Arduino current sensing (in car)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    #61
    Re: Arduino current sensing (in car)
    Thanks for the input guys. This is one of the reasons I wanted to build that adjustable load a while back...I actually found one on Banggood pre-made, but it's not exactly cheap, so I'm not sure it would be worth the investment and pay for itself in the long run.
    Wattevah...
      • Jul 2011
      • 6069
      Could you please post the link to Item that you are taking about
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        #63
        Yes. Here it is. This also qualifies as a bit of a fail, since I recalled it being much more expensive than that, but looking at it NOW, it doesn't seem unreasonable (its price could've dropped indeed). When dealing with stuff like this I always put it like this: make or buy: would the cost of the components required to build one myself outweigh the pre-made version ? If so, I'd definitely choose the ready-made version...
        Wattevah...
          • Jul 2011
          • 6069
          I going buy few of them to how they work
            It looks reasonable by the time you add heatsink, control pot, and may be fan and the case for may be $20 and if it works really well, then it is great.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #66
              I also found pots on Banggood. Multiturn ones for reasonable prices (especially considering Banggood mostly sells multiple pieces for a low price)
              Wattevah...
                • Jul 2011
                • 6069
                Could you please post the link to it thanks
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #68
                  Have a look through the results yourself HERE and see what catches your eye
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #69
                    That load I linked to looks like it's got two op-amps on it....a double amplifier configuration perhaps ? I think I'll go for it myself
                    Wattevah...
                      • Jul 2011
                      • 6069
                      Thank you for the link
                      This is the one I going to buy
                      https://m.banggood.com/3590S-2-103L-...ottom-alsolike
                        • Jul 2011
                        • 6069
                        I saw that to that why I going to give it a try my self
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          #72
                          Yep - that's the one I chose myself...looks decent enough.
                          Wattevah...
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            Dang, I haven't used a multiturn pot in ages... I have two or so in my junkbox but none in any equipment...
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              #74
                              I just received those current sensors I ordered...haven't messed around with them yet, but in the meantime, my code reaching completion, I still haven't decided what the best course of action is regarding the different inputs: should I use "active high" or "active low" ? That is, should the pins read off when LOW or off when HIGH ? Power consumption is important, because the thing will be running on the car's battery, plus it has to be relatively noise-resistant, and in this regard I did some research and learned that the simplest form of debouncing is to add a capacitor between the pin and GND, of course this would require the "active low" setup, which is what I currently got going on on the breadboard, but how it will behave in the actual vehicle I have no idea....
                              Wattevah...
                                • 31247
                                active low,
                                if you use active high you need to screw around with voltage clamping and other shit.
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  #76
                                  I still need to clamp it to 5v anyhow, since I can't pull up or supply the board with more than that.
                                  Wattevah...
                                    • Jul 2011
                                    • 6069
                                    When I have done projects with a Basic Stamp I always use active high ( meaning do some part of the program )
                                      • 31247
                                      pullups enabled on the microcontroller, and inputs connected through diodes - job done.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #79
                                        It's a little more complicated than that, since I'm going to be using the existing rocker switches in the dash, but instead of connecting their outputs to the windows (like they are now), I'll connect them to the micro....right away there's a lot of difficulties: active low is not possible in this setup straight away, because if you know how a window rocker switch operates you know it keeps the outputs (the wires going into the actual motor) grounded at all times when not in use. When you flip it in one direction, one of the wires continues to remain grounded, while the other one is pulled high to VCC, so the motor goes in one direction. When rocked in the other direction, the wire which was VCC goes to GND and vice versa.
                                        So imagine the green and blue wires go to the motor in the door (don't mind the text, except the GND and VCC which are accurate), so what I'll do is cut them, put some connectors on them to make the install easier, then connect them to a NPN transistor each: one for UP, one for DOWN. When pressed in one direction, let's say "UP", 12v will go into the base of the "UP" transistor, pulling the E-C path to GND and the micro's "UP" pin with it, activating the corresponding pin of the H-bridge we'll be putting in. Meanwhile, the "DOWN" transistor's base remains grounded through the other wire which used to go to the motor....that's the theory at least.
                                        Trouble is, I'm not sure it will work to begin with and what trannies to use after the fact, especially since I'm using them somewhat opposite of how they're normally used: I'm switching a LOW signal with a HIGH signal, which brings us to problem no.2: the car operates at 12-15v (when running)....no need to say more. The buck converters I got off banggood should do the job of powering the while providing sufficient noise suppression....I hope....that's why I'm sharing this project, to hear other peoples' opinions and hopefully build it as robustly as possible.
                                        Granted, if I knew what I was doing, I wouldn't be posting asking for advice and it wouldn't be nearly as fun...half the fun is figuring out all this sh!t...some people hate it, but I like it...I love tinkering to waste time
                                        Wattevah...
                                          • 31247
                                          connect the red to ground and the blue & green to the mcu.
