Power windows automatic Switch
  • Jackching
    • May 2017
    • 127
    Anybody know the technical name of switches these are that are circled in red? The top one is the power lock and the second one down is the automatic power window switch out of my car. The lock still works but the window one doesn't. Just wondering if its possible to just to replace the switch as they want a fortune to replace the whole part. Thanks.
  • zx8401
    Phantom Fiddler
    • Aug 2013
    • 49
    Re: Power windows automatic Switch
    I would look at the contacts first, they may be a simple 6 pin double pole double throw switch.
    You may need to dissasemble one to see how they are configured.
    Sorry im not helping much, i would take one apart so i knew what connects to what.
    • R_J
      • 9580
      Are you sure its the switch thats bad? It should be easy to check it with a meter. they could be double pole double throw, on-off-on momentary center off
      Probably easier to find one at an auto wrecker, or there could be after market ones on line. they do list similar items
      • redwire
        • 3912
        Look for a logo on the switches, to tell who makes them.
        In all likelihood, they are Kyungin, a Korean make and hard to find.
        You can get the whole door/window switch assembly off eBay or Ali.
        Usually the door wires break, in cold weather, at the hinge point.
        • petehall347
          • Jan 2015
          • 4433
          • United Kingdom
          switch cleaner usually fixes those .
          • gabik111
            ORD spotter
            • 142
            • USA / Poland
            Depends on what car is this usually they are integrated with the board that is underneath. The board might be a part of the internal network (CAN) which contains other features in your car.
            I would try to fix this or as other suggest check wires.
            Laptops and computers repair.
            • Jackching
              • May 2017
              • 127
              Thanks for all your suggestions. I was able to try a new switch and it still didn't work. So now I'm down to a wire, the motor or maybe a relay. The fuses are fine
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                The motor in my opinion is the issue, here. The motors have a tiny switch that goes bad for some reason. The switch opens and breaks the power when the window reach full up or full down when in-travel.
                • gabik111
                  ORD spotter
                  • 142
                  • USA / Poland
                  It calls limit switch. It might need some service (I did it in my Sienna when there was an issue with automatic door) - just need some cleaning and greasing. It require to deassembly the motor housing if it is possible (some motors are assembled permanently).
                  Some motors have an electronic limit switch which brakes the power when motor current is higher than some programmed value (when the motor gets mechanical resistance it needs more power=current to operate then electronics sees that and shutting off motor power).
                  • Powderfanupnorf
                    Dell AL440LX power on switch circuit help required
                    by Powderfanupnorf
                    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                    06-24-2024, 01:24 PM
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    09-06-2024, 05:59 AM
