Looking for Recommendation for a Cheap Multimeter with Ammeter Function
  • Used_Cars
    • Oct 2015
    • 102
    My truck has an electronic leak. I think it's either the alarm system (factory) or the stereo system (aftermarket and has TEENAGER screaming all over it). Battery doesn't have enough power to even turn the dashboard lights on after 3 days of sitting there.
    Watched a Youtube video, and the guy said to check current flow from the ground side because it's safer than measuring at the 12 volt post. My multimeter is ancient and doesn't have ammeter function.
    I just need it for this one test and OfferUp has used Flukes at $180.
    Any recommends?
  • Used_Cars
    • Oct 2015
    • 102
    Re: Looking for Recommendation for a Cheap Multimeter with Ammeter Function
    I went shopping and found this:
    https://goo.gl/xfr7LM
    What do people think? It's five bucks.
      • 31195
      your in the u.s. - those are at Harbour freight and often given free when you buy stuff.
      they cost a lot less than that from china btw - more like $3-4 inc shipping.
      i shouldnt need to point out that they are shit
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        If you have Sub-woofer Amps or even any Hi-power Amps connected as part of the Audio system, that could be draining your battery if the are connected directly to the battery. There is usually a connector with 3 screws to power these Amps. 1. +12V to Battery, 2. +12V to switch and 3. GND. They may be in any order not exactly as I have listed but the 2. +12V to switch could be keeping the Amp/s on all the time.
        • desert-rat
          • Mar 2014
          • 4103
          In agrement with Stj harbor fright has some cheep volt ohm meters . They have one for $20-25 . My first thought would be how good is your battery . Next thought would be a light staying on , or a bad dioen in the alt.
          • Used_Cars
            • Oct 2015
            • 102
            I did some reading last night after posting this and taking the "it's the aftermarket stereo system" theory one step further, one guy I read said that these aftermarket bass units (the truck has a huge one) get turned on by the head unit, and then wait for the head unit to tell them to turn off. If the head unit doesn't send some kind of "off" signal, the bass unit stays on constantly until the battery dies.
            Well. In my case the battery never actually dies; it just depletes down to the point that things stop working. I can always get the truck started again with a jump, so it's not fully discharged all the way down to 0%.
            So if this is the problem I don't know what the solution is, other than pulling the bass unit and tossing it in the trash. I hate bass in my music anyways. Hearing that "THOOM THOOM THOOM" at a stop light makes me want to shoot up a school full of teenagers in retaliation.
              • 31195
              the amp usually has an led indicator on it
              • will62
                • 229
                • usa
                Go to your fuse box and measure voltage drop across each fuse. If your meter will not read millivolts, borrow one that will or order a $5 one off ebay like this one:
                https://www.ebay.com/itm/Red-LED-5-D...8AAOxyQyJRlcPq
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Are you sure there aren't any lights on that shouldn't be? (glovebox, ashtray, under hood, etc.)
                  Measuring in the ground leg vs. power leg is immaterial. The current has to flow in a loop so any side of the battery is as good as any other.
                  The admonishment re: the 12V terminal is in case you "slip" and short the probe to some portion of chassis (which is ground). This would be bad IF you are measuring the current "in-line" (disconnect one lead from battery, insert meter between battery terminal and disconnected lead) AND your multimeter isn't fused (if its fused and you "make an oops", you blow the fuse in the multimeter).
                  If you use a clamp-on ammeter, then you're never really in electrical contact with any part of the circuit so any place is as good as any other!
                  Any recommends?
                  For a one-time use, if in the US, go to your local Pep Boys, OReilly, etc. auto parts store and BORROW a meter. Won't cost you anything (other than your time to pick it up and, later, return it)
                  The trick is deciding how big of a load represents "too large". Skipping over that little detail, once you are set up to monitor the current with the car not running, ignition OFF, doors closed, (cuz the dome/courtesy light will draw a lot of power) etc., you can remove fuses one at a time and notice the changes in the current measured. (note reading, pull fuse, note new reading, reinsert fuse, lather, rinse, repeat)
                  Start with what you suspect most (aftermarket add-ons). The car (truck) manufacturer has obviously NOT designed the vehicle to run down its battery during normal use. So, some additional item is playing vampire. Or, some wiring error (pinched conductor?) is typically your problem.
