometer that made it "all or none", and once I had a TRIAC become very insensitive and same result. I would expect the light bulb test to have some part-way brightness?
                                      If bumping the station changes things, it might be bumping the pump to start it or there is a bad solder joint or wonky potentiometer.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        #39
                                        Bumping doesn't change anything. When I had the lightbulb connected it seemed the same brightness (dim) up to the highest air setting then it goes full brightness. I also noticed some hiccups in the light when changing settings. Some quick instances of the light going off then back on.
                                        Should I attempt to play with the trimpot for pump speed?
                                        How could I test the pot and triac? I was wondering if cleaning the pot would do any good but it seems different than I'm used to seeing. Almost looks like there's silicone grease inside the enclosure
                                          • 31058
                                          check the soldering and do a recap.
                                          my old one, they hadnt even stuffed the parts into the board properly before soldering them!!
                                            ZD desoldering station pump rebuild
                                            by stj
                                            just did one.
                                            works great.
                                            so here's the discoveries.
                                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                            so you need to clean everything to get rid of all the tacky black stuff.
                                            then reassemble it.
                                            *BUT*
                                            you must put the 2 screws into the assembly only finger-tight.
                                            if you tighten it properly the valves dont work....
                                            08-21-2024, 05:59 PM
                                            HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-12-2024, 02:20 PM
                                            MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:20 AM
                                            HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 06:00 PM
                                            09-06-2024, 12:30 PM
