Electronic Controller for The TRIAC ( BTA100-800B )
    • Jul 2011
    • 6070
    I bought one of these units
    Here is the pictures of the two boards that make up this controller
    If I change the resistor to the optic sensor ( on the LED input side ) could I get better control of this triac
    The ( “0” ) setting is zero power to the output side of this controller
    The problem I have with this version of it is that most of your control is from a setting of 30 to 35 on the controller display which translate to about 1 to 15 amps
    Or a little over 2 amps per step
    I would like to change this to 1 amp per step
    From this I estimate that this transformer at full 120 volt without any controller is probably about 50 amps or so
    Because I have tripped a 20 amp break a few times already
    In my shed where I going to be using it I am probably going to put a 50 amp break in it to be able to use it a lot higher amps than what the controller that was on it was doing
    But we are only talking about 250 to 500 milseconds ON time or maybe less time than that
    This is on this battery spot welder that the controller went bad that I am trying modify to use replaceable controller parts with
    Here is a picture of both boards
  • redwire
    • 3912
    Re: Electronic Controller for The TRIAC ( BTA100-800B )
    I would try the unit with a light bulb/heater load and multimeter, to see if it is more linear with a resistive load. The inductive-load transformer might be confusing the unit.
    You are thinking of driving the opto with less current, but that doesn't drive the triac less, as in a linear control. A triac is either on or off, you just need to control when in time (on a sine-wave) it turns on, to modulate the power.
    Looking at the boards, I'm guessing it has a single chip MCU and which tries to phase-control a triac. Can you set it for 50/60Hz? I'm not sure how good this design is, they say "non-linear" voltage control for the "10000W scr voltage regulator" it's called. The zero-cross detection, or triac inductive-load triggering may be malfunctioning, or it's just crappy chinese firmware.
    For spot-welding, most people are using a 555 timer and foot switch to pulse a SSR or scr/triac's like you have on the power board. You could just ditch the MCU board. The 4-pin cable has (+5V, zero-cross, GND, SCR opto drive)
      • Jul 2011
      • 6070
      I would like to do that but here is my problem I have to do milliseconds
      I have a timer that will do milliseconds
      What kind of zero controller could I use that would work for an inductive load (transformer)
      Do any idea or point me in the right direction
        • Jul 2011
        • 6070
        I understand that a triac is either on or off
        I have tried to find a circuit on google to do this with no luck or I just not using the right terminology
        When googling for the right circuit to build for this project what terminology do I need to use
        • redwire
          • 3912
          I'm not sure what you are controlling power, it is a spot welding transformer?
          These are energized with full mains just for a little blip, for 10-100's milliseconds kind of thing. So a triac switches full power off/on/off to the transformer for many powerline cycles.
          Instead, if the triac is always turned on only for a part of a mains power cycle (repeatedly), let's say 90 degrees, then you get 1/2 power which averages to 1/2 the voltage.
          This is like a lamp dimmer, or how your "10000W scr voltage regulator" is. It dials down steady power flow compared to a one time blip.
          555 timer to make the pulse. Fancier builds use an Arduino spot welder.
          http://www.instructables.com/howto/spot+welder
          https://hackaday.com/2014/09/21/a-pr...ve-transformer
            "This is on this battery spot welder that the controller went bad that I am trying modify to use replaceable controller parts with"
            Can we see what the old controller looks like and how it is being used?
              • Jul 2011
              • 6070
              I will tried to post the picture of both sides of the board tomorrow
                Get the Make and model too.
                • master3112
                  ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                  by master3112
                  I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                  When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                  10-29-2024, 09:32 PM
                • ronnygracias
                  Help with freemotion incline trainer with controller comm error
                  by ronnygracias
                  The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                  11-04-2024, 01:32 PM
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  by sam_sam_sam
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • Stephen
                  A2991 Logic Board issue, 20volts 0 amps help!
                  by Stephen
                  Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                  09-10-2025, 03:16 PM
                • Stephen
                  A2991 logic board issue, 20volts 0 amps help!
                  by Stephen
                  09-10-2025, 03:15 PM