                  Remember, removing power from some things can make them forget! So, think real hard before you pull a fuse: "Will this screw anything up that I will later regret?"
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    Disconnect power from bass unit. Let car sit for 4 days. See if you can start it.
                    • petehall347
                      • Jan 2015
                      • 4439
                      these work well . http://autoelectricalpartsuk.co.uk/i..._category=true
                      • desert-rat
                        • Mar 2014
                        • 4103
                        Its either something running the battery down while its turned off , the alt is not keeping it charged or the battery going down whle turned off . If you have around 14 volts while running the alt. is probly good . If you take one battery lead off ( while turned off ) and hook up a 12 v bulb . If the bulb lights up you have some thing going to ground .
                        p.s. A general purpose volt ohm meter , a number of other places have them as well
                        https://www.harborfreight.com/11-fun...ity-61593.html
                        • petehall347
                          • Jan 2015
                          • 4439
                          check for reports of that vehicle doing same thing with others .. i had one car in and it turned out to be the body ecm waking up too much and using all battery power . i couldnt see any excess current draw at all . software update may have fixed it but i fitted the device i posted above . that stopped the battery going flat
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Dang wish I could just give you these free with purchase coupon for the crappy HFT multimeter... I get them time to time.
                            Here's another trick you can do without an ammeter. Disconnect the battery terminal and hook up a light bulb... YES, DIM BULB tester... in series. Those slender 1cm x 3cm bulbs with the wire or cap contacts on both ends are around 12W I'd say is a good tester bulb.
                            Anyway you should suspect any audio device that can be turned on without the key in the ignition... I suspect teenagers won't like this as they claim their audio is more important than the car starting, but it's a good safety policy to put it controlled by the ignition key. With a typical car battery capacity around 50 ampere hours, 3 days means a good portion of 1 ampere is being drawn constantly. They say that this number should be less than 100mA.
                            With that above 12W bulb, focus on trying to get the lamp to at most be very dim. If it's lit bright in any way, you're drawing too much current when off! There, no ammeter needed!
                            • desert-rat
                              • Mar 2014
                              • 4103
                              This meter is rated for d.c. amps , if I understand how its worded . You would hook up a d.c. amp meter to the cables out of the battery , see if any thing is still drawing power after ever thing is shut off . It would work for ever thing except the starter .
                              https://www.amazon.com/bayite-Digita...s=dc+amp+meter
                                • 31195
                                actually, this is the type of place you want a UNI-T UT-210e
                                • caspian
                                  Can Ammeter damage Power Supply?
                                  by caspian
                                  Dear Members,
                                  My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
                                  But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
                                  Is this true?
                                  I have attached the photo of a sample Ammeter module that I am going to buy....
                                  06-05-2022, 01:42 AM
                                • dj8452000
                                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                  by dj8452000
                                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                  02-18-2025, 08:28 AM
                                  Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                                  This is a new item at Electronic GoldMine that has arrived within the last few weeks
                                  Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                                  Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                                  https://theelectronicgoldmine.com/products/g28392
                                  One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                                  11-24-2024, 01:25 AM
                                • Salvador Pérez
                                  Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
                                  by Salvador Pérez
                                  Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
                                  • 0.91V for the GPU
                                  • 1.7V for VRAM
                                  • 3.3V and 5V rails 1.8V for the BIOS
                                  • 0.9V for the CPU and iGPU 1.2V for the RAM
                                  However, these two coils are not showing any voltage....
                                  03-10-2025, 11:50 AM
                                • trex66
                                  Craftsman 82345 Multimeter broke!
                                  by trex66
                                  My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                  03-04-2025, 04:26 PM
